Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 62
Reload Thread: 4 10 inch subs or 2 12 inch subs
    mscott1979's Avatar
    mscott1979 is offline Senior VIP Member
    Jun 2008
    below the mason dixon
    161
    I'm having a tough time deciding, either i'm going with 2 dvc 12's wired in series to make a 4 ohm load or 4 svc 10's wired in series to make a 4 ohm load. Which would give me more output as far as spl goes? By the way im using a amp rated at 500 rms not much power i know and i plan on building a ported box for the 2 12's and a sealed box for the 4 10's so what do you guys think?
    SQChevy's Avatar
    SQChevy is offline Senior VIP Member
    Jan 2006
    Dallas, TX
    390
    Re: 4 10 inch subs or 2 12 inch subs
    I've had 4 10" sealed JL Audio 10W6AE's underneath my back seat and people thought I had 2 ported 12's. It was amazing the amount of bass that they produced. I had them downfire with about a 1" gap between subs and the carpet. That would be my suggestion. You will also have a lot more cone area with the 4 10's.
    2002 Green Chevy Z-71 Extended Cab pickup with bed cover - VEHICLE IS NO MORE
    Alpine VPA-B222 VehicleHub Pro, DVA-5210, TME-M770S, PXA-H700, KCA-100BT, TUA-T500HD
    Focal Be Tweeters, Be 6.5" Midrange, 21WX 8" Sub, 2x 40A 15" Subwoofer
    Focal 2 FP 1.800, FP 4.75
    2004/2005/2006 USACI World Champion
    2003 World Finalist
    Rashaddd's Avatar
    Rashaddd is offline Terrrrrist
    May 2008
    Sacramento
    5,098
    Depends alot on the woofer...the 10's would likely get louder, but the 12's will get lower. Personally I'd go with the 12's, I love lows
    adam212's Avatar
    adam212 is offline freek show
    Jan 2008
    Alabama
    130
    really depends on the enclosure no particular size is gonna get lower its all about the box you put them in and if you can fit a larger enclosure i would suggest 4 10's
    SeanDub's Avatar
    SeanDub is offline CarAudio.com Veteran
    May 2006
    Kansas
    24
    3,528
    19 Post(s)
    Quote Originally Posted by Rashaddd View Post
    Why will the 12s get lower? Because they are larger?
    Deck: Pioneer Premier 880 w/ iPod
    In-dash: AudioControl Epic-150
    Sub: Digital Designs 9515e/f Dual 1.0
    Amp: Atomic 5000.1 @ 0.5 ohm
    Box: 3.85 @ 36 hz with 66 sq in of port
    Refs: fwb_1234, Hopes Audio, Louisiana_CRX, astrolade, nhustlar, teamquakecelica, walkychalky, negative3five, TypeRBass, jblanford (x2), massiveaudiocw, KnOkIn It 420, hoss, xtremebassjunky, trow100, MillzThaYungin, IonSQL, matrxx dude, yunvme666, vitveet, PWNED, Team H&K, jk32sho
    OoMesKoO's Avatar
    OoMesKoO is offline Me > Newbs. :fyi:
    Sep 2005
    Rhode Island
    27
    3,410
    wow. This is going to be fun. Rashaddd, I recommend leaving, forgetting about your original username and trying again. You will be flamed. Extremely hard in less than 12 minutes.
    ::References::
    Sold: BIG_SUPERMAN72, biggie5252, Anonymous User, mustangowner
    Traded: poundindak69, perfecxionX, CRXBMPN
    Bought: nismos14, JasonPaul, phoenixgoldfan1, ace 800, ABSOLUTEAUDIO, wu501
    adam212's Avatar
    Jan 2008
    Alabama
    130
    haha^^^
    mscott1979's Avatar
    Jun 2008
    161
    Quote Originally Posted by OoMesKoO View Post
    ha ha
  9. #9
    mscott1979's Avatar
    Jun 2008
    161
    Quote Originally Posted by adam212 View Post
    im not going to be able to put the 10's in a big box because of trunk space, as a matter of fact it will be .91 cu ft per chamber....i have a lincoln ls. On the other hand, with the 12's i could build a decent sized enclosure and it would definitly be ported, maybe like 2.5 cu ft. I was also wondering with 500 watts rms would roughly 125 watts per sub if i was to go with the tens, would that be enough for them or would 250 watts per sub for the 12's be better.
  10. #10
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,141
    31 Post(s)
    why not 4 8's ?
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  11. #11
    97gp's Avatar
    97gp is offline Banned
    Nov 2007
    ohio
    7,931
    Orly?
  12. #12
    mscott1979's Avatar
    Jun 2008
    161
    Quote Originally Posted by Louisiana_CRX View Post
    why not 4 8's ?
    didn't think they would get loud enough due to cone area
  13. #13
    GMCJimmyslt2000's Avatar
    GMCJimmyslt2000 is offline ll Faded ll
    Feb 2007
    South Bend, IN
    1,558
    u need some very effiencient subs with that amount of power. The 12s and 10s are both pry gonna be underpowered.
    what kind of amp is it. Can u afford another one.
    if u cant get another amp, i would go with one 12 in a nice big ported box, should get decently loud and not be underpwoered
    Refs:
    Bought From- Spy, 18inchjeepin, BJ The Man, Jeeper07,
    Pjvoc, lil_italy773, NJTStang11
    Equipment:
    HU- Pioneer 4800
    Speakers- Stock Bose
    Sub Amp- Hifonics Brutus 1100@2ohm
    Sub- 15" Fi SSD w/ Copper Coils
    Box- 3cubes Tuned at 33hz
  14. #14
    mscott1979's Avatar
    Jun 2008
    161
    kenwood kac 9103d 500 watts rms @ 4 ohms 900 @ 2 ohms but I don't run it in 2 ohm mode because at higher volume levels the amp has a tendency to go in and out of protection mode, but the amp does have some pretty decent power. The 12's that i have now, it pushes them just a wee bit harder than they should be pushed. They are svc 400 watts rms and the amp is wired at 2 ohms. I don't want to wire them up to 8 ohms thats why im replacing them with dvc subs which will give me more wiring options, but i was thinking "hey i could go with 4 svc 10's since im swithching it up anyway.
  15. #15
    mscott1979's Avatar
    Jun 2008
    161
    bizzump
