Results 1 to 9 of 9
Reload Thread: 15" brahma...entering comp, need help
    audio hoe's Avatar
    audio hoe is offline Member
    Feb 2003
    toronto
    32
    what would you recomend for box size and tuned to what freq. for the brahma to play the loudest possible, size isnt an issue, im building this box strictly for this comp so sound quality is absolutly no issue....
    thanks for the help
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    well check the following site....it will tell u the best possible box size for a given power range.......
    http://www.adireaudio.com/mobile_aud...r_handling.htm
    F150Matt's Avatar
    F150Matt is offline Senior VIP Member
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    Dont go by that crap. If your competing you for sure dont want a sealed box...how much power are you using? This will determine how big you can make the box and how big you can make the port. What type of vehicle are you using? All of these factor into tuning frequency and box size...
    Matt Sibley
    Dad, Electrical Engineer, MBA
    Used to do these:
    Team S.P.E.A.D. Captain
    Team Kicker
    Team Maxxsonics
    USACi Pro Stock 5001+ World Record Holder
    audio hoe's Avatar
    Feb 2003
    toronto
    32
    running off a jbl1200.1
    going in a dodge durango, the sky's the limit box size wise...
    any help will be apreciated
    thanks
    F150Matt's Avatar
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    I'd start with about 6 cubes and 180-200inches of port. Try to find your resonant frequency and tune the box to peak at that. You should be able to be pretty succesful with it. Its all trial and error...make that port removable, and try increasing and decreasing port area, try changing box positioning in the vehicle...all of these things can make or break your SPL. It takes a lot of work to get it right. Good luck.
    Matt Sibley
    Used to do these:
    Team Kicker
    Team Maxxsonics
    BDIDDY's Avatar
    BDIDDY is offline Sittin' Slick
    Mar 2003
    Tennessee
    30
    2,575
    how do you find the resonant frequency?
    "Just have to remember to take everything in stride, and don't put off till tomorrow what you can do today because there might not be a tomorrow. " <---- RAMOS
    Profliepower is the funniest guy ever...
    bigbassman's Avatar
    bigbassman is offline Master of all things loud bigbassman is a Supporting Member of the forum!
    Apr 2002
    Southern WV
    36
    2,890
    if you have access to an spl meter.. you build, and keep adjusting the port till its loudest.. whatever frequency that is at, is your resonant..
    if you don't have access to a meter.. you guess..
    Loyd L.
    SQL Prolly
    BDIDDY's Avatar
    Mar 2003
    Tennessee
    30
    2,575
    is there a good number to start at. and can the right number make that much of a difference?
  9. #9
    F150Matt's Avatar
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    Yes that number can make a significant difference. I suggest you get to know a few guys at a local shop, one that has a meter, and get them to let u use it for an hour or so. May wanna try a lil less than the port area I suggested earlier too, I forgot you only have a JBl 1200.1. You might want to start with 100 inches and go up from there. I think thats what I am gonna do with my XXX 15 when it comes in...David seems to think a one to one ratio would be good for port area...try it with your brahma.
    Matt Sibley
    Used to do these:
    Team Kicker
    Team Maxxsonics
