Results 1 to 9 of 9
Reload Thread: Why is This Powered Subwoofer Not Working?
    pekoe1111's Avatar
    pekoe1111 is offline Junior Member
    May 2008
    Vermont
    I bought a used Bazooka EL8A-HP 8" 100 watt Subwoofer on EBay and can't figure out why it is not working. Here's the deal:
    I have the red power wire hooked directly up to the Pos side of the battery in the trunk, and the black ground wire bolted to a good ground. The orange wire is hooked up to the head unit. RCA jack speaker wires are hooked up as well.
    This wire setup worked with my other powered Bazooka sub.
    Symptoms:
    1) Light is not on on the sub.
    2) When I take the ground wire off and touch it to ground, it sparks.
    3) When I put the inline fuse in the its slot (I just spliced a fuse into the power wire), it makes a small "zap" sound). I have also removed the fuse wire and now have the power direct to the Pos battery side and still no light on sub.
    Shouldn't the light come on even with just the power and ground wires hooked up?
    Tnaks,
    BB
    thaster's Avatar
    thaster is offline CarAudio.com Elite
    Feb 2007
    pennsylvania
    1,252
    Re: Why is This Powered Subwoofer Not Working?
    sub is finish. you might have bought a blown sub. or if you want, use a DMM and check
    Acura Integra
    HEADUNIT - Pioneer AVIC N2
    FRONTSTAGE - Crystal SSCS6 component system
    REAR - None
    FRONTSTAGE AMP - Diamond Audio d3 400.4
    SUBWOOFER - Image Dynamics IDQv3 12 inch
    SUBWOOFER AMP - Alpine PDX 1.600
    SUBWOOFER BOX - 1.9^3 @ 28 hz ported box designed by JBLCAMRY and built by BJ FISHER
    dman4486's Avatar
    dman4486 is offline RememberedHowToChangethis
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    did you connect a remote wire?
    Autos:
    '12 Audi A3 S-Line TSI 6MT
    '96 Honda Passport 3.2L v6 4X4 5sp
    2015 Victory Cross Country Tour 106
    2015 Ford Escape Ecoboost
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
    pekoe1111's Avatar
    May 2008
    Vermont
    Remote Wire
    Isn't the orange the remote wire? I connected it to the head unit, as I did with my other one. I believe that tells the sub when to power off - typically after about 30 secs. - right?
    What is a DMM?
    Also, is there a fuse inside? Maybe that is blown. My old powered sub had a fuse on the outside back panel, but the other one has no visible fuse...
    Mar 2007
    saint charles, IL
    27
    10,311
    Quote Originally Posted by dman4486 View Post
    x2 you might not have the remote wire either run right or you dont have one period
    pekoe1111's Avatar
    May 2008
    Vermont
    What is the orange wire supposed to connect to? As I said, on my other powered Bazooka, it worked fine. The sub stayed on for 30 secs. after I turned off the car, then turned off, so I am assuming it works fine. I even disconnected the orange wire - no diff.
    BB
    pekoe1111's Avatar
    May 2008
    Vermont
    Mystery Connection on Powered Sub
    So I took a closer look at the back panel of the powered sub and it has:
    1) Clip on connection with all the wires
    2) Switch (looks like ON/OFF
    3) LED green light (currently will not go on)
    4) MYSTERY: small round plug hole with a plastic, screw-on fitting.
    Anyone know what this is? Maybe it is the reason the sub is not working...
    dman4486's Avatar
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    pictures might help
    Autos:
  9. #9
    pekoe1111's Avatar
    May 2008
    Vermont
    Figured it out! Disconnected the orange remote wire and connected the brown/yellow wire loop...
    Thanks!
