Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: Subs Not Moving in Sync with One Another
    james33440's Avatar
    james33440 is offline CarAudio.com Elite
    Oct 2002
    FL
    36
    1,875
    Icon33 Subs Not Moving in Sync with One Another
    I was just wondering that if subs weren't moving in sync with one another would it be harmful? Would it affect SPL in anyway?
    2001 Altima System:
    Alpine CDA-9855 (3Way Mode)
    Kicker Resolution RS6 Components (Active Setup)
    CDT Tweeter Image Enhancement Kit
    3 Ascendant Audio Arsenal 12's (Sealed)
    Kicker KX650.4
    Kicker KX1200.1 @ 0.67-ohm
    My Video Thread
    My CarDomain Rides
    more_spl's Avatar
    more_spl is offline only have 1, but it's 12"
    May 2002
    Winnipeg
    32
    1,108
    Affect SPL: YES. Becuz you aren't pushing all the air it can at the same time.
    Possible Causes:
    -polarity of one sub is reversed
    -you are using 2 (or more) subs in a box which is one big enclosure (nono on sealed).
    With them using the same air space, they compete for the same air. It's called "push pull effect"..
    i decided not to have a signature
    LoneRanger's Avatar
    LoneRanger is offline Old Yamahas Give Me Wood
    Dec 2001
    Wellston, Ohio
    35
    1,379
    I've also seen leaky boxes, faulty RCA's and bad amps cause this....
    "There is no 'I' in Tag Team"
    Project 'rex: Coming Soon to An Eardrum Near You
    james33440's Avatar
    Oct 2002
    FL
    36
    1,875
    What about a common chamber ported enclosure? Should the subs still move in sync with one another?
    2001 Altima System:
    Kicker KX650.4
    My Video Thread
    My CarDomain Rides
    alove_85's Avatar
    alove_85 is offline Love is Life
    Jan 2003
    In Your Sister
    32
    3,016
    sounds like their out of phase, try changing the polarity or even the angle of the box.
    bumpin_blazer's Avatar
    bumpin_blazer is offline Only the Strong Survive
    Mar 2002
    Austin,TX
    35
    8,044
    my guess is it isn't a phase problem or polarity by reading your discription of your audio setup my guess is it's b/c your using 2 amps 1 per sub. unless you have the amp strapping circuit they talk about my guess is that's your problem. one of the amps might be slighty off of when you tuned the amps together in the first place. now if they are strapped together then i'm wrong and it is something else.
    adam
    2006 Bright Island Blue 6s: stock 6 disc in dash, Hertz Hi-Energy 6.5" comps, MB Quart Ref 12", eclipse 5-channel sub amp.
    Car mods: Lowered on Mazdaspeed springs with Koni Yellow shocks, Racing beat front/rear sway bars with AWR end links, LED turn signals, tail lights, front side markers, 18" ADR Cypher rims, 55w HID's in low beam and fogs, 5% tint all the way around. No go fast mods yet...tuning and Mazda6 don't go well together .
    Steve a.k.a. ss3079: So this one lady goes, "These ignorant people who drive around blasting there music, they cant hear emergency vehicles"
    So that set me off, and I said "Well then why do they let deaf people drive?"
    AOL: JmKeenen
    LoneRanger's Avatar
    Dec 2001
    Wellston, Ohio
    35
    1,379
    wow....
    for once adam and i are on the same page
    hihoslva's Avatar
    hihoslva is offline Member
    May 2003
    Long Island, NY
    83
    This effect does not exist. 2 subs in 2 cubes of air will behave exactly the same as 2 subs each with 1 cube of air (sealed enclosures). They do not "compete" with each other for airspace.
    "push-pull" is generally a term for isobaric loaded boxes, where the subs are wired out of phase on purpose - one sub pulls , while the other pushes.
    In a sealed enclosure with both subs wired the same, they act together. There is no need to have subs in separate airspace except to protect the other if one blows. Sharing airspace has zero effect on SPL, x-max, or any other factor of how the woofers perform. It's basic physics.
    ~HH
    2002 Sunlight Silver Metallic Mazda Protege5
    Kenwood~Lanzar~Infinity~Peerless
  9. #9
    roop's Avatar
    roop is offline Member
    Feb 2002
    MN
    34
    79
    check that you + and - cables are both right.
  10. #10
    more_spl's Avatar
    May 2002
    Winnipeg
    32
    1,108
    ~HH
    ok. i'm not doubting you. I would like someone to explain. The air is all shared, so how can it be 100% equal between the 2? Split 50-50. It sounds impossible.
  11. #11
    Mar 2002
    Austin,TX
    35
    8,044
    Originally posted by LoneRanger
    wow....
    that's b/c i'm learning my good man. my biggest guess is that though don't you think??
    adam
    AOL: JmKeenen
  12. #12
    EPanther99's Avatar
    EPanther99 is offline Senior VIP Member
    Feb 2002
    Elizabethtown KY
    37
    306
    Re: Subs Not Moving in Sync with One Another
    maybe im missing somthing but if your subs are wired in stereo and not in mono they will not move in sync with each other bc there will be bass in the left channel and not in the righ tat times...
    HU: Pioneer Premier P-720
    Front: JVC 2 way 6.5" component system
    Rear: Kenwood KFC-1687
    Subs: (2) 2002 Kicker 15" L7's
    Amps: (2) Infinity Beta Digital 300's
    (2) 1 farad Stinger Power Caps
    (2) 1 farad Monster Cable Monster Caps
  13. #13
    more_spl's Avatar
    May 2002
    Winnipeg
    32
    1,108
    Re: Re: Subs Not Moving in Sync with One Another
    bass is (or at least SHOULD BE) recorded mono. It will play the same way w/ multiple subs in stereo config. My subs are corrently wired stereo (becuz of my amp) but they still move in sync w/ each other. It's like this cuz bass is omnidirectional
  14. #14
    EPanther99's Avatar
    Feb 2002
    Elizabethtown KY
    37
    306
    Re: Re: Re: Subs Not Moving in Sync with One Another
    i have many bass cds where the bass is recorded in stereo....it kind of gives a waving effect to the music, and when it plays one speaker will be moving a lot and the other will stay still bc everything is recorded in the left or right channel at that time, although i have almost always had my subs wired in mono the bass is louder....
  15. #15
    hihoslva's Avatar
    May 2003
    Long Island, NY
    83
    If you run subs in stereo, they should be separated. The subs moving independently is not a good thing when they share airspace - and yes, plenty of the frequencies played through subwoofers IS recorded in stereo. There's no reason bass *should* be recorded mono, and often it is not.
    The human ear cannot determine what direction bass comes from, but this varies with frequency. While you might not be able to locate the sub playing 40 or 50 hz, you can definitely hear where 80 or 100 hz is coming from, and that is still sub-bass in a lot of music and in many people's setups.
    For stereo subs, separate them if at all possible. But since 99% of us (probably) run subs mono, shared airspace is a-ok.
    ~HH
