Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Reload Thread: good single 12" sub for this amp..
    blueski's Avatar
    blueski is offline Member
    Apr 2003
    NJ
    41
    90
    I have a mtx 81000D and I m looking for a single 12"setup at 2 ohm ..I will ported the sub what can I get?
    dave_3148's Avatar
    dave_3148 is offline fuggun "a" man!
    Mar 2003
    texas
    30
    1,026
    whats your budget?
    blueski's Avatar
    Apr 2003
    NJ
    41
    90
    $400 or less
    blueski's Avatar
    Apr 2003
    NJ
    41
    90
    ttt
    97dakota's Avatar
    97dakota is offline lovin Belize
    Aug 2002
    st.louis
    33
    899
    with that much I would look into like a brahma, re lines. I personally have never heard these. talk to RangerMan, SS(with four numbers behind) can't remeber ramos. they all have had them I believe.
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    A brahma won't work, it's dual 2 ohms...
    An XXX...if you call and ask them to make it dual 1 or dual 4, then that would work...
    burtonsnow83's Avatar
    burtonsnow83 is offline shred the gnar
    Jan 2003
    Salt Lake city Ut
    34
    535
    which one would the de9.1 work with? I am kinda retarded
    http://www.sounddomain.com/id/burtonsnow83
    148.1 on the dash(rangerman's mic)
    H/U -Alpine cda-9815
    Comps- CDT Cl61a
    Sub- 2 edk 12.44
    amps- Avionixx AXT 800.2
    Us acoustics usx2080
    box - 2 cubes each at 33 hz
    wiring-knukonceptz
    All in an 02 xterra
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    Either.
    Both the Brahma and XXX have the ability to be wired to 1 ohm(The XXX is 1.17).
  9. #9
    Drewbert1's Avatar
    Drewbert1 is offline Member
    May 2003
    Cando North Dakota
    27
    34
    Got a sub for u!
    I think you should hook the fabulous amp to either a Rockford Fosgate Power 12' or a Jl audio 10' w7. These two subs sound about the same, but if i were you i would go for the w7.
    Good Luck on getting the perfect sub!
    drew_cobain
  10. #10
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: Got a sub for u!
    You're gonna get so caned for that...
    I love RF's, but they do NOT sound the same as a W7....
    He also mentioned a $400 budget. I have yet to see any W7 at that price, unless it's second hand.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
  11. #11
    blueski's Avatar
    Apr 2003
    NJ
    41
    90
    can those RF power 12" or 10 w7 handle that much power?
  12. #12
    grizzjwill's Avatar
    grizzjwill is offline Beatin down the block
    Apr 2003
    nashville,tn
    30
    1,504
    38
    I havent seen a second hand W7 for less than 400 dollars
  13. #13
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    I believe a W7 might be able to take it, as well as RF, so long as you don't seal them. Feels weird saying W7 and RF at the same line...
    SO long as one is careful with the gains, I'm sure both subs can handle a bit more power than its initial rating. Also depends, really.
    W7's are 4ohm SVC.
    The RF punch series HX2 is 4ohm DVC(final = 2 ohms) .
    The RF power HX2, on the other hand, is 2ohm DVC (final = 1 or 4ohms) .
    All in all, I say as far as power goes, both subs would have no problems with a little over the recommended.
    If your amp puts out about 750w RMS @ 4ohms, I think that's too bad, pushing either sub. Only difference is how clean or brutal you want the bass whipping on your back.
    If I'm not mistaken, MTX amps are not known as an SQ amp. (According to knowledgable people on the forum, there IS such a thing as an SQ amp)
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
  14. #14
    Jdg784's Avatar
    Jdg784 is offline Yep..I'm God
    Oct 2002
    Suwanee, Ga
    33
    723
    Umm..if you seal them they handle more power, think about it..with a sealed box the air inside gets pressurized as the sub moves, causing more resistance, and therefor more power is needed to move the sub to it's x-max. A ported box causes power handling to decrease,
    98' F-150 Lariat SuperCab Flareside
    Dual Flowmaster Exhausts
    Custom ECU Chip
    Much Engine Work 305 hp, and 429 lb ft of torque
    Alpine 7894 running to 4 Pioneer 5x7's
    JBL 1200.1 running to a 15" XXX in a 3 cube sealed custom built enclosure.
    140 sq feet of second skin.
    AIM-Soccerguy784
    [email protected]
  15. #15
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    Kicker L7, RE HC, RE XXX, ED A
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
