Results 1 to 10 of 10
Reload Thread: Dual 1ohm vs Dual 2ohm
    conn.am's Avatar
    conn.am is offline Senior VIP Member
    Sep 2006
    Celina, OH
    30
    283
    I am looking at the FI Q's....someone please explain to me the diff. between dual 1 and dual 2.
    AudioXtremes's Avatar
    AudioXtremes is offline Team FatStig
    Nov 2006
    Indianapolis, IN
    1,857
    1 Post(s)
    Re: Dual 1ohm vs Dual 2ohm
    Other than the resistance difference? Well a d1 coil will usually have a fatter coil and more bl product. In my dual .7 and dual 1.4 flatwould aluminum coils the .7 will handle more power.
    But in the FI sub's case I believe he machines them differently depending on coil choice so this may not be the case.
    TEAM FATSTIG
    Cause I just gotta be me!
    conn.am's Avatar
    Sep 2006
    Celina, OH
    30
    283
    Did not understand that at all. I dont know which one i would want if i want two of them on one amp....
    bigbirney420's Avatar
    bigbirney420 is offline CarAudio.com Veteran
    Feb 2005
    Omaha, NE
    42
    2,412
    13 Post(s)
    It depends on what you need your final load for the amp to see. A single Dual 1 can be wired in series to 2 ohms, and if you have a pair of Dual 1's wired in series then the amp will see 1 ohm load. If you have dual 2 it will be 1 ohm in paralell, or 4 ohms in series. A pair of dual 2's will show 2 ohm final.
    2009 Pontiac G8 GT, Rotofab Intake, SOLO Exhaust, Pacesetter Headers, LS7 MAF Patrick G Tune
    Hybrid Imagine 6.5 front, Image Dynamics CTX 5.25 rear doors. Sundown SA10 of JBL MSA-500
    2007 Toyota 4Runner
    Polk DB Coaxes, JBL MSA-500 running Sundown SA12
    Refs: Pike110,Hintzyboy,dcmcki, qcsfinest704, MagickMan, allstar1500bd, ravemeister, Team PSI, Jntar, Brian Owens, and others....so many
    Nov 2006
    Indianapolis, IN
    1,857
    1 Post(s)
    What amp are you using?
    TEAM FATSTIG
    SilverSquared's Avatar
    SilverSquared is offline Fat guy on the GROUND.
    Dec 2005
    Southeast Louisiana
    2,190
    2 Post(s)
    73 Post(s)
    Its all on the wiring you want....
    D1....parallel final load is 1/2 ohm, in series its 2 ohms, per sub.
    D2....parallel final load is 1 ohm, in series its 4 ohms, per sub.
    But, with more than 1 sub, theres series-parallel wiring too.
    conn.am's Avatar
    Sep 2006
    Celina, OH
    30
    283
    I have a Hifonics 2000 watt amp. I used too have two type r's (4ohm versions). I would want it to go down to 1 ohm for "max" power right? I understand 1/2 ohm is not recommended. If i had two fi q's i would want the Dual 2 versions to get down to one ohm right?
    Feb 2005
    Omaha, NE
    42
    2,412
    13 Post(s)
    If you had 2 FI Q, you would want dual 1 to wire to 1 ohm load, thats how I have it on my Sundown. I would not run Hifonics at lower tha 1 ohm
    2007 Toyota 4Runner
  9. #9
    conn.am's Avatar
    Sep 2006
    Celina, OH
    30
    283
    Quote Originally Posted by SilverSquared View Post
    But this says D1 is either .5 ohm or 2 ohm ?
    "D1....parallel final load is 1/2 ohm, in series its 2 ohms, per sub."
  10. #10
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    You going to run one or two of them? If you are only running one, get the D2 if 2 get the D1.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
