Results 1 to 2 of 2
Reload Thread: Subs causing amp to go into protect?
    FAM4LIFE's Avatar
    FAM4LIFE is offline SHILOH BOY
    Nov 2002
    Hampton, VA/Waldorf, MD
    1,252
    Is it possible for a sub to send a amp into protect when it is wired correctly?
    2006 Titan XE
    Under construction!
    Mar 2003
    MI
    27
    63
    I would check to see if it is wired pos to pos.. neg to neg. also check the ground wire, if the ground wire is not attached it will go into protect mode. most often it is the ground wire.
