Results 1 to 7 of 7
Reload Thread: 2007 Chevy Silverado EXT CAB. HELP
    mdsheely's Avatar
    mdsheely is offline Member
    Oct 2007
    Indianapolis,IN
    141
    I just got a 2007 chevy ext cab z71 ltz. I would like to put a system in. The problem is there is almost no room. I have the factory six disc changer w/ XM radio. Also the factory bose system. It does not sound that bad now, but I would like to add some bass. I am having a 10'' box built but they are trying to get me to buy some off brand subs. They are pushing kole audio. I did a little research and have heard nothing good about there products. The sub in question is this one.
    http://www.woofersetc.com/index.cfm?...roduct_ID=2106
    They had one in their shop and it felt solid. I know I shouldnt go by the way something feels, but the build quality felt okay. I Was thinking about the shallow mount type S or Kicker CVT. Any ideas?
    Basically around 300rms for the amp if you have any suggestion on that too.
    I am not on a real tight budget, but with the limited amount of room I dont think I will need to spend a whole lot.
    crunktimes.com's Avatar
    crunktimes.com is offline CarAudio.com Veteran
    Nov 2006
    New England
    45
    9,689
    11 Post(s)
    Re: 2007 Chevy Silverado EXT CAB. HELP
    pole audio?!?!?!?!
    Come get your crunk on! www.crunktimes.com/ct
    casper97ta's Avatar
    casper97ta is offline IM HERE FOR THE GANG BANG
    Jul 2006
    Pittsburgh, PA
    3,469
    7 Post(s)
    For bass on a budget you cant go wrong with kicker. They make subs to fit almost any ones budget and space requirements. Have you looked into Q form enclosures or the MTX thunder forms?
    http://www.qlogicenclosures.com/c-583-ql-c1gtx110.aspx
    H.U- Alpine IVA-D310
    clarion EQS746 EQ
    Front stage- PPI 356CS
    Front amp- Exile S400.4
    Sub-
    Sub amp-
    NSB100
    _____________________
    REFS :pimpedout97x,Mike Dressure(x3),hc3_cuz,keefy248,seagrasser,Gammey4,p hillipcyoung,Hawaiian5(x2),Dumpin Treos,delvryboy, xtremebassjunky,All_Rice,AgEnT,96MaxGLE,kurtdirt1, Louisiana_CRX,wu501,REDLINEZ33,vxboi,mrogowski,Zeu slicious,LazyRider
    Quote Originally Posted by cotjones View Post
    you have to admit the equalizers do seem to make 1 watt sound like 2 (1000 watts from a jl sounds way louder than 1000 from an alpine or rockford or many other brands)
    mdsheely's Avatar
    Oct 2007
    Indianapolis,IN
    141
    It is Kole audio.
    I really didnt want to spend three hundred on the enclosure. I was really looking to just get one ten or twelve. I guess if the enclosure they build doesnt live up to my expecations, there are a couple other sources for enclosures.
    Any other ideas for subs and amp. 1=10'' quality sub. 1- 300watt rms amp.
    Thanks in advance.
    mdsheely's Avatar
    Oct 2007
    Indianapolis,IN
    141
    Also does anyone know if there are Preouts on my factory head unit. I have the six disc xm factory deck.
    THanks,
    Towncar's Avatar
    Towncar is offline CarAudio.com Veteran
    Dec 2005
    who knows
    4,359
    18 Post(s)
    Ditch the factory deck.. If you are content on keeping it, then get a jl clean sweep, or a decent line out converter. The cvt should do nicely behind the seat.
    Quote Originally Posted by Terranova View Post
    The gain is set around 750 right now. I need to get together with my buddy and plug his stethoscope in to set it to 1000.
    Quote Originally Posted by infamous_e46 View Post
    Start fcking one of the guys in the *** to make her jealous
    mdsheely's Avatar
    Oct 2007
    Indianapolis,IN
    141
    Thanks for the reply. I will check the line converter.
