Results 1 to 7 of 7
Reload Thread: not happy with adire box size suggestion for brahma 10" please help!!
    Feb 2003
    Brooklyn NY
    68
    Ok i called adire twice and both times they told me .75 gross. Im not happy with the output for a 340 dollar sub but i think this has to do with this ridiculous box size. also will there be a huge difference after the break in? I told them i would be sending it 600 watts, cause it wont take the 1800watts at 1 ohm.
    With my current amp rack i have space to make a box 8x22x25 which is a box volume of 1.812. what would be the best thing to do do with that space and 600 watts.
    If i was to build a new amp rack I could build a box 8x32x25 which would be a total box volume of 2.696. what would be the best thing to do with this space and 600 watts.
    Which box size would you think would be better for the sub? Would there be a huge difference in the output of the subwoofer? Could i do a ported box with the larger area? what would i tune it to, Ive never built a ported box, 3 sealed but no ported so i need alittle input. Any suggestions would be great. THanks Chris
    Oh i have a 2003 4runner its in the cargo area facing up at the ceiling. !!!
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    Make a ported box with the 2.7 cubes you have. Tune it in the mid 30 Hz area, 35 Hz should be good. With ported boxes, you theoretically get 2x the output with the same wattage (a 3dB gain)...so if you port it, it will sound at least twice as loud with the same wattage...
    jlaine's Avatar
    jlaine is offline Vaporware
    Apr 2002
    Morris, MN
    2,607
    Way too large of an encosure suggestion.
    The 10" does sound good ported though, just not in that size of a chamber.
    Box size isn't ridiculous really, perhaps you are expecting more out of a 10" than is normal?
    It's an ideal candidate for porting, if you want to go that route to utilize your power to the utmost.
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    :o
    Thought it was a 12"
    impulsebrklyn's Avatar
    impulsebrklyn is offline Member
    Feb 2003
    Brooklyn NY
    68
    then what would be a good size for an enclosure. I was running two idmax and i figure i would atleast get the same ouput when i was running only one. But the output isnt even close to when i was running one mtx 12" 6000 a few years ago?? I just get very low tight tight bass not much else. and the gain on my amp is at like 3/4 to even get that it doesnt disort till almost full gain. need some help chris
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    I'd say around 1.5 cubes ported...
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    .75 sound about right considering your only gonna be sending 600w....maybe larger....but not to much....
