Results 1 to 3 of 3
Reload Thread: Infinity Speaker wiring question
    Marksman's Avatar
    Marksman is offline Member
    Feb 2003
    WI
    37
    Icon30 Infinity Speaker wiring question
    I just took a closer look at my Infinity(Reference 3-way 6x9) speakers and noticed that it has three prongs for wiring. It looks like one negative and two positive posts. The second positive looks like it has a small crossover attached to it and it has another, blue, wire coming off of it. What are these for? When I installed them, I just plugged the wiring harness in and neg. to neg, pos. to pos. and I was done. Now I'm going to be adding an Amp to these speakers.
    So, what's the story with the third post? Should I be using it somehow?
    Thanks!
    -Marksman
    Quinn03's Avatar
    Quinn03 is offline Member
    Mar 2003
    NaDm.Net
    34
    65
    Icon14 special stuff
    from my view of the situation, its a used for signal stabalizing. I only say that because on an oscilliscope (o-scope is used to measure freq) you can plug a third cord into another channel on the front to stabilize the signal. basically for you it's used to help if you get distortion. u can ground that post to the neg side and equalize the speakers output. That's the best guess I can come up with.
    ActionJ-01-Z71's Avatar
    ActionJ-01-Z71 is offline Action Jackson
    Jan 2003
    TULSA
    42
    237
    14
    I have the Reference 6.5 comps. Mine also has a second postive. My manual says it is for the tweet. (Basically the tweet has 2+'s) This other + is so I can reduce the tweet -3dB. Could be the same for you. I say take a listen with one side hooked up, then swing it over to the other side and see if there is any change in sound.
    AJ
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    Alpine Type R 12 4ohm DVC
    Kicker XS-100 @ 2 ohms
    BOOMER!!!!!
