Results 1 to 5 of 5
Reload Thread: 10" sub recommendations for around .6 cu ft sealed?
    Gundam's Avatar
    Gundam is offline Junior Member
    Nov 2005
    Elk Grove, CA
    I currently have a 10" Image Dynamics ID sub powered with 250w at the moment and I'm dissapointed with the output. I have a fiberglass stealthbox with around .6 cu ft to work with and I need something that would work in a small sealed enclosure. My requirements:
    1. .6 ft^3
    2. 10"
    3. I have a mounting depth around 6" to work with
    Although I would like SQ, I'm willing to sacrifice it for SPL. I came from a pair of 12" earthquake magmas with 1200w, and the SQ of those were satisfactory for my needs. Of course I do not expect my setup now to match the output of my old system, I just want a bit more oomph. Although I would like to stick with my current amp ([email protected] or [email protected]) I'm willing to get another amp to properly power whatever sub you guys suggest. So power is not an issue, the size of the driver and enclosure requirements are.
    tapout's Avatar
    tapout is offline CarAudio.com Veteran
    Mar 2006
    Ga
    11,922
    Re: 10" sub recommendations for around .6 cu ft sealed?
    Kicker CVT
    tapout's Avatar
    Mar 2006
    Ga
    11,922
    although, the Idmax isnt the problem. Its the stealthbox.
    innsanes's Avatar
    innsanes is offline CarAudio.com Elite
    Sep 2006
    HB Cali
    1,377
    14 Post(s)
    I got an 10" Fi Q in a .6 cf stuffed with pollyfill and its **** LOUD!
    2016 e-Golf
    Dynaudio
    Sundown 1500D
    0/1 gauge setup
    15" IDMAX
    Aug 2007
    costa mesa, ca
    121
    bump.... I have the same issue. Any other recommendations? I currenlty have a CVR 10" and I am looking for a sub that will handle much more power but will be able to utilize the small space I have.
