Results 1 to 5 of 5
Reload Thread: How to make the doors hold comps.
    MaDroX420's Avatar
    MaDroX420 is offline CarAudio.com Elite
    Feb 2003
    Albany, La
    29
    516
    I have an f150 how do i go about making a set on comps fit in the doors. Do i need any special tools or kits?
    Dec 2001
    Kent State/Mentor Ohio
    868
    depending on depth you could make an MDF ring to give you 3/4 "
    or you can make a new kick panel
    MaDroX420's Avatar
    Feb 2003
    Albany, La
    29
    516
    The door holds 6x8s so how would i size the ring and what size comp. should i try and fit?
    Dec 2001
    868
    I'd probably go with 6 1/2s
    depending on the angle of the rear it should fit
    MaDroX420's Avatar
    Feb 2003
    Albany, La
    29
    516
    How could i tell before i buy them ? Just measure depth
