Results 1 to 2 of 2
Reload Thread: Calculating Sag and xmax
    Jlace's Avatar
    Jlace is offline Member
    Mar 2007
    Dallas
    82
    Do these specs tell you if I can upfire/downfire this sub?
    Qts: .406
    Qes: .45
    Qms: 3.615
    Fs: 36 Hz
    Re: 3.3
    Vas: 20.1 L
    Bl: 21 T*m
    SPL: 88.5 dB
    Sd: N/A cm^2
    Xmax: 15MM mm
    Voice Coil: 62 mm
    Displacement: .08 ft^3
    Outside Diameter: 10.5"
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
