Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: Single Assassin 8 Flat response SQ build
    Fast1one's Avatar
    Fast1one is offline CarAudio.com Veteran
    Apr 2006
    California
    4,628
    Assassins have been a reasonably sized boner for quite some time now. Ive owned four 8s for a while and have slowly sold/given/let borrow to others. Mine have been both sealed and ported with fantastic results.
    Unfortunately i wanted more, as the low end always left something to be desired for obvious reasons. Ive seen many threads about the 8s in sealed and ported boxes, and thats great and all. But I had yet to see someone try something exotic. Im talking about a complete flat response(or near it) from 20/25 HZ to somwhere around 60HZ.
    I am now down to my last surviving 8, which called a 1.3 cube vented enclosure tuned to 35 Hz its home for about a month. It was VERY loud for what it was off 300 watts. It sounded very good doing it as well. For this build, I sacrificed a little bit of that loudness for a flat response and pretty **** good low end for an 8, hell even a ten. Behold:
    What is it? Im sure some of you recognize it. Its just a simple transmission line (1/4 wave of the frequency) tuned to around 34 HZ with a catch. It has a compression chamber which is basically an enclosure to bring a little more low end out of the line. What does this mean? Anything in the 20s is now loud and clear and nearly flat just as i wanted from mid twenties to around 60.
    There is a catch however, the sub acts as if its almost free air, in which case I havve to be careful with what I play. It hasnt bottomed out yet (With about 300 watts), but I imagine it would if I played anything below lets say around 25HZ. But can it play it? Sure can, the mechanical limits are now preventing it, instead of the enclosure. O yeah, its a little big too (Around 2.7 cubes gross IIRC)
    So what have we learned? Well just what has been said for many years. Its all in the enclosure. Almost any descent quality sub can do whatever YOU want it to do. I now have my low end, flat response, a still very loud 8, and the accuracy and punchiness that TLs are famous for. I have also noticed that there is less strain on the amplifier, as my lights hardly dim at all (They didnt dim that much before anyway).
    Dont sit there, all the info for a TL can be found on the net so you can design one. You may need a little help, the guys at DIYaudio.com helped me a ton with this project and they can help you too. Also try http://www.t-linespeakers.org/
    And now for a couple more pics:
    Mock up:
    Sorry I dont have more pics....Enjoy.
    Edit: Keep in mind my trunk is not even sound deadened yet and tis easily the best setup ive ever had. Once I sound deaden, the SQ will be even better.
    References: Lax916, AcidicDreams , Altima98 , mr Tibbs, Majette, giantgloworm, mattmcss, riogigalo, mysilver02alty, Woc47, Hintzyboy, oglejust, APitBullT, foreman, jhubbell, tmcilroy, pioneerpimp, Dre_ATL
    Plus a ton more I never added, lol. If you are not on the list and you had a pleasant transaction with me, PM me!!!
    937DYTBOI's Avatar
    937DYTBOI is offline TL>you
    Mar 2005
    Dayton,Ohio
    33
    6,239
    Re: Single Assassin 8 Flat response SQ build
    nice man, good to see youve done your homework
    My Goal
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Have you experimented with stuffing the line?
    Fast1one's Avatar
    Apr 2006
    California
    4,628
    Cant say I have, I started out with a line tuned to 35 and looked OK, but it wasnt quite what I wanted. It was another member at DIYaudio that suggested I lower the CSA and add the compression chamber. Im starting to get then hang of it though. Im making one for home soon...
    Edit: Jim J, I thought about it but it was last minute and I didnt have any at hand. Now that the box is sealed I cant really do much except at the end. It sounds fine as is but I will never know Would that reduce the amount of cone movement?
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    31
    3,280
    How come no 45's in the corners of the port??
    Jon
    Fast1one's Avatar
    Apr 2006
    California
    4,628
    Quote Originally Posted by kickerlivinloud View Post
    Jon
    The member over at DIY suggested I didnt because it introduced more upper harmonic noise that I didnt want. Above 80HZ it has huge dips and peaks that would have been more noticeable. For this reason, I forgot to mention, it requires a steep Low pass at 50 HZ 24db/octave
    Justintoxicated's Avatar
    Justintoxicated is offline CarAudio.com Elite
    Jun 2005
    San Diego, CA
    885
    I wish it was always that simple, I'd love to have a small box for my titan that fits under the rear seat in transmition line, but I just don't think its possibe due to the odd shape. My single 10" Assassin is not that loud in it's sealed enclosure, in fact I can often hardly hear it over my fronts
    I think I just need a better sub.
    I'd love to hear that setup...
    Truck:
    Nissan Titan KC
    HU:
    Eclipse CD7200 MKII HU
    Speakers:
    DLS Iridium 6.2 Front Stage
    TC1000's,
    AMps:
    Arc Audio XXK 2100 for fronts, Diamond Audio D5 1200.1
    Other:
    Knukonceptz 0 & 4ga and all Speaker wire and Streetwires 0 ga Power/Ground Distro Block, 4.5 rolls 60 mil RAAMAT and Ensolite foam througbhout, Kintetik HC2000 The Big 3 + 0ga Gounding Kit.
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Probably not, but it sometimes makes the response less raggedy...if there's any weirdness with it.
    TL's aren't like bass reflex enclosures in that you can just crunch some numbers and forget about it, even with Martin King's awesome models there's still some wiggle room
  9. #9
    Fast1one's Avatar
    Apr 2006
    California
    4,628
    Quote Originally Posted by Justintoxicated View Post
    If you had the room that wouldnt be the problem. My highs distort from the lows slightly and thats with 110 per side with one 8 in a trunk car. A maxima at that, which is hard to get loud lol...
    If upgrading is the only option, go for it.
    Edit: JimJ, i am aware of that, which is why i am not calling myself an expert Best thing to do is to look at some pre-made plans and experiment yourself. They sure are fun...This enclosure was actually modeled with MJKs software...
  10. #10
    CJL's Avatar
    CJL
    CJL is offline CarAudio.com Veteran
    Mar 2006
    oZone
    3,844
    71 Post(s)
    Nice!
    REFS:
    eatank,mikescanlon,BoominBeast,Pistonsfan70,90accordman,bizflawless,Mazdakid,Boyle465,LiquidClen,dman4486,
    KickerSoItBump, SPY,1000101,infamous_e46
    Bought-Sold-Traded
  11. #11
    Immacomputer's Avatar
    Immacomputer is offline Cloud disappear
    Sep 2006
    Ocala/Oviedo, FL
    33
    4,672
    12 Post(s)
    Looks pretty nice! I'm going to be building some TLs soon. One will be for a 10" w6 clone for HT use and the other will be a 12" IDQ for home audio use. The w6 will probably be tapered with a 2:1 ratio and it won't have a compression chamber but I will have one on the IDQ and it will probably be tapered 2:1 as well if I need to save some wood. Space isn't an issue with the IDQ and it probably won't be in charge of anything over 50hz anyways so I may not need to taper it.
    Video 1
    I may make you feel but I can't make you think.
    Your sperm's in the gutter -- your love's in the sink.
    Video 2
  12. #12
    Fast1one's Avatar
    Apr 2006
    California
    4,628
    Quote Originally Posted by Immacomputer View Post
    I didnt taper this one for ease of design and build, it probably would have been better though as it would tame the nastiness above 80HZ...which is crossed over anyway but i can still hear it right now (Yet to upgrade my lowpass slope from 12db-24db)
    Good luck on the build man. Post it up on here I want to see results.
    BTW If anyone wants the design Ill give it to you free of charge. You can modify it too to ft your dimension constraints. I want to see someone try four in an SUV with around 1000 watts total...
  13. #13
    Volenti's Avatar
    Volenti is offline Senior VIP Member
    Feb 2006
    Australia
    271
    Nice build Fast1one, I'm glad it worked out well.
  14. #14
    Jun 2005
    San Diego, CA
    885
    Quote Originally Posted by Fast1one View Post
    Hmmm,
    Well theres a hump in my floor between the right and left side, with a total mounting depth of maybe 6.5 inches on the sides if using 3/4th inch MDF, and fabricating brackets to lift the rear seat. Without lifting the seat it might be possible to get 6 inches if the box is routed or using 1/2 inch MDF. The hump between the seats leaves only a couple inches of space in the center.
    I'm thinking it would be alot easier to just buy more power subs.
    I still want to hear one of these though! If I ever get a second vehicle I think I will probably go this route.
    Truck:
    Nissan Titan KC
    HU:
    Speakers:
    TC1000's,
    AMps:
    Other:
  15. #15
    Sep 2006
    Ocala/Oviedo, FL
    33
    4,672
    12 Post(s)
    I'll make sure to post a log in the enclosure construction area. I probably won't be able to begin this for a while but it will happen sometime.
    Video 1
    Video 2
