Results 1 to 3 of 3
Reload Thread: Amp Question
    RangerMan's Avatar
    RangerMan is offline Premium Member RangerMan is a Supporting Member of the forum!
    Jan 2002
    NC
    8,214
    Amp Question
    Okay, I'm just kinda playing around with stuff and I'm going to try to see how my Audiobahn alum10x sounds with my MTX 250x amp. I was just wondering if I could run the Audiobahn 10 (dual 6 ohm) at 3 ohms with my amp. I would have to bridge the amp but I don't know if it would overheat or what. The amp is like 100 x 1 bridged @ 4 ohms. Just wondering...
    L8er
    RM
    mykeys's Avatar
    mykeys is offline URABUS
    Nov 2001
    South Prairie, Wa.
    40
    1,057
    Aum 10
    It should be ok the impedance isn't too low I would worry if it was gonna be 2ohmd or less. The part I would be worried about is only getting 100 watts to the sub. If I remember correctly those need like 1000 watts.. I think you may wannaeither keep your gains very low so you don't cook your voice coil or look for a bigger amp all together..Digital would probably be your cheapest route.
    Mike
    RangerMan's Avatar
    Jan 2002
    NC
    8,214
    Oh... I have a JBL 1200.1 but I'm just messing around w/ this amp... The sub's max power is 1000 watts, it only needs like 105 watts to work it is 800 rms. Thanks for the help.
  1. factory HU to amp question
    By natem33 in forum General Discussion
    Last Post: 02-12-2002, 08:17 PM
  2. Amp question
    By adam182002 in forum Amplifiers
    Last Post: 02-09-2002, 10:34 PM
  3. Amp question
    By Adam182002 in forum Wiring, Electrical and Installation Help
    Last Post: 02-08-2002, 05:32 PM
  4. Xplod Amp Question
    By Unregistered in forum Amplifiers
    Last Post: 01-26-2002, 10:39 PM
  5. Amp question
    By Albokid in forum Amplifiers
    Last Post: 01-23-2002, 01:41 AM
