Results 1 to 3 of 3
Reload Thread: 2 ft^3, which sub? ported or sealed?
    KelBench400's Avatar
    KelBench400 is offline Member
    Sep 2002
    Whitehall, PA USA 18052
    59
    Ok guys,
    I have 2 ft^3 to work with PER sub after displacement. I'm looking at either two Brahma's, two XXX's, or two RE HC's. I would like to go ported if possible. Which would be the best sub to use in that space. Either 12" or 15". If I can't go ported, what should I go with sealed?
    I am going to power these with an Orion XTR Pro 2400, so figure about 1200 RMS per sub. I'm looking for anything between 60/40 and 40/60 SQ/SPL. Any other subs I should be looking at that can take 1200 RMS all day?
    Thanks for any suggestions.
    Wkerat's Avatar
    Wkerat is offline Member
    Sep 2002
    Scranton, PA
    120
    what is the difference of shared space? is it equivalent of the larger space for each sub? I always thought it was the same thing...
    kaosmoon's Avatar
    kaosmoon is offline Senior VIP Member
    May 2002
    Cedar Falls IA
    229
    As wierd as I feel about doing it the e12a might be a darn good bet for you. Very sq oriented speaker, just happens to get real loud too.
    out of the ones you mentioned I'd go with the Brahma though
    Ben
    get out of your box.
