Results 1 to 13 of 13
Reload Thread: Inverting 1 Sub only?
    da_bOm's Avatar
    da_bOm is offline Member
    Mar 2002
    British Columbia
    66
    i want to invert 1 sub only and leave the other one normal, my question is will i loose/gain anything or is it just for looks, also if i do should i switch the positive and negative wire? its a SVC if that helps
    Wonderbread's Avatar
    Wonderbread is offline Against Avatar Theft
    Feb 2002
    Vancouver BC
    33
    5,152
    it wont affect anything, except!
    if its a seperate chamber box, each sub will have different air spaces, that WILL affect teh sound of the woofers...
    if you are going to invert one sub.
    wire teh normal one normally (duh) and then wire the inverted one reversed...
    MSN - [email protected]
    Add me if you have any questions!
    Quote Originally Posted by PT Teal
    I woke up one morning and found a cop at my door telling me he found my car on fire in the middle of the desert.
    Quote Originally Posted by cleanerupper View Post
    Some people have told me that the chrome reflects sunlight, therefore the amp doesn't get as hot as others. Is this true?
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    Wonderbreads right, might need to make the inverted subs box a bit smaller - where in BC are you?
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    nismo's Avatar
    nismo is offline Senior VIP Member
    Aug 2002
    with the overpeck anti-fanclub
    309
    i HIGHLY doubt its gonna be enough to hear ANY difference. you might be able to measure fractions of a db difference on ouput, but nothing that youd be able to hear at all.
    eric
    WANG MOON PRODUCTIONS, inc.
    overpecker & audiomobile's biggests ANTI-fan
    CLASS 'D' AMPS ARE NOT DIGITAL!!!! YOU WILL GET FLAMED BY SOMEONE...EVEN IF ITS NOT ME.
    Feb 2002
    Vancouver BC
    33
    5,152
    not necessarily on total volume..
    if its sealed, the response curve changes...
    larger airspaces generally cause a few things to happen...
    lowers teh power handling of the drivers,
    produces a flatter response curve (less peaks than in an optimum airspace)
    Those are the main ones...
    and, depending on teh drivers, (btw, which ones ar they?) the displacements could ahve a huge effect on teh airspace...
    let us know and we can tell you how much you will need to compensate (eitehr with bracing or with poly fill (bracing or somethign like taht in teh inverted subs airspace may do better tho.
    nismo's Avatar
    Aug 2002
    309
    i honestly wouldnt worry about it at all. just b/c the box is ~ 10% bigger (assuming 1.5 cubes, and .15 sub displacement--no i didnt use a calc...but close enough ), doesnt mean that the mech powerhandling will go down 10% or anything along those lines.
    just b/c there's a difference on paper doesnt mean that there will be a difference in performance. with such a small change, there's no reason for concern.
    eric
    Feb 2002
    Vancouver BC
    33
    5,152
    BUT, depending on teh reduction of airspace, the response can cahnge fairly dramatically, no?
    nismo's Avatar
    Aug 2002
    309
    i wouldnt say dramatically...it does ever so slightly. if you look at the picture, you see a yellow plot, and a blue plot. both are of the adire shiva (12") sub. in the pic, the blue curve is the .707 alignment, and the yellow is a slightly higher 'q' alignment...at ~.73. i would be willing to wager money that you couldnt hear any difference in performance, and would likely not see much using tools either.
    eric
    *edit* btw, this is a 10% difference in box sizes
  9. #9
    nismo's Avatar
    Aug 2002
    309
    another thing i forgot to mention, is that unless you measure each and every driver you install, you arent gonna get the same alignment for a pair of subs, even if theyre identical, just b/c of manufacturing tolerances...they typically range from anywhere around 5% to about 10 or 15%
    eric
  10. #10
    Feb 2002
    Vancouver BC
    33
    5,152
    taht's for a shiva?
    what about something iwtha much higher structure displacement?
    ie. brahama, xxx, RF powers, anything with aton of magnet, etc?
    larger differences...
    i beg of you, at what point in the 'q' DOES it become noticeable?
  11. #11
    nismo's Avatar
    Aug 2002
    309
    just for comparison, i did the same setup with a pair of brahma 15's...the blue is still .707, and the yellow is still .73...both yellows are at 90% of the .707 box q...the 90% box on the brahma 15 figures that the difference in displacement is .27, although the brahma only displaces .15 ft3, but this would cover the fact that the cone is dished (and then a little extra)
    here is another pic of the response curve (keep in mind that the response should be CLOSER than it shows.
    as for when box q becomes noticable, im not totally sure, as im still learning...my guess is somewhere in the neighborhood of about .075 or .1 difference in box q...maybe a little less, maybe a little more...but probably not too far off.
    eric
  12. #12
    Feb 2002
    Vancouver BC
    33
    5,152
    hrm alwas good, to know, lol.
    sometimes, i like to start arguments just to elarn, lol.
  13. #13
    nismo's Avatar
    Aug 2002
    309
    you wouldnt believe how much ive learned from arguments (mostly watching them from dan vs. matt...but some of me doing it too). a lot of just having people question my thinking and having to back up my thoughts with things ive learned, and facts and other things ive picked up along the way.
    eric
