Results 1 to 4 of 4
Reload Thread: Amp for dual 2 ohm: 2 channel or mono
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,449
    1 Post(s)
    So I've been trying to decide how to wire my new Quart sub (dual 2) and I am going back and forth between bridging a 2 channel @ 4 ohm or running a mono class D @ 1 ohm. I know the answer is pretty simple: run the mono b/c of efficincy, etc. But I would like to have a 2 channel for the flexibility.
    The rating on the sub is 600 watts continuous and I have been looking to power it with either a Diamond D3 600.1 or a Diamond D5 600.2.
    Opinions with qualified experience appreciated!
    Thanks
    Last edited by FoxPro5; 08-26-2005 at 02:32 PM. Reason: I just realized that this might be more for the amp section. Moderators move as you please.
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    33
    37,876
    Re: Amp for dual 2 ohm: 2 channel or mono
    how does a 2 channel give you more flexability then a mono amp? unless you want the flexability of a hpf then i say get a mono amp.
    FoxPro5's Avatar
    Aug 2005
    3 octaves higher
    5,449
    1 Post(s)
    Quote Originally Posted by iceteebone
    Right. By using it in different applications in my system.
    iceteebone's Avatar
    Aug 2003
    Michigan
    33
    37,876
    Quote Originally Posted by FoxPro5
    if you are gonna use the amp in the future to run something other then subs i guess the 2-channel is the way to go.
  1. 2 ohm dvc sub to 2 ohm load mono
    By fbplaya02 in forum Wiring, Electrical and Installation Help
    Last Post: 08-17-2005, 01:35 AM
  2. 1000watts mono channel stable at 2 ohms rockford amp
    By timythea05 in forum Amplifiers
    Last Post: 10-12-2004, 04:14 AM
  3. 300 watt 2 channel amp, 1 ohm stable??
    By billy98sport in forum Amplifiers
    Last Post: 12-04-2003, 10:31 PM
  4. Series, Parallel, Stereo, Mono Basics 101
    By nrgy in forum General Discussion
    Last Post: 12-02-2002, 04:16 PM
