Results 1 to 8 of 8
Reload Thread: External Porting?
    Psyence's Avatar
    Psyence is offline Customized
    Aug 2005
    Canada
    43
    445
    External Porting?
    If a person is to make a box, but the port is outside he box, how do you factor all that in?
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    Re: External Porting?
    u only factor how much of the port is inside the box
    80
    kuijo's Avatar
    kuijo is offline CarAudio.com Veteran
    Mar 2005
    TX
    31
    2,681
    u just don't remove the port displacement from the volume of the box.
    Psyence's Avatar
    Aug 2005
    Canada
    43
    445
    So in other words, the port on the outside of the box does not alter the performance of the woofer... as long as it is the correct size inside the box?
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    You could have a box in your trunk and run the port up to your head if you wanted to. The ports do not have to be in the box.
    jujumantb's Avatar
    jujumantb is offline Duke of Earl
    Jun 2004
    Madison, Wi
    32
    3,417
    Quote Originally Posted by HAVINGFUN
    It *should* be on the same plane though, helps with cancellation.
    DFW40's Avatar
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    true
    kuijo's Avatar
    Mar 2005
    TX
    31
    2,681
    Quote Originally Posted by Psyence
    not just the correct size INSIDE the box. the entire length of the tube must be the correct size. not like you can put the right port in the box then extend it and expect to get the same tuning.
  1. Question About External Amp
    By Harrison486 in forum Speakers
    Last Post: 08-03-2005, 02:16 AM
  2. Porting question?
    By getsumbaby in forum Subwoofers
    Last Post: 04-15-2004, 04:20 PM
  3. slot porting vs conventional
    By rambassmachine in forum Enclosure Design & Construction Help
    Last Post: 08-12-2003, 01:13 AM
  4. external amp v. deck
    By joshpoints in forum Amplifiers
    Last Post: 06-16-2003, 09:40 PM
  5. question about amp with external fuse
    By treefitty in forum Wiring, Electrical and Installation Help
    Last Post: 01-02-2003, 07:40 AM
