Results 1 to 13 of 13
Reload Thread: Odd Electronic Chain Failure: Blown Mofo12
    generalGOTCHA's Avatar
    generalGOTCHA is offline Boyz in the Hood (EZE )
    Oct 2004
    San Antonio TX
    35
    487
    equipment:
    Hifonics Brutus 1500d
    Mofo12 by PA in 2.4^3 (manufact specs)
    pioneer 7700 HU
    scorsche 4guage from Hot to amp
    6" ground:
    4ft 3" 8guage from amp to subwoofer:
    I wired pos/neg to each coil , and bridged the coils externally to the enclosure:
    I hope to soon post pics of my install .. it was clean ,neat , sharp , hid , and well planned for performance as well as cosmetics.
    I used a nitrous switch, too toggle on and off my amps , one toggle per amp :
    Problem:
    Keeping the amp on almost full gain ((yeah I know brutus can put out a **** load)).
    The box was 3/4" MDF with inside laid fiberglass to coat everything including seems of the enclosure.
    I was absolutely astonished at how hard one ****ing subwoofer hit in my 1994 XLE v6 camry compared to two Kicker Comp Vr's of my cousins.. so slamming power into the ole mofo for about one month hitting clean and HARD ! Out of the clear blue the mofo12 began to distort .. I was mind set that my enclosure was rattling loose and not the sub being faulty. So I built a whole new enclosure for it and changed the tuning while I was at it. After installing.. I burned the VC's in slowly like always @1ohm .. and I got up to 18 of 62 on the volume ((mind you keeping it on just 1 could be heard inside a home)) and it distorted like before.
    I was pist, I checked gains, bypassed the eq , tried a different amp , and swapped the sub from the box with a temp sub which hit clean.. so frustrated I inspected the mofo and found nothing ,nor a stinch. I hooked it back up and said ****it.. I jammed her till she died which wasnt long after.
    Soon after the smoke cleared my trunk.. knowing the fate of the woofer .. I took the mofo's non-magnetic bolts out, deconstructed the magnets from the support frame and there was the mechanical thermal weekness. ALL the wire around the thin aluminum bobbin was burned crisp and smelled like a burned resistor from a project gone bad . Soon after .. I boxed the mofo back up .. and I supplimented it with another subwoofer. I turned on the hifonics and about 15 seconds after all 3 of my amps shutoff. It burned the 100a fuse from the main line, when I tried it on each branch of the distro same problem occurred only for the brutus.
    Oh btw.. if this helps ! Voice coils look emaculate , cone was froze up untill I un-wound the bobbin. ODD as it is .. the Hifonics AMP on the last bad fuse blowing occurance set off like fireworks inside the amplifier.
    The fuses werent touched, still the same fuses in the amp that arrived from Ike sounds. So , Im wondering if the amp went faulty , maybe overpowered the subwoofer in some way and both dettered slowly. Or , the mofo's fate caused a negative reaction to the electronics in the amp.
    I dont have an explination so I hope one of you do. Either way im looking to send them both back and have them replaced free of charge .
    for those who read this.. I posted a second post on considering diff subwoofer , and I have questions some of the pro's here can maybe help me on.
    zachzchw's Avatar
    zachzchw is offline CarAudio.com Veteran
    Dec 2004
    ohio
    6,640
    Re: Odd Electronic Chain Failure: Blown Mofo12
    Quote Originally Posted by generalGOTCHA
    Keeping the amp on almost full gain .
    Thatll do it right there.
    SPL140.2's Avatar
    SPL140.2 is offline Team DefJ
    Mar 2005
    NY
    40
    5,295
    5 Post(s)
    clipping isnt a good thing
    Team DefJ
    http://www.myspace.com/loudinspl
    WWW.JAGGEDEDGEKUSTUMVINYL.NET
    REF'S:
    VOSSCHS-NJACK2AF-WOWIMZZ-DECIPHA-AZNGOTSKILLS-TRAFFICJAMZ-MILLIONARE1-QTRHORSE
    TSL13505-DJL(2)-KNOTSLCK-KYLEC-KNUKONCEPTZ(4)-KEIFERSRACING-TEAM H&K
    ANDRIZZLE-95BLACKGA(3)-MAX_POWER-POUNDINDAK69-DVRMSTRNG-BLONG131-PIMPDADDYQ
    NOPH33RACING-KPR10IS-XTREMEBASSJUNKY-ENVEE 02-J3M CONCEPTS(3)
    CONNERSDAD19(6)-SNOOPDAN(2)-SUNDOWNZ(3)-MRWIGGLEZDJ-ASTYL-BLAZIN_JASON-GOT_FOCUS?
    SPLCHOICE-DBDESIGNSELITE-JEREMY M-GLADIATOR_JAI-QTIPEXTRA(2)-BJFISH11(2)
    MEMPHISFLEX-CHA0-BBALL09124-BUCKYBOY-CURTIS1993-ICPURPLEPPLALOT-BMBORSK-P3BUMPIN-DEFJ165
    Nov 2004
    TriState Area
    32
    3,888
    23
    you didn't set your gains properly did you?
    myspace
    1993 Volvo 960 Luxury Sedan
    Refs: Sake Pho Sho, Silentheaven389, macmood, iamslain, lemans23, desertheat (3), monte_carlo97 (7).
    Nov 2004
    TriState Area
    32
    3,888
    23
    You need to set the voltage on your Amp to 34.6 volts. Not 947562757t5017826-012
    myspace
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    your amp clipped
    your sub broke.
    end.
    this is what happens if you dont set your freggin gain.
    akizzle's Avatar
    akizzle is offline yezzzzzzzzzzzzzzzzzir
    Apr 2005
    htown, tx
    28
    309
    hfas;kdufyhas;kdhas;fjhg nm i just found it
    Nov 2004
    TriState Area
    32
    3,888
    23
    setting your gains is SQRT(POWERxRESISTENCE).
    34.6v is what your sub can handle daily So i advise you to set it to 34.6v and keep it there buddy.
    oh yeah, use a DMM and set it to AC current and measure through your speaker terminals on the amp. POS to POS and NEG to NEG.
    myspace
  9. #9
    RCwhat's Avatar
    RCwhat is offline CarAudio.com Elite
    Dec 2004
    Se, MA
    584
    well, when you burned up the voice coil from clipping the hell out of the signal, you obviously caused a short in it which basically shorted the terminals on the amp as well, great job focker!!!!! hopefully you learned your lesson.
  10. #10
    Oct 2004
    San Antonio TX
    35
    487
    Actually , yah I didnt set the gain... I did it by ear abusing the subwoofer for more output power.
    No voice coil burnt , they are PERFECTLY FINE ! its inside the magnet , the bobbin I beleive it is called, where it hovers in the center core of the magnet ((I took the sub apart and examined it)) . The wire coiled around that was burn. the voice coils woven through the spider were fine !
  11. #11
    PowerNaudio's Avatar
    PowerNaudio is offline the power of audio
    May 2005
    killeen, TX
    1,876
    the voice coil would be that bobbin that has a long copper wire wraped around it!.
    AIM:powernaudio,yahoo:powernaudio,email address: powernaudio at gmail.com contact me if you need any help.
    Portafolio
    builds
    more builds
    saturn l300 build
    videos
    References:Mr.Loki,dubbinjet,trucktoy,fancynapkin, netherland,Datdudedru,hockey1playa33,
    donbon86,PhatTonyDeMar,Saywhat?,vosschs,ChuckKlock er,budlightman361,baseballer1100,elslug,
    bdogg321,projectpat06,eatank,BodegaBay,playboyclic ,cbrrocketrdr,iwanturmags,pboulos,DaBeholder,
    bholtmeier,beatthis27,OldManTod,MTXman,Gianotti.
  12. #12
    RandyJ's Avatar
    RandyJ is offline CarAudio.com Veteran
    Nov 2004
    USA
    4,523
    tis a wanna be beezlebub/profilepower or whatever his name was.
  13. #13
    Nov 2004
    TriState Area
    32
    3,888
    23
    Quote Originally Posted by N00blet
    lol wah?
    anyays, profilepower is under the new name Stroker Boy or whatever.
    myspace
  1. Odd situation - really bothering me
    By mp3master in forum Wiring, Electrical and Installation Help
    Last Post: 12-23-2002, 05:21 PM
  2. MY amp BLOWN??
    By JLAudioEXTREME in forum Wiring, Electrical and Installation Help
    Last Post: 10-08-2002, 04:04 AM
  3. blown HX2s
    By geonn in forum General Discussion
    Last Post: 08-05-2002, 12:57 AM
  4. Do i need a electronic crossover????
    By nofriends46 in forum Wiring, Electrical and Installation Help
    Last Post: 06-03-2002, 06:54 PM
