+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: I feel like I might blow my Sundown Audio 12
    Cassix's Avatar
    Cassix is offline Member
    Mar 2017
    Seattle,WA
    65
    26 Post(s)
    So I just recently built my own box for a Sundown Audio sa 12 D2. It's 2.3 cubic feet port tuned to 35hz. I also recently went from using to sa 12s to just one because I didn't have the amp powerful enough to push two of them so while I'm waiting for my amp to come I am just running the one in the Box I built and I have it powered by a Phoenix Gold SX 1200.1. Its rated at 1200 watts at 1 ohm 800 watts RMS. Anyway every time I turn my sub up for a while I could smell it burning first it was a voice coils now it just smells like something's burning and it seems like after I play it for a little bit it doesn't hit as hard as it used to until cools down again. I probably already caused irreparable damage. The only thing that I could think of which from what I hear is almost impossible to do is overpower it. So I clamped my Phoenix Gold amp and it said it was putting out 1293 watts. I checked it 3 times and it came up the same way every time. I know the subs can handle a lot of power but it's only rated for 750 can it take almost 1300 Watts constantly?
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,926
    15
    36 Post(s)
    4030 Post(s)
    Re: I feel like I might blow my Sundown Audio 12
    SA SERIES
    You're putting 1200W into a 750W rated sub and asking us why it smells like it is burning. Step back and think about this for a bit.
    Also inb4 "clipping" or "clean" or "my buddy runs 3X rated power to Sundown".
  3. Thanks audiobaun thanked for this post
  4. #3
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    lol it's clipping. That amp isn't doing 500 constantly. You may get 1k for a few seconds here and there.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  5. Likes Water Bear, Hertz Mafia liked this post
  6. #4
    hispls's Avatar
    Sep 2009
    9,926
    15
    36 Post(s)
    4030 Post(s)
    Quote Originally Posted by LosIsATool View Post
    If his sub is burning he is most certainly giving it more than 500W for more than a few seconds.
    Do you people even understand what clipping is or how AC power is measured?
    Shaded area = your power averaged over time, now start making that waveform square at the same peak to peak voltage and even at perfectly square wave the shaded area is only about 40% more than the sine wave pictured.
    This graphic explains the terms "peak" and "RMS" as they should be used in regards to alternating current.
  7. #5
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    2,034
    40 Post(s)
    1293 Post(s)
    Quote Originally Posted by hispls View Post
    A single SA 12 can handle a clean signal from a 1200watt amp on music all day long. Only way your going to kill that woofer from that amp is a dirty signal and playing 100hz tones so the woofer can't cool itself.
  8. #6
    hispls's Avatar
    Sep 2009
    9,926
    15
    36 Post(s)
    4030 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    Suit yourself.
    Forget I said anything, OP, carry on, you'll be fine as long as things are "clean".
  9. #7
    Water Bear's Avatar
    Water Bear is online now Member
    Oct 2017
    Atlanta, GA
    85
    68 Post(s)
    Super late reply to this thread, but I'm running 1200+ watts on an SA-12 no problems for months now...if you're burning yours up, you're almost certainly clipping it.
    Polk DB 6.5 components and coaxials, Alpine MRV M1200 (1200x1 @ 2) and MRX F30 (50x4 @ 4) amplifiers, Pioneer double din HU, Sundown SA-12 in ported enclosure (built to spec).
  10. #8
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,315
    8 Post(s)
    2087 Post(s)
    What was the impedance when you clamped the amp?
  11. #9
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    5,881
    18
    29 Post(s)
    2366 Post(s)
    either way just lower gain
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit I’ll sleep with you if you do that for me..
    i TiPe LiKe MeNtAlL cHaLeNgE fReE.
  12. #10
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,789
    232 Post(s)
    7683 Post(s)
    first off it was dumb to just use one of them in the first place, even if underpowered, more cone area will get you louder.
    2nd, 100% clipping.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  13. #11
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    13,399
    68 Post(s)
    2 Thread(s)
    5545 Post(s)
    You have to understand reactive loudspeakers and loading I understand what you mean but it's alot more complicated than that.
    i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
  14. #12
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,489
    804 Post(s)
    While I agree that the sub is likely clipping to he'll and back. You maybe playing too low of frequencies for that box. Anything under 30hz is going to strain the suspension of the woofer. Go to low and the sub may unload and actually see constant rms without the coil moving properly to cool. This is unlikely since you would prolly be bottoming out the sub before heating up the coil that much
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam
    Memphis viv component run active
    2 alpine pdr-m65
    1 alpine pdr-f50
    2 jl 13tw5-3 in subthump understeat box
+ Reply to Thread
