Results 1 to 6 of 6
Reload Thread: Dual sub box only playing one sub
    PNILLZ's Avatar
    PNILLZ is offline Junior Member
    Sep 2013
    New Jersey
    Feedback Score
    3 Post(s)
    Icon13 Dual sub box only playing one sub
    My sub box only plays one sub when I connect them both the amp will go into protect mode. I checked all the connections they were fine, and my left sub plays fine. When I connect the right one by itself, it doesn't play is it blown? Is it time for a new setup? I've had this one for about 2.5 years
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Back to ATL
    13,028
    Feedback Score
    5 (100%)
    33 Post(s)
    3126 Post(s)
    Re: Dual sub box only playing one sub
    wrong section this is the classifieds
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,238
    Feedback Score
    36 (100%)
    25 Post(s)
    2150 Post(s)
    Quote Originally Posted by PNILLZ View Post
    If you know what Coil configuration your subs are, you can disconnect from the source/amp, and use a DMM to check the coils,to find out if its blown or not.Very easy to do.You can YOU TUBE it up, and watch a tutorial on how to do it,easier than explaining it to you
    2)American Bass VFL Mini Hybrid 4480.[email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
    audiobaun's Avatar
    Jun 2011
    Tx
    9,238
    Feedback Score
    36 (100%)
    25 Post(s)
    2150 Post(s)
    Quote Originally Posted by slo_ride View Post
    lol..:d
    2)American Bass VFL Mini Hybrid [email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    Feedback Score
    110 (100%)
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    bad sub , bad op , just sayin !
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  6. Likes audiobaun liked this post
  7. #6
    UsAmpsFreak's Avatar
    UsAmpsFreak is offline Senior VIP Member
    Oct 2013
    North Dakota
    308
    Feedback Score
    124 Post(s)
    I would check the impedance on all of your voice coils to make sure you don't have one out. That would give you a whacky impedance and could cause the amp to go into protect. Otherwise you may just have a badly blown woofer that when connected is sending a dead short to ground to the amp which will absolutely freak it out.
  1. dual slot port box design for one sub.
    By subzero in forum Enclosure Design & Construction Help
    Last Post: 08-15-2012, 04:42 PM
  2. 2 subs in 1 box, only powering 1 sub for now...
    By c_hayhurst in forum Enclosure Design & Construction Help
    Last Post: 04-30-2007, 06:38 PM
  3. Piano black glossy sub box anyone made one??
    By protonman in forum Enclosure Design & Construction Help
    Last Post: 07-13-2006, 06:44 PM
  4. Can someone design me a sub box like this one?
    By AzGrower in forum Enclosure Design & Construction Help
    Last Post: 06-09-2005, 02:16 PM
  5. Replies: 11
    Last Post: 01-07-2005, 05:58 PM
Tags for this Thread
