Results 1 to 11 of 11
Reload Thread: 12’’ Sundown Audio Nightshade v1 with Aluminum Pole Plug
    cman0655555's Avatar
    cman0655555 is offline CarAudio.com Elite
    Jan 2007
    Carlisle, KY
    553
    14
    Feedback Score
    3 (100%)
    Nightshade 12" Subwoofer
    If you want a loud subwoofer to use both daily and in the SPL lanes then look no further than the Sundown Audio Nightshade. Many Sundown Audio customers are already using Nightshade woofers to achieve SPL levels in excess of 150 dB on music in their vehicles! *
    The Nightshades feature strong paper composite cones with an additional stiffening disc located behind the thick poly dust caps. The tinsel leads are tied down to the spiders so you never have to worry about the leads slapping or popping against the cone and spider at high excursion levels!
    The Nightshade woofers are assembled in the USA with only the best high strength adhesives and materials.
    * Please use caution as excessive SPL levels such as those achievable with the Nightshade subwoofer can cause permanent hearing damage!
    FEATURES AND SPECIFICATIONS:
    • Dual 2-ohm or Dual 1-ohm Voice Coils Available
    • 3" Diameter 8-layer flat-wound Aluminum Wire Coil
    • High Temperature Aluminum Voice Coil Former
    • 1500-Watts RMS Power Handling
    • Over 2 inches peak to peak excursion
    • Wide, triple-layer foam surrounds for high excursion
    • Extremely strong paper cones w/ stiffening disc
    • Thick poly dust caps
    • Cast Aluminum 12-spoke basket with cooling vents
    • Triple Stacked 1" x 9" magnet slugs for high motor strength
    • MSRP - $629 USD T/S D1 **:
    RMS: 1500
    Z: 2 ohms
    Re: 1.44 ohms
    Fs: 43 Hz
    Qms: 6.83
    Qes: 0.43
    Qts: 0.40
    VAS: 11.7 L
    BL: 17.6 NA T/S D2 **:
    RMS: 1500
    Z: 4 ohms
    Re: 2.9 ohms
    Fs: 41 Hz
    Qms: 9.36
    Qes: 0.46
    Qts: 0.44
    VAS: 11.7 L
    BL: 22.8 NA
    ** T/S Specifications measured with coils in series
    Enclosure Suggestions :
    1.5 - 2.25 ft^3 Ported Tuned to 30-40 Hz
    DO NOT USE A SEALED BOX
    Mounting Specifications :
    Mounting Depth = 8.25"
    Overall OD with Gasket = 12.5"
    Cut-Out Diameter = 10 15/16"
    Sub Displacement = 0.18 ft^3
    10/10 function
    7/10 cosmetic
    Was bought directly from sundown and I am the only owner. It is a refurbished motor so its not perfect cosmetically but nothing is physically wrong with it. It does have a few nicks in the surround from where it was taken in and out of boxes for spl tesing. Will come with a gasket although there isn’t one in the pictures. I wanted to show the blemishes so you know what you are getting. Also the basket has been painted and there are a few chips in the black paint. Once again nothing that would hinder the performance. Ive tried to get pictures of all the imperfections but if there is something you want to see in more detail let me know and I will get it. I took the pics with my phone but can get better pictures with my camera if desired. The sub was never abused and honestly I don’t beat on it hard daily at all, only time it was pushed hard was during competition. The only power this thing has seen is my single sundown [email protected] I measured the true rms power I was getting out of my setup and it was 600-700 watts. It never got stinky and as you can see in the pics the coil is perfect till this day. The only reason for selling is that I am looking to downgrade to something smaller that weighs less and will suit me better for my daily needs. I am calling it quits on competing for now so I don’t need this type of sub.
    225+actual shipping obo. If local would be willing to meet up for cheaper. Also willing to meet halfway if less than a few hours of travel or bring it to you for a small fee.
    Only trades I am looking for is a 10’’ or 12’’ FI Q, Sundown Z Series or similar SQL style sub
    Dual 2 only. No 15s or 18s have no use and can’t fit them.
    Will ship fedex or usps your choice. To many subs broken by our local ups site. If local would be willing to meet up for cheaper. Also willing to meet halfway if less than a few hours of travel or bring it to you for a small fee.
    2005 Nissan Sentra SE-R Spec V
    Team Carlisle Acoustics
    Team Sundown Audio
    Team Xstatic Batcap
    2009 MECA DB1 World Champion
    2009 MECA DB1 Undefeated Season
    2009 MECA DB1 KY State Record
    2009 MECA S1 4th place
    2008 MECA S1 3rd place [email protected]
    2008 MECA DB1 4th place 124.4
    2008 MECA e2 DB points champion
    2008 MECA DB1 KY State Record
    2007 MECA AS1 World Champion
    2007 MECA AS1 Points Champion
    2007 MECA AS1 Ky State Record
    mossberg385t's Avatar
    mossberg385t is offline Love Train
    May 2009
    Sarasota, FL
    2,291
    Feedback Score
    14 (100%)
    4 Post(s)
    Re: 12’’ Sundown Audio Nightshade v1 with Aluminum Pole Plug
    LOL 1500 rms... GLWS sir.
    If you reconed this with a copper coil it would make a decent SQ sub, Zs are a nightshade motor with a copper shorting ring and a copper coil
    Quote Originally Posted by CarAudio.com Admin View Post
    Please send your tithes of 10% to my paypal. Thou shall worship thy goob.
    IA 40.1, Nakamichi PA350, Arc audio 6.5s 2 way active (1986 Alphasonik x-over) Audio Control three.1, Kenwood KDC-X592, TREO SSX based 18: 8 layer flat wound copper coil w/ dual SS former, 3 medium nomex spiders built by SPLaudio and repaired by myself and Harshaw for optimal sexiness and performance.
    team Dbeez MECA as3 db3
    ☞2218☜ βθπ βν
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,428
    Feedback Score
    19 (100%)
    323 Post(s)
    Quote Originally Posted by mossberg385t View Post
    then why does the z have a double stacked and nightshade has a triple stacked motor? jacob has came online several times to show the differences between the 2 woofers. and this woofer laughs at 1500w, i will be putting a 15 nightshade on about 2700w here very soon
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
    lowriderram_95's Avatar
    lowriderram_95 is offline VW Surgeon
    Jun 2007
    Little Rock, AR
    28
    1,658
    Feedback Score
    1 Post(s)
    34 Post(s)
    I had an 18 on 4500 for about 6 months, clipped it for music classes and the tinsels fried....
    (b):hoxie08, dacheatham, Mr.Foca, RetroAudioInc, pro-rabbit (t):dave_damage, j.clark90, tubermaguber
    RE XXX v1 10
    SQ2200.1
    AQ120.4
    SQ200.2
    infamous_e46's Avatar
    infamous_e46 is offline hArRy_DaNgLeRs
    Jul 2008
    California
    26,048
    Feedback Score
    46 (100%)
    1026 Post(s)
    Quote Originally Posted by sacsking916 View Post
    fuqqing groupie
    Quote Originally Posted by RyanM923 View Post
    Damn, look at that midget ***...love me a midget ***. 3 foot 4 standing up, 3 foot 6 sitting down.
    Quote Originally Posted by michaellane View Post
    don dont come in here ruining my thread. i hate you and jose
    www.alphadamp.com
    Got Mad Feedback Son http://www.caraudio.com/forums/buyer-seller-feedback/364675-infamous_e46s-feedback-thread.html#post5697823
    Apr 2009
    6,428
    Feedback Score
    19 (100%)
    323 Post(s)
    Quote Originally Posted by eL_wEEnIe View Post
    fuqqing groupie
    your just jelly i got it before you did
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Jul 2008
    California
    26,048
    Feedback Score
    46 (100%)
    1026 Post(s)
    didnt want it but coulda got it if i wanted it thomas my girl homie
    www.alphadamp.com
    Apr 2009
    6,428
    Feedback Score
    19 (100%)
    323 Post(s)
    well thomas is my bitch dawg
    and i aint no groupie, and you know i shouldve won the more mexican poll on FB between us.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
  9. #9
    Jan 2007
    Carlisle, KY
    553
    14
    Feedback Score
    3 (100%)
    Pending Sale!
    Team Sundown Audio
    Team Xstatic Batcap
  10. #10
    chris the man's Avatar
    chris the man is offline Senior VIP Member
    Oct 2010
    co springs
    155
    Feedback Score
    2 (100%)
    3 Post(s)
    ill buy this beast
  11. #11
    Jan 2007
    Carlisle, KY
    553
    14
    Feedback Score
    3 (100%)
    Sold!
    Team Sundown Audio
    Team Xstatic Batcap
