+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Reload Thread: CDC351's DC Enclosure
  1. #31
    -BenBen-'s Avatar
    -BenBen- is offline TEAM FI
    Jun 2011
    Down South
    669
    14 Post(s)
    Re: CDC351's DC Enclosure
    I love deep low bass..and i listen to alot of slowed music so i figure its a good medium so i can play regular music still also
    Quote Originally Posted by pro-rabbit View Post
    Is there a reason you are set on that tuning? Do you know if that is what works best for your application and goals?
    Loud with what you have will be relativity easy.
    Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
    Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
    ***Current Setup***
    2006 Pontiac G6 Sedan
    Pioneer avh-p4300 Head Unit
    FI Sp4 15 (D1.27 ohm)
    3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
    Sundown Audio Saz 3000D
  2. #32
    cdc351jeferson's Avatar
    cdc351jeferson is offline Premium Member cdc351jeferson is a Supporting Member of the forum!
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    Quote Originally Posted by benbenondatrack View Post
    goal is loud as hell ground pounder, sub forward port driver side.. aero port tuned to 33.. getting a vfl 500.1 amp
    are you gonna order some recones as well with the vfl 500 for your xfls?
    headunit : Sony xab-601bt
    fronts: infinity kappa 60.9's
    subs: 2x dc 12" xls
    box : 3cuft net 33hz ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
    sub amp: AQ3500.1
    others: Mechman 240amp alt, 3 xs3400batts , all 1/0 knukoncepts kollosus flex, stinger deadener
    REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
  3. #33
    -BenBen-'s Avatar
    Jun 2011
    Down South
    669
    14 Post(s)
    Mine still are not broken in, but i was thinking about orderin some recones just cause the top of them dont look perfect. but i may not. Im sick of this ap 1800..not enough power man
    Quote Originally Posted by cdc351jeferson View Post
    ***Current Setup***
  4. #34
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    well if you plan on putting 6800+rms on those 2 xlfs rated at 1000watts rms each be prepared for lots of recones
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
  5. #35
    -BenBen-'s Avatar
    Jun 2011
    Down South
    669
    14 Post(s)
    i was going to maybe run at 4 ohm.. i will maybe upgrade to diff subs later, but i want to put maybe 3k to em
    ***Current Setup***
+ Reply to Thread
  1. DC Lv5 18" Enclosure
    By c0smo kram3r in forum Enclosure Design & Construction Help
    Last Post: 08-31-2010, 08:29 PM
  2. enclosure specs for a 15 inch DC level 4xl
    By mendezm9 in forum General Discussion
    Last Post: 05-03-2010, 10:45 PM
  3. Enclosure build for Old_Gregs 2 12" dc lvl 3's
    By Twisted_0912 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 10-08-2009, 07:35 PM
  4. Enclosure Build For MmatsDude's DC lvl 5 18
    Last Post: 03-12-2009, 07:14 PM
