+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 35
Reload Thread: CDC351's DC Enclosure
  1. #16
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,099
    351 Post(s)
    Re: CDC351's DC Enclosure
    Quote Originally Posted by Kangaroux View Post
    Easier to carpet...gives a place to tuck in the carpet
    Depends on how you carpet. It is actually a little harder to hide the seem if you are using the correct carpet.
  2. #17
    double 07's Avatar
    double 07 is offline Supporting Vendor double 07 is a Supporting Member of the forum!
    double 07 is a Supporting Vendor of the forum!
    Nov 2011
    Etowah, TN
    1,913
    13
    286 Post(s)
    Quote Originally Posted by knotdrummer88 View Post
    why did you leave the extra 1/4 or 1/8" on either end of the box?
    I like the look, creates sorta handles on enclosure and it helps with carpeting...It also works great for doing a separate secondary carpet color on the recessed sides as well......
    It's the FINAL COUNTDOWN!!!!!!!
  3. #18
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,099
    351 Post(s)
    Quote Originally Posted by double 07 View Post
    Indeed! Also makes wrapping with vinyl much easier.
  4. Thanks double 07 thanked for this post
    Likes double 07 liked this post
  5. #19
    knotdrummer88's Avatar
    knotdrummer88 is offline CarAudio.com Elite
    Jan 2012
    Toledo, OH
    736
    4 Post(s)
    sweet, maybe ill try that on my next box build. thanks man
    I look for a girl with lowered standards, and possibly a vision problem. Depth perception and size awareness problems are a definite must. Also must like river-dancing and hideous, irreversible burn scars.
    What can I say, Im an old fashioned kind of guy.
  6. #20
    double 07's Avatar
    Nov 2011
    Etowah, TN
    1,913
    13
    286 Post(s)
    I had access to a PONTIAC today......I got some awesome new dims for PONTIAC BASS HEADS..........
  7. #21
    cdc351jeferson's Avatar
    cdc351jeferson is offline Premium Member cdc351jeferson is a Supporting Member of the forum!
    Jul 2012
    austin tx
    1,619
    12 Post(s)
    you gots pm and email! lol
    headunit : Sony xab-601bt
    fronts: infinity kappa 60.9's
    subs:
    box : ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
    sub amp:
    others: Mechman 240amp alt (for sale)
    REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
  8. #22
    -BenBen-'s Avatar
    -BenBen- is offline TEAM FI
    Jun 2011
    Down South
    671
    14 Post(s)
    g6? and what did you messure..i have about 6 cu gross firing forward with seats down. using most of the trunk
    Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
    Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
    ***Current Setup***
    2006 Pontiac G6 Sedan
    Pioneer avh-p4300 Head Unit
    FI Sp4 15 (D1.27 ohm)
    3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
    Sundown Audio Saz 3000D
  9. #23
    double 07's Avatar
    Nov 2011
    Etowah, TN
    1,913
    13
    286 Post(s)
    You could get that much if you needed it but there wouldn't be much room left for batteries, amps or anything else......I was just after a larger enclosure to NET more port area not so much for more NET CF......My guys Pontiac build is with DC subs....All we need is 3 cubes net with a port big enough for a toddler to crawl into...LOL
  10. #24
    -BenBen-'s Avatar
    Jun 2011
    Down South
    671
    14 Post(s)
    I need a box for 2 xfl 12s to get as loud as possible and low.. tune to around 33 hz? so i may need alot of the space. and put batt. in spare tire spot. then mound amp on the back seat?
    ***Current Setup***
  11. #25
    double 07's Avatar
    Nov 2011
    Etowah, TN
    1,913
    13
    286 Post(s)
    I thought you already had a 6 cube gross enclosure in it already......A box that size should have easily netted you 4 cubes with huge port area....That's all a pair of XFLs need.......
  12. #26
    Jul 2012
    austin tx
    1,619
    12 Post(s)
    so what your saying is you can make me a box to make the dc's stupid loud :P hehe im off work in under 30 mins ill call kevin im sure he will fill me in on the details
    subs:
    sub amp:
  13. #27
    -BenBen-'s Avatar
    Jun 2011
    Down South
    671
    14 Post(s)
    it ended up being 3.5 -3.75 after everything. i need 5 cu
    ***Current Setup***
  14. #28
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,099
    351 Post(s)
    Quote Originally Posted by benbenondatrack View Post
    You don't have to have 5ft3 net, it all depends on the design and goals.
  15. #29
    -BenBen-'s Avatar
    Jun 2011
    Down South
    671
    14 Post(s)
    goal is loud as hell ground pounder, sub forward port driver side.. aero port tuned to 33.. getting a vfl 500.1 amp
    Quote Originally Posted by pro-rabbit View Post
    ***Current Setup***
  16. #30
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,099
    351 Post(s)
    Is there a reason you are set on that tuning? Do you know if that is what works best for your application and goals?
    Loud with what you have will be relativity easy.
+ Reply to Thread
  1. DC Lv5 18" Enclosure
    By c0smo kram3r in forum Enclosure Design & Construction Help
    Last Post: 08-31-2010, 08:29 PM
  2. enclosure specs for a 15 inch DC level 4xl
    By mendezm9 in forum General Discussion
    Last Post: 05-03-2010, 10:45 PM
  3. Enclosure build for Old_Gregs 2 12" dc lvl 3's
    By Twisted_0912 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 10-08-2009, 07:35 PM
  4. Enclosure Build For MmatsDude's DC lvl 5 18
    Last Post: 03-12-2009, 07:14 PM
