Results 1 to 9 of 9
Reload Thread: 6x9 Wall for techno?
    phildapimp89's Avatar
    phildapimp89 is offline CarAudio.com Elite
    Feb 2005
    IL
    767
    Would this be a better idea than subs for punchy bass thats in techno songs. It seems like subs lag behind when playing techno (even my Atlas 15") Just kinda a thought not like I am planning on doing this :P
    BlackHaze-'s Avatar
    BlackHaze- is offline Member
    Feb 2005
    The Sun
    80
    Re: 6x9 Wall for techno?
    Get some 8" to stay up with the beat, get some Soundsplinter 8"s and youll be good, then get really good speakers and a nice amp
    Head Unit - Kenwood KDC MP625
    Subs - 6 12" RE REs
    Box - Around 10 sq inch Tuned to 34~35 Hz
    Amp - Elemental Designs Nine.1
    Alarm - Viper 791 XV
    Wiring - Audiopipe PK3000P 0 Gauge
    Box wiring - Knu Koncepts 12 awg
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,691
    *sigh*
    And you're implying larger speakers can't "keep up" with the beat of techno? Sadly mistaken if you are...
    To the original poster - I'd bet money that it's your enclosure alignment, not the sub's diameter that is causing them to "lag" behind. Try a higher Qts alignment, and I'm sure that would solve the problem.
    Or, sell your "defective" subs to me at a very reasonable price
    Beat_Dominator's Avatar
    Beat_Dominator is offline Yea, thats Mecha Godzilla
    Mar 2005
    Phoenix Arizona
    30
    21,987
    To defend phildapimp89, the "bigger is slower" thing was true at one point, though that was a long, long time ago. New technology has effectively eliminated that problem.
    If you are 100% sure it sounds "laggy" then I would side with Frosty on this one and say your enclosure is causing some problems.
    Comming Spring 2009
    I make rear-loaded, double crabshell, isobaric enclosures.
    Berry47's Avatar
    Berry47 is offline CarAudio.com Elite
    Dec 2003
    My Pants
    29
    1,076
    I put my sub in a lower enclosure volume and it made the bass much tighter.
    Mine: CDT, Eclipse, Diamond Audio, Dayton, Aura
    Wifey: Infinity, Concept, Pioneer, Profile, JBL
    Refs: Ruckus, MSSOKC
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,439
    play with your setup. when i hear things like this i get depressed. bad setups make me want to shave my legs.
    Raven's Avatar
    Raven is offline Lacking social skills!
    Dec 2004
    Michigan
    28
    4,616
    When he says his 15 can't keep up, do you think he means he's crossed over under 80 hz or so and just doesn't have midbass? I don't see anything regarding front staging in his sig, so I can only assume the front is stock. In that case, a pair of midbass drivers, 8"s are my recommendation, properly bandpassed to fill the midbass gap would do wonders.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Quote Originally Posted by Berry47
    It gave you bump in the upper bass/lower midbass region, giving you the perception that the bass was tighter But, boxes like that will also have less low frequency extension and worst transient response/group delay.
    But, what are you running for a frontstage phildapimp89?
  9. #9
    audiolife's Avatar
    audiolife is offline WhAt?
    Feb 2002
    indiana
    42
    14,367
    Quote Originally Posted by Beat_Dominator
    lol my idw 15's were mistaken for 8's until something low went through them. people didnt know and the majority still dont know how to run a big woofer if they think this way still. if i had space id run a 15" no problemo even off 320 watts
  1. use 6x9 rear speaker slot to put 6.5" subs?
    By babyloc86 in forum Speakers
    Last Post: 01-24-2005, 06:05 PM
  2. question about sub wall in my Durango
    By NeverEnuffBass in forum Enclosure Design & Construction Help
    Last Post: 12-06-2004, 12:50 PM
  3. My 13kv2 ported box! (pics)
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 11-18-2004, 09:31 PM
  4. J-
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 01-06-2003, 03:50 PM
  5. Replies: 2
    Last Post: 08-22-2002, 04:16 PM
