+ Reply to Thread
Page 8 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... LastLast
Results 106 to 120 of 357
Reload Thread: Proper Door Sound Deadening and You
  1. #106
    jakl27's Avatar
    jakl27 is offline Member
    Sep 2005
    miami, fl
    27
    35
    Re: Proper Door Sound Deadening and You
    i dunno if it was asked already (too many posts to read) buton the first page, you out the clay on the ring. i assume u dont mount the midbass on the side where the clay is right?
    soon to be installed in my custom f-150.
    kx600.1 powering a re se10
    kx350.2 powering a set of mb quarts components 5.25"
  2. #107
    cykario's Avatar
    cykario is offline Member
    Sep 2005
    Miami
    26
    55
    If I'm going with custom kick panels should I use egg crate and dynamat (or any other material) to cover the whole panel?
  3. #108
    JAZN's Avatar
    JAZN is offline CarAudio.com Veteran
    Sep 2004
    SoCAL
    28
    11,370
    15
    Quote Originally Posted by jakl27
    you should have clay between the midbass and mdf ring.
  4. #109
    Decado's Avatar
    Decado is offline CarAudio.com Elite
    Jul 2005
    Minneapolis, MN
    1,121
    Quote Originally Posted by JAZN
    And clay between the mdf ring and the door .
    The Rest Of My System:
    -Orion HCCA-D2400 Amp
    -RE SX 15" Subwoofer
    -MTX Thunder 564 4-way amp
    -OlogyAudio Dayton RS Component Set
    -Sirius Satellite Radio
  5. #110
    Decado's Avatar
    Jul 2005
    Minneapolis, MN
    1,121
    So...would the small dimpled stuff work? I cannot find anything else anywhere.
  6. #111
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Quote Originally Posted by Decado
    Huh? Work for what?
  7. #112
    Decado's Avatar
    Jul 2005
    Minneapolis, MN
    1,121
    Quote Originally Posted by squeak9798
    Huh? Work for what?
    Uhh sorry, read a page back, i was wondering if the small many bump foam egg carton will work just as good as the big fewer bump stuff.
  8. #113
    lil azn 06's Avatar
    lil azn 06 is offline Senior VIP Member
    Sep 2005
    Houston Texas
    25
    388
    Would it be bad to stack 2 3/4 mdf rings to make 1 1/2 inch wood ( wiould use screws to keep them tight) or should i just stick with 1 mdf ring? SQ is the objective here for me, and if theres no difference, then ill stack the 2 mdf rings. Reason for stacking them is the door panel (plastic part) is too big of a hole, and id rather have the speaker sticking out a bit instead of going inward.
    Also, what screws should i use to mount the mdf rings to the car? Nuts and bolts, or metal screws?
    Lastly, what kind of clay should i buy?
    Thanks
  9. #114
    Decado's Avatar
    Jul 2005
    Minneapolis, MN
    1,121
    2 rings should be just fine, for screws, i don't know what everybody else uses but I used self tapping screws so it would go into the metal and made sure i drilled big enough holes in the mdf so it wouldnt crack, works great. And the clay, just buy some non-hardening modeling clay, any craft store should have it, and people were saying wal-mart also.
  10. #115
    slain93gsr's Avatar
    slain93gsr is offline Prying Open My Third Eye
    Sep 2005
    Wisconsin
    283
    i've use wood glue to connect two mdf rings before let them sit a day and it should be good to go..
  11. #116
    Decado's Avatar
    Jul 2005
    Minneapolis, MN
    1,121
    Quote Originally Posted by slain93gsr
    Ohh...ya, forgot about that, haha, it's been a long day...
  12. #117
    lil azn 06's Avatar
    Sep 2005
    Houston Texas
    25
    388
    wood glue?
    And also, since i live in Houston, which is always hot as hell/humid, would clay be a good idea? Also, do i stick clay bwt the 2 mdf rings?
  13. #118
    Decado's Avatar
    Jul 2005
    Minneapolis, MN
    1,121
    Quote Originally Posted by lil azn 06
    wood glue?
    You put wood glue between the 2 mdf rings...
  14. #119
    lil azn 06's Avatar
    Sep 2005
    Houston Texas
    25
    388
    my dad refuses to use clay on the doors (its my car so wtf) but he says its stupid. Instead he says i should use weather insulation tape. So, how does that work out?
    Also, i got my 12w6v2 and i was wondering if theres anything i can put to keep the rearview center mirror from shaking so much.
  15. #120
    Decado's Avatar
    Jul 2005
    Minneapolis, MN
    1,121
    Weather insulation tape may seal around the speaker up, but I do not think that it will stop any resonating.
    Sound deaden your trunk? That may cut down on some vibrations you get up there. Other than that there's not a whole lot you can do. Just use your side mirrors, that's what I do, because my rearview mirror fell off from bass and I can't get the ****er to stay back on.
+ Reply to Thread
