+ Reply to Thread
Page 3 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 31 to 45 of 357
Reload Thread: Proper Door Sound Deadening and You
  1. #31
    JAZN's Avatar
    JAZN is offline CarAudio.com Veteran
    Sep 2004
    SoCAL
    28
    11,370
    15
    Re: Proper Door Sound Deadening and You
    is deadening the outer skin of your door necessary? im gonna use a deflex pad but im just wondering if i should deaden the entire outer skin too. the inner frame is already deadened.
  2. #32
    Mar 2005
    Where you live (Ex. Los Angeles, CA)
    2,264
    Quote Originally Posted by JAZN
    yes yes yes yes yes yes yes
    so many vibrations come from the outer skin of your door because it
    a) deflects vibrations from your speakers all over the place causing distortion
    b) is a relatively thin piece of metal and vibrates like mad. feel your door from the outside when you have your speakers up high, they hum and buzz like a thousand bees.
    c) everyone says your supposed to, the above reasons are just thinking logically/realistically
    Owner of Post 22,222 in THE Thread.
  3. #33
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,368
    My friends door panels flex nicely from his sub.
  4. #34
    MetalMaxima's Avatar
    MetalMaxima is offline AURAL DESTROYER
    Dec 2004
    The Garden State
    31
    1,142
    Since we're on the subject, here is a pic of the speaker OEM speaker rings on my car...would anyone recommend using the MDF rings in addition to the method listed here?
    HU - Alpine 9833
    FRONTSTAGE - Dynaudio MW170, MD 100, Morel Domes (all passive )
    REAR-FILL - Rainbow SL 165
    SUB - 2 x 12" Alumapro Alchemy RX
    AMPS - Arc Audio XXK-4150/2500
    WIRING - Stinger Expert
    SQ CABIN 160sqft. Damplifier, 120sqft. Spectrum, 100sqft. Hazmat, 80sqft. Spectrum Sludge...[/SIZE]
  5. #35
    supa_c's Avatar
    Apr 2004
    In a chair
    19,368
    Plastic resonates quite nicely if not deadned.
    What i normally do is get rid of the stock rings ( most aftermarket speakers dont fit them) and make some custom MDF ones.
  6. #36
    Dec 2004
    The Garden State
    31
    1,142
    Quote Originally Posted by supa_c
    What i normally do is get rod f the stock rings ( most aftermarket speakers dont fit them) and make some custom MDF ones.
    Ok, looks like I'll be doing some ring cutting. Thanks!
    HU - Alpine 9833
  7. #37
    Dec 2004
    The Garden State
    31
    1,142
    Quote Originally Posted by twoohfour
    i'm working on this right now as I write this...
    and let me tell you....
    plexiglass is a fkin B1TCH to cut!!!!
    Use a carbide cutting wheel with a rotary tool such as a Dremel. Worked wonders for me.
    HU - Alpine 9833
  8. #38
    supa_c's Avatar
    Apr 2004
    In a chair
    19,368
    wow, my spelling ****** in that post
  9. #39
    May 2004
    Dramaville
    19,671
    Quote Originally Posted by jntar
    Well, I am going to try this out tonight. I will let you guys know what I find on saturday
    Update.
    Tried the egg crate out. Works very well, mid range frequencys dont sound so "under water" I spent $1.50 on it too. Took about 30 min to install with silicone. Added more deadener to my doors. The clay worked pretty good at sealing the little inperfections I had leftover after the fist two rounds of deadeneing. Tried the plexi idea with a sheet of balsa wood I had lying around, but my doors are too large and the door skin wouldnt allow me to install it.
    All in all tis a great tutorial.
  10. #40
    Nightskye's Avatar
    Nightskye is offline Member
    Feb 2005
    East Bumfvck
    140
    I highly recommend deadening the inside of the outer door skin, it made a huge difference with mine. But I disagree with not using liquid deadener. It may take longer, yes, but with a brush you can reach areas that you can't with a mat.
    '06 Civic Sedan
    Clarion DXZ855MP
    PPI PC4800.2
    ID CTX65CS
    IDQ10v3
    Second Skin deadened
  11. #41
    JAZN's Avatar
    Sep 2004
    SoCAL
    28
    11,370
    15
    Update.
    bah i paid 30 bucks for my deflex pads, then again i do see water inside my door on rainy days. nice to see more positive comments on this stuff working, i have my liquid deadener on the way for my outer skin now.
  12. #42
    JAZN's Avatar
    Sep 2004
    SoCAL
    28
    11,370
    15
    i wanna cover up the holes with mdf. good idea? if so, is 1/2" thick enough?
  13. #43
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Should work
    Don't see why not
  14. #44
    96pfinderSE's Avatar
    96pfinderSE is offline CarAudio.com Elite
    Mar 2005
    Georgia
    531
    to start off would it be affective if i just cover the outside of the door panel like this cause i only have 24 sq ft (2 dynamat extreme dookits) will that still be affective?
  15. #45
    supa_c's Avatar
    Apr 2004
    In a chair
    19,368
    You should notice the difference
+ Reply to Thread
