Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: Proper Door Sound Deadening and You
hello friend,
it's very good exeperience to sit in the car and liston high watt bufer sound it just like rocking
Need a premium iPhone app developed? Premium iPhone Apps
I haven't read all 25 pages, but has Fatmat been mentioned? I used about 2000 sq ft in my durango and found it to be pretty solid stuff.
Originally Posted by
SPLAudioHz
yeah you wasted 1900+ square feet
Any body ever use anything like this? It's 6" wide roll.. about 1/16" thick, pressure sensitive adhesive back... I have some surplus at my work and am thinking of using it for my doors...
emilimo701
Junk stuff? Or only need a little bit of it?
Dave88LX
only need a little on certain problem areas.
mcm308
seems like that could serve multiple purposes. I have some butyl tape, but it's a little thicker. I haven't used it yet though
Hello!
I finished my rear doors, needed to add more sound deadening and fixed my rear rattles, I put as much as I could on the external outer metal, maybe left about 2-3 inches untreated on each side of the external metal.
The problem I have is one of the rear doors (left)does not close as easy as the right door. My right door, I barely push and it closes by itself, my left door does not close unless I make 2 or even more times the effort to close it. I have more than enough on both doors and I do not want to waste material since all I want to do is make it close easier and tighter.
My question,
Where do I add more SDM to add weight to make it close with less effort, inner layer center, Lower,higher ?
outer layer, inner layer? closer to the hinges, center, high, low? closer to the end, high, low, middle?
Thanks in advance for your help!
Holy dead thread revival, Batman!
Yes, Robin, and wtf is SDM? Is that an evil new abbreviation that is being used against we doer's of good?
Spider Monkey
Romney will [fornicate] me less than Obama already has and WAY less than what Obama has planned.
Refs: adamtwo4, basscort2009, burzendowski, clanassa, cthedinger, ikoolguy, its_bacon12, Jew_Bagel, jr711, kreapin, kowboy, Rudy, TheRealDefman, Winter_C
HU:Eclipse CD7200 MkII
Subs: Fack Skar Audio
Front comps: HAT Clarus C61-2 off Sony ES 7547
Electrical: C&D batt, Big 3 with 1/0, 4ga to amps, Stinger RCA’s
Damping: 60mil FG panels over holes, full worx from SDS
Flex68
Sound Deadening Material, is that really that hard (SDM)? I posted a thread in the G D section and got no answer yet, I figured since this is a sticky and and a SDM how thread I would post my issue and get some help. Any ideas?
Adjust and grease your door hinge and/or latching mechanism.... "SDM" is to deaden sound, not to help doors close better
Spider Monkey
I'm going to install new Rainbow speakers in my Buick Verano (same size as Chevy Cruze) which has triple sealed doors. Do I really need sound deadning in the doors or not? I read that sound deadning does not improve midbass, is that true? If I do need sound deadning, I am thinking of going with Damplifier Pro, how many sq feet per door will I need?
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
