+ Reply to Thread
Page 23 of 25 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 LastLast
Results 331 to 345 of 367
Reload Thread: Proper Door Sound Deadening and You
  1. #331
    teenycar's Avatar
    teenycar is offline Member
    Sep 2009
    Redlands, Ca
    47
    Re: Proper Door Sound Deadening and You
    My door project. Thanks to the good folks on this forum for the advice along the way.
    Stripped the doors and put two layers all throughout the outside panel and 2, 8X8 squares behind where the speaker will mount and glued some ensolite 8X8 squares behind the speaker as well. Now I am "plugging" the inner door panel holes using perforated aluminum 20 guage. Inner panel has 1 sheet of raamat. I am putting raamat on the inside and outside of each fill panel too.
  2. #332
    SHEILA's Avatar
    SHEILA is offline Junior Member
    Dec 2009
    us
    13
    remember that the sound is in waves
    use the blocks to deflect the waves to where you want them
    the coarse surface will absorb some, so the sound will be heard more in that area,
    if you coat the surface it will reflect more, and less will be heard and directed where you want it.
  3. #333
    SHEILA's Avatar
    Dec 2009
    us
    13
    You are right that *** and love are not out of world experience.
    But I would like to correct you that both these are far far wonderful, then shown in movies or music videos.
    _____________
    Midnight Hour
  4. #334
    Bubblebass's Avatar
    Bubblebass is offline Member
    Jan 2010
    SoCal
    125
    I have read about 25 pages here....what seems to be the best product used for the best price for the front doors? Raamat seems to be really hard to order from the site and very expensive! Anyone comment on this stuff?
    50 sqft R-BLOX Sound Deadener +Dynamat Sample : eBay Motors (item 270527597662 end time Feb-14-10 01:27:39 PST)
    and is $75 a good price for it for 50'?
    If I use some caulk under the speaker rings, so I need to use clay? I have been reading that it just peels off with heat and my summers are 110 here.
    I am thinking of just getting this stuff, some MDF and caulk and a very small peice of egg crate for behind the speaker itself. Do I need to do that even if there is deadener behind the speaker?
  5. #335
    RMF419's Avatar
    RMF419 is offline Senior VIP Member
    Aug 2006
    Toledo Ohio
    160
    I have read all of these pages myself. What I am confuse about is; In my car the speaker is mounnted in the door panel itself. There is good room in there. I have an sls in there now. I wanted to do a better job of mounting this speaker. Along with adding some cld tiles to the outer shin with some mass loaded vinyl. Should I cut thru and mount to door or leave as is. Here are some pics of the situration.
    2 Soundstream RUB4.600
    Audax TW025A2 tweeter in the A-Piller.
    Peerless 830986 3" Midrange in the sails.
    Peerless 830946 SLS 6.5 Midbass in the doors.
    Tang Band W69-1042J 6"x9" Subwoofers.
    Lanzar Optidrive 10-Channel crossover.
    Counterfit Pionner Double Din
    2ga welding cable and 12ga speaker wire.
  6. #336
    _s_m_a_c_'s Avatar
    _s_m_a_c_ is offline Junior Member
    Mar 2010
    Oregon
    21
    Has anybody tried hercaliner (truck bed liner) for deadning/soundproofing? Somebody suggested it to me and after knocking around a utility/rescue vehicle entirely covered with it I have to say it seemed to work. A gallon is around $100. Thoughts?
  7. #337
    open321max's Avatar
    open321max is offline Junior Member
    Apr 2010
    chian
    hi
    Wow,thats just sweet,I`m going to have to do that to my doors with the egg carton stuff.
  8. #338
    sdmtnbiker420's Avatar
    sdmtnbiker420 is offline GAME 4 SALE
    Mar 2007
    San Deezy 92111
    1,255
    Quote Originally Posted by SHEILA View Post
    _____________
    Midnight Hour
    what music videos you been watchin
    2000 Infiniti QX4 - louder than you
    1989 Honda CRX - faster than you
  9. #339
    only1db's Avatar
    only1db is offline Junior Member
    Apr 2010
    Melbourne, FL
    holy good read batman!
    where can i get the non hardening clay from? a craft store?
    like others my speakers were getting wet and one of my hex series midbass speakers took a dump on me, i'm replacing them(hopefully with another set) but i'm going to be redoing my door adapters and the clay seems like a really good idea. over the eyers the wood that i used (1/2 inch plywood) as broken apart and rattles.
  10. #340
    FlexnInLa's Avatar
    FlexnInLa is offline Huggin Them Nuts!
    Jul 2010
    Middle of Nowhere, Louisiana, USA
    45
    1,243
    232 Post(s)
    What the **** is this freak? Has this thing been banned? I didn't know that was "this kind" of forum.
  11. #341
    jcalvert86's Avatar
    jcalvert86 is offline Junior Member
    Jul 2010
    illinois
    Is it of any benefit to deaden the plastic door panel backside in any way? whether mat or liquid?
  12. #342
    emilimo701's Avatar
    emilimo701 is offline CarAudio.com Elite
    May 2010
    Boston, MA
    756
    9 Post(s)
    lol @ clay
    at first i thought it was a joke....
  13. #343
    AWD PSI's Avatar
    AWD PSI is offline Senior VIP Member
    Aug 2010
    SoCal
    177
    Great thread, I read it all and learned a lot. Also read through Sound Deadener Showdown - Your Source for Sound Deadening Products and Information.
    I do have questions about foam. Does it have to be CCF in the door panel? I found sheets of foam at Jo Ann Fabrics in various density and thickness. It's the same type foam as the egg carton stuff used behind the speakers but smooth, is this good for anything else? The only CCF I can find is at the sporting goods store. It is a mat for under sleeping bags and looks like small egg carton sheets. Living in SoCal I don't worry about rain much but this seems like a better choice for inside the door skin behind the speaker. Will this work ok? If it has to be CCF in the doors where can you find it locally? Thanks for any help.
    ***Edit*** I also came across floor pads made out of EVA foam. You can get a fairly large mat from a sporting goods store for $30. Would that foam be useful for anything?
  14. #344
    emilimo701's Avatar
    May 2010
    Boston, MA
    756
    9 Post(s)
    Quote Originally Posted by AWD PSI View Post
    most closed cell foams have the properties of being resistant or impervious to things like moisture, mildew, UV sunlight, contact with chemicals, all of which are usually applicable to what a vehicle is exposed to. some CCFs are probably also more resistant to tearing, and that SDS site also talks about compression set but the open cell foam you find at JoAnns might be fine for that too, i'm not sure.
    I'm awaiting some foam in the mail if you want to follow:
    http://www.caraudio.com/forum/speake...uys-think.html
  15. #345
    emilimo701's Avatar
    May 2010
    Boston, MA
    756
    9 Post(s)
    This thread has a lot of useful information, but it also has a fair share of misguided information. Perhaps should be de-stickied in place of an updated one? With a tutorial from someone who has been formally educated in some way relating to this topic, and with adequate experience using these products (and/or products from other domains of DIY that can be transferable for possible better solutions)? and the title is very cheesy hah
  16. Likes alexwoodby liked this post
+ Reply to Thread
