+ Reply to Thread
Page 21 of 24 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 301 to 315 of 357
Reload Thread: Proper Door Sound Deadening and You
  1. #301
    lil azn 06's Avatar
    lil azn 06 is offline Senior VIP Member
    Sep 2005
    Houston Texas
    25
    388
    Re: Proper Door Sound Deadening and You
    Quote Originally Posted by chibahawk View Post
    just started deadening my doors today. question for people in the know. im a plumber and we've got plumbers putty that we use to seal up sink drains, shower drains, and basically anything we want to prevent from leaking - ive swiped a few containers from my van to use on the mdf rings.
    the container says "keep away from strong oxidizers"
    --problem= im not a scientist.
    can i use this putty instead of clay?
    Does it harden? Because you would want to use something non-hardening.
    Alpine 9855
    JL 300/4
    JL 500/1
    Rainbow Profi 2 way active
    JL 12w6v2 ported
  2. #302
    chibahawk's Avatar
    chibahawk is offline oe squeezer
    Jun 2005
    NYC
    26
    855
    no it doesnt harden or retain moisture. as for heat resistance i havent been able to find an exact number regarding whether or not itll stand up to a ny summer.
    im just not sure if using it against the back of the speaker is a good idea in case it oxidizes??
    refs: Blunt, BassAddictJ, Pickler, Blazin_Jason, 3onDubs, jeremyzach, mexcansa, baastard
  3. #303
    chibahawk's Avatar
    Jun 2005
    NYC
    26
    855
    Heres some stuff I did today. Did about 2/2.5 layers. Still have plenty more eDv1. I'm applying it with a blowdryer and really sticking the edges on so hopefully I won't have to deal with it coming off.
    ****Also has anyone ever tried using Great Stuf foam in the doors? I used some in my left door... I'm thinking of being real careful and filling up the very innermost part closest to the engine that I can't really reach with deadener. Have to watch out for the window track and also not to block the drains for water. Anyone think it's a good/bad idea? Should I not bother?
    I'm using the stuff for windows that WILL NOT expand to the point of bending the door frame.
  4. #304
    websterbud's Avatar
    websterbud is offline Junior Member
    Apr 2007
    Wisconsin
    28
    What type of non-hardening modeling clay are you guys using? Went to the crafts store today and they had Roma Plastina, but only #1 and #2...are these okay to use?
  5. #305
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,450
    Quote Originally Posted by websterbud View Post
    Yes.
    The non-hardening clay I buy is just regular clay with wax added to it so that it doesn't harden over time.
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
  6. #306
    mpbojangles's Avatar
    mpbojangles is offline Junior Member
    Oct 2004
    Akron OH
    23
    This may have been asked in the previous 21 pages, but is there anything that you can do to the egg carton foam to make it water resistant. cover it with a plastic bag and melt it on (with a lighter) might be an idea? What do yall think?
  7. #307
    TriXR4Kids's Avatar
    TriXR4Kids is offline Member
    Dec 2007
    Leavenworth, KS
    39
    Would extra pads of ensolite behind the speaker be comparable to the egg carton foam for breaking up the waves?
  8. #308
    FoxPro5's Avatar
    Aug 2005
    3 octaves higher
    5,450
    Quote Originally Posted by TriXR4Kids View Post
    What do you mean "extra"?
    Ensolite is a brand of closed cell foam which is often used for its waterproof qualities (sports equipment, industrial apps where there is water, etc). There are many types of Ensolite and many more types of CC foam.
    Typically egg carton foam is open cell, but you have to check and see for sure which one you have. Technically, it should be more absorptive of sound because of its material properties. The draw back is that it can also absorb water, too.
    If you want to defract or "break up" sound waves you need a blocker or a barrier. This is where products like Deflex pads come in handy. They are resonably good (depends on frequency band) at "scattering" sound waves, but not so good at absorbing them. They are almost always made out of low durometer rubber or silicone and have a convoluted surface to "soften" the blow of a rear wave from a close distance.
    TEAM Front Fill
  9. #309
    KB15's Avatar
    KB15 is offline Junior Member
    Sep 2005
    Toronto,Canada
    32
    23
    Does this happend to work for just basic installs or is this for speakers that will be used for midbass... etc.. etc...
    I would look to install bunch of infinity 6012i to replace the stockys nothing big... but by doing thsi will this improve anything?
  10. #310
    outspoken's Avatar
    outspoken is offline CarAudio.com Elite
    Oct 2007
    Between The Golden Gate And The Bay Bridge
    36
    1,530
    Quote Originally Posted by KB15 View Post
    if by doing this you mean deadening, then yes you will notice a major difference...
    Refs: vitveet(x2)-audiobahnuser18(x2)-fargof-mazzasec-loudcartunez-jeeper07-NE14MX-pitbull12887-datboiroy-littleviet-XxSuperAdamxX(x2)-uS3-craigzter-LazyRider-juckstapose
    Quote Originally Posted by endofdays89 View Post
    yeah, put in some white girl or three 6 mafia and sit in your car and let us see how much the rear view mirrors move. It usually is the best indicator that the low lows are hitting well or not. Cuz it should vibrate quite a bit.
    Quote Originally Posted by matrxx dude View Post
    my girl ask me once to choose between her and my car audio,i told that ***** i had made harder decisions at the coke machine.
  11. #311
    KB15's Avatar
    Sep 2005
    Toronto,Canada
    32
    23
    well i look to change the speakers anyways i guess ill throw the remaning i have left around the speaker and work outwards... by dynamating the door (i have that elemental design one forget the name) but yea will it also help keep some of the road noise out aswell??
  12. #312
    outspoken's Avatar
    Oct 2007
    36
    1,530
    yes it will keep road noise out... edead is what you are using i believe, and i assume you read this thread, the instructions i mean... if you don't do the whole door properly, i wouldn't expect a major improvement...
  13. #313
    KB15's Avatar
    Sep 2005
    Toronto,Canada
    32
    23
    i got the .75mm thick one its a pretty thick pieice and i ahve enough for maybe about 65% of the entire door n alot of it i mite not need because of the holes in the door what wil i fill thoes with not messing with the window from going up and down?
  14. #314
    Sheetal K's Avatar
    Sheetal K is offline Junior Member
    Jan 2008
    Amchi Mumbai
    Nice Article. I went for Dynamat.. bit costly..but, I never regret.
    check this: http://acousticsforyou.com/articles/...ing-sound.html
  15. #315
    zoo keeper's Avatar
    zoo keeper is offline Junior Member
    Sep 2007
    mcmcellandtown
    17
    why do you guys put 2 or 3 layers of deaden? i never did any, but soon when it stops snowing here in PA
+ Reply to Thread
