+ Reply to Thread
Page 20 of 24 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 286 to 300 of 357
Reload Thread: Proper Door Sound Deadening and You
  1. #286
    phenryiv1's Avatar
    phenryiv1 is offline Custom user title
    Nov 2006
    Martinsburg, WV
    549
    Re: Proper Door Sound Deadening and You
    Quote Originally Posted by ironchef b View Post
    By any chance do you or someone else have any pics of this application especially the bolded part???
    I will be taking pics as I do it. I have seen pics online, and it seems to work well, for the cost. (Some) luxury cars have this foam from the factory.
  2. #287
    Buffalohed's Avatar
    Buffalohed is offline Music Snob Extraordinare
    Jan 2007
    Austin
    575
    Quote Originally Posted by phenryiv1 View Post
    This and your previous post were very helpful. Thank you.
    "The endeavor to understand is the first and only basis of virtue." - Spinoza
    “The mind can make a heaven out of hell or a hell out of heaven.” - Milton
    Kicker comps / Stereo Integrity subs / Sundown + Kicker amps / lots of room for improvement
  3. #288
    John Scaro's Avatar
    John Scaro is offline The Money Pit
    Jan 2007
    Woodstock, Ga.
    I need some info on deadners. RAAMmat, Second Skin, E Dead, the list goes on. Well which is better and why? Is there any that I should stay away from?
    Thanks!
  4. #289
    mntnceguy's Avatar
    mntnceguy is offline Junior Member
    Sep 2006
    Denver, Co.
    Go here, read this:
    http://www.sounddeadenershowdown.com/
    Then go here to get the best stuff:
    http://www.secondskinaudio.com/cgi-bin/index.cgi
    And check out the forum there for more good info and help
  5. #290
    John Scaro's Avatar
    Jan 2007
    Woodstock, Ga.
    Quote Originally Posted by mntnceguy View Post
    Go here, read this:
    Good reading Thanks!
    I went with RAAMmat for the floors, backwall, rear doors and misc and the SecondSkin for the front doors. Now I just need time to do it!!!!
  6. #291
    XanderMoser's Avatar
    XanderMoser is offline Poor college student
    Mar 2007
    Wisconsin
    573
    Has anyone tried this spray-on deadener from Cascade at Parts Express?
    http://www.partsexpress.com/pe/showd...number=268-250
    It only costs $16 per can, and it is supposed to cover at least one door per can. Granted, I have a 2 door with longer than normal doors, but this would be much much cheaper for me and I am on a strict budget. I just want some deadening to improve my midbass and not add a ton of weight. I would also be plugging up the holes in my door skin and adding a closed cell foam egg shell pad behind my speakers. Would it be worth it?
  7. #292
    Anthony Collova's Avatar
    Anthony Collova is online now Supporting Vendor Anthony Collova is a Supporting Member of the forum!
    Anthony Collova is a Supporting Vendor of the forum!
    Jan 2005
    Scottsdale
    37
    1,352
    45 Post(s)
    Quote Originally Posted by XanderMoser View Post
    Consider that you need about 3 to 4 cans to properly dampen a single door, it becomes less and less affordable.
    Go with full gallon and split it up between 2 doors. That would be better
    ANT
    AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
  8. #293
    4frogger's Avatar
    4frogger is offline Member
    Mar 2006
    San Diego
    44
    Quote Originally Posted by Sragan View Post
    Now, after that long winded explanation to my disagreement, here's the short version. Decoupling or isolating the speaker is strictly so the speaker can perform optimally, not simply to improve bass response (it's a byproduct), although for the more younger crowd, an easier way to get them into the habit of doing things properly (but along the way, let's tell 'em why). I will agree, MDF as a spacer ring to replace the plastic rings in factory locations is a good thing, and while clay will isolate the speaker, why risk the mess when a simple foam gasket will do the trick for a solidly mounted speaker/spacer? Not to mention, no one here knows the rate at which the clay will deteriorate over time, if it does at all.
    }[/i]
    Can Anyone chime in on this? Should I just use foam as opposed to clay for reasons as stated by Sragan? I do agree with him as far as rate at which clay will deteriorate, esp during hot summers and open/closing doors often (clay shifting of sliding downwards).
  9. #294
    krisfnbz's Avatar
    krisfnbz is offline CarAudio.com Veteran
    Sep 2006
    Frederick MD
    27
    4,386
    1992 Civic LX Deadening Job pics.... at the following link
    http://www.caraudio.com/forum/showthread.php?t=225604
    Yes that is a 5 1/4th audiobahn mid speaker in my civic's headrest. circa 2006.
    2000 Celica GTS
    Pioneer FH-X700BT
    Powerbass 2XL-60.3C 3 way
    Dayton Ultimax 15", sealed 4cuft
    Memphis 16-MC5.700 5 channel
    Knu wiring
  10. #295
    AMA's Avatar
    AMA
    AMA is offline Junior Member
    Dec 2006
    TX
    17
    Maybe I missed it in the 20 pages of this thread, but those of you who have used this technique:
    what did you use to treat the MDF?
    Cause if it gets wet or collects to much moisture it will warp and crack.
    Thankx
  11. #296
    Decado's Avatar
    Decado is offline CarAudio.com Elite
    Jul 2005
    Minneapolis, MN
    1,121
    Quote Originally Posted by AMA View Post
    Thankx
    I never treated the MDF and I've had it in there for more than a year now and no signs of cracking or warping. Besides, couldn't treating it cause it to become resonant?
    The Rest Of My System:
    -Orion HCCA-D2400 Amp
    -RE SX 15" Subwoofer
    -MTX Thunder 564 4-way amp
    -OlogyAudio Dayton RS Component Set
    -Sirius Satellite Radio
  12. #297
    phenryiv1's Avatar
    Nov 2006
    Martinsburg, WV
    549
    Thankx
    I made my spacers out of high-density PVC that was 1" thick. I used roll deadener as a gasket between the spacer and the door.
    it was expensive (as compared to MDF) but it will never rot out.
  13. #298
    Oct 2006
    Cali
    1,142
    I personally always use a weather proof spray paint and do 3-4 coats just for caution... i dont see many people treat their wood often but i personally do... In general i like to use the apliance epoxy spray paint... its like 5 bucks a can but i have only gone through two cans in about 7 years...
  14. #299
    Decado's Avatar
    Jul 2005
    Minneapolis, MN
    1,121
    Quote Originally Posted by WantedIsHere View Post
    I also like to treat my wood often . Sorry, I just had to say it .
  15. #300
    chibahawk's Avatar
    chibahawk is offline oe squeezer
    Jun 2005
    NYC
    26
    855
    just started deadening my doors today. question for people in the know. im a plumber and we've got plumbers putty that we use to seal up sink drains, shower drains, and basically anything we want to prevent from leaking - ive swiped a few containers from my van to use on the mdf rings.
    the container says "keep away from strong oxidizers"
    --problem= im not a scientist.
    can i use this putty instead of clay?
    refs: Blunt, BassAddictJ, Pickler, Blazin_Jason, 3onDubs, jeremyzach, mexcansa, baastard
+ Reply to Thread
