+ Reply to Thread
Page 19 of 24 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 271 to 285 of 357
Reload Thread: Proper Door Sound Deadening and You
  1. #271
    TomBrooklyn's Avatar
    TomBrooklyn is offline Junior Member
    Jul 2006
    Brooklyn
    15
    Re: Proper Door Sound Deadening and You
    Hi squeak,
    How are you going to get the door panel back on? Doesn't the Deadener on the inside make the panel not sit right? And I suppose your're going to cut a hole in it to let the MDF spacer stick through? What do you do with that whole thing sticking out, put some kind of molding around it?
  2. #272
    Mx3guy's Avatar
    Mx3guy is offline Member
    Jun 2006
    Oklahoma
    100
    Ok I just finished deadening my doors with the peel n seal roofing stuff I only used 10 squared feet per door and the difference is amazing. My subs used to rattle the heck out of my doors at half vol. Now they bearly rattle at full vol. but the subs pretty much drowned it out, you have to get right up to the door to hear it. Any way I only spent $25 for 25 squared ft. at lowes. If you have trouble with subs rattleling your car you should get this stuff its cheap and works really well. There is a slight smell but not as bad as I thought it would be. Even my door speakers sound better. This stuff is a real good buy.
  3. #273
    AJČ06's Avatar
    AJČ06 is offline 8====D ---> ( | ) = win
    Jul 2006
    DFW, USA
    10,198
    I NEED some!!
    http://www.myspace.com/unknownbelow
    Refs: Showrides|IonSQL x2|mattmcss|QtrHorse x2|DaGh0st|bjfish11
    حَتَّى إِذَا اجْتَزْتُ وَادِي ظِلاَلِ الْمَوْتِ، لاَ أَخَافُ سُوءاً لأَنَّكَ تُرَافِقُنِي. عَصَاكَ وَعُكَّازُكَ هُمَا مَعِي يُشَدِّدَانِ عَزِيمَتِي.
    Ebay:aj06silver
    Quote Originally Posted by Reson8 View Post
    Much as I shudder at the thought of potentially seeing your *****, writing caraudio.com on your dick would kick ***. Que the joke about only being able to get up to "CAR" on it....
  4. #274
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    2,250
    Quote Originally Posted by ItalynStylion View Post
    Wow, i just spent the better part of 2 hours reading http://www.sounddeadenershowdown.com/
    That was the best write up I have ever seen on just about any topic. He will deff get a little paypal help when i get the chance!
    I do have a question for anyone who can help me. Ive decided on the Damplifier sound deadener but im STILL not sure how much im going to need. I plan to do 50% coverage on both front doors and most of the rear deck in a Lexus IS300. Anyone have a decent EDUCATED guess on how much i will need?
    I'd get 125 sq ft or so, whatever you don't use there you can always put somewhere else or double up.
  5. #275
    ItalynStylion's Avatar
    ItalynStylion is offline Audiophile
    May 2006
    Fort Worth, Tx.
    1,277
    Quote Originally Posted by T3mpest View Post
    I finished the intstall last weekend and I must say im inpressed with how it turned out. I didnt get crazy with the deadener but the difference is unreal.
    As a matter of fact one of my friends on the cross country team got in my car this morning and she said, "****, your car is sooo quite!"
    Biggest...smile.....evar
    Quote Originally Posted by qtipextra View Post
    is 2 12's overkill for HT?
    Quote Originally Posted by JimJ View Post
    It's a start.
  6. #276
    May 2006
    Fort Worth, Tx.
    1,277
    I used damplifier by the way. I would recommend it to anyone and suggest using nothing else....I know I won't
    It's a start.
  7. #277
    Glaucus's Avatar
    Glaucus is offline Junior Member
    Jul 2005
    Winnipeg, Canada
    27
    Over the next few days, I'm going to attempt to fab up acrylic plates, get photos of it being done, and hopefully post them up here to clear this mess of a post (mine) up.
    So... any progress on this???
    - Mike
  8. #278
    Jared530's Avatar
    Jared530 is offline Drop bombs
    May 2006
    Sacramento, Ca
    2,259
    i was wondering, instead up placing eg cartong foam inside your door panl, if its ok to put fiber glass in fora substitute, the reason is because i cant find any egg carton foam, and regular foam at fabric stores are about $30for a yard.
    Refs: Kevokrook77, Cheapo, Killahbean, Coolwazabi, ShinyChromes(SCAMMER), Jnoel, matrxx dude, ssackett, Josh #44(SCAMMER), tc3k101, matrxx dude
  9. #279
    Buffalohed's Avatar
    Buffalohed is offline Music Snob Extraordinare
    Jan 2007
    Austin
    575
    I think there are some misconceptions going around here. At least I have certainly ran into some after reading tons of pages on multiple forums about "sound deadening".
    The most important thing imo is that sound deadening can be split into two categories:
    1) Stopping rattles/reverberations from your car stereo
    2) Dampening noise coming in from the outside
    The problem is that almost everyone talks exclusively about the butyl/asphalt mass products designed to stop rattling and vibration in your car. These are great for what they do, especially if you have a system that causes stuff to rattle and shake. However, I am skeptical as to how much this actually helps stop road noise from entering your car! I am sure it works to an extent but it seems like a mixture of some other techniques more commonly used to dampen sound would have a greater effect.
    I don't know very much about this so I am posting this mainly as a question. Say if you did not plan on playing an extremely loud system, therefore having few instances of stereo induced rattling, but wanted a high level of dampening from outside sound, what should you do to your car?
    Foam, carpet padding, fiberglass, extra layers of butyl, caulking? What should you use and where should you put it? In my car, a ton of noise comes in from the engine compartment through the firewall. Should I load up the area with flame retardant foam, or something else?
    Thanks.
    "The endeavor to understand is the first and only basis of virtue." - Spinoza
    “The mind can make a heaven out of hell or a hell out of heaven.” - Milton
    Kicker comps / Stereo Integrity subs / Sundown + Kicker amps / lots of room for improvement
  10. #280
    phatcat600's Avatar
    phatcat600 is offline yeah my name is stupid
    Jul 2004
    Dowagiac, MI
    25
    371
    I just applied deadener to the plastic panel that comes off...I thought that was what was meant by inner door skin. Is this completely worthless?
  11. #281
    Lil Poot's Avatar
    Lil Poot is offline you sturrin at me brah?
    Jul 2005
    Wichita KS
    30
    4,956
    Quote Originally Posted by phatcat600 View Post
    yes. deadener is for stopping metal from resonating.
    Alpine W205/H701
    Revolution Design D9 - 2 AQ HDC3 18s
    Genesis Profile Four Ultra - Creative SDX7 mids, TBI HDSS tweets
    Iraggi 240a, Optima g34 YT, 3 C&D 134ah, 15.3v MLA module, 120 ft 1/0, 200 ft^2 RAAMmat
    WTT/S - 2 HDC3 18s, RD HW 10, 880prs + ipod + 6 disc changer, Alumapro ALC6.2 Components, Zed built US Acoustics USA4050 + USA2200, Fisher Customs boxes
  12. #282
    phenryiv1's Avatar
    phenryiv1 is offline Custom user title
    Nov 2006
    Martinsburg, WV
    549
    Quote Originally Posted by Buffalohed View Post
    Thanks.
    Closed cell foam. Line your floor, inner door skin, roof (?), interior fenders, and firewall with it. Also, caulk or foam any gaps where sound might be transferred through a passageway.
    Also, you can fill your frame rails, trunk support beams, and floor crossmembers with the NON-pressure expanding foam for windows and doors (this is really important). http://www.lowes.com/lowes/lkn?actio...612&lpage=none
  13. #283
    phatcat600's Avatar
    Jul 2004
    Dowagiac, MI
    25
    371
    what a waste of deadener
  14. #284
    phatcat600's Avatar
    Jul 2004
    Dowagiac, MI
    25
    371
    plus I already ripped out all the stock insulation stuff....ouch
  15. #285
    ironchef b's Avatar
    ironchef b is offline Ainokea
    Jul 2006
    Oahu, Hawaii
    316
    Quote Originally Posted by phenryiv1 View Post
    By any chance do you or someone else have any pics of this application especially the bolded part???
+ Reply to Thread
