Results 1 to 5 of 5
Reload Thread: RE Comps
    IshbOO's Avatar
    IshbOO is offline Senior VIP Member
    Aug 2004
    St.Louis, MO
    25
    336
    RE Comps
    I have some Questions about the RE comps.
    Could I power RE comps off my Head unit, until I can afford an amp?
    How much are the RE comps?
    How do the RE comps perform?
    I just blew one of my 4x6 speakers, and looking into buying some comps to replace them. I dont have a place to mount them, but i'm sure I could get some kick panels, Not all sure where else I could mount them, maybe there are romm in the doors.
    Ca.com Refs: BLD 25, tez4life
    Ebay Refs: http://myworld.ebay.com/jdmjunkeee
    FS Orion HCCA-D2400, 12" SS RLP, 15" SS RLP
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: RE Comps
    Quote Originally Posted by IshbOO
    Yes. But you will definitely want to get an amp for them at some point in time.
    (702) 896 4823
    www.reaudio.com
    Call them and find out. If there is a dealer within 50 or so miles of you, then you must buy from the dealer. IIRC they are ~$179 or so direct from RE.
    Check out the product review section, and try to do some searching. There should be quite a few reviews around here. From what they've said...the mid is great, tweeter could be better. But, to each his own.
    In all the cars I've worked on; even if the car doesn't have door speakers, there are big enough openings in the lower-front of the inner metal door panel that it is fairly easy to install speakers there with a little cutting of the door panel Done it in two vehicles so far...both turned out nicely and performed well. Cut the panel where the speaker will go, build a baffle out of MDF, screw baffle to the door, install speakers into baffle. BAAM! You're done
    DrtySthV6SE's Avatar
    DrtySthV6SE is offline I like big butts
    Dec 2004
    Tuscaloosa, AL
    191
    Re: RE Comps
    i like mine, running them off a NINe.2 and they sound ******
    Pioneer Premier, Elemental Designs, SoundSplinter, RE Audio, Rockford Fosgate, Optima, Stinger
    x2
    IshbOO's Avatar
    Aug 2004
    St.Louis, MO
    25
    336
    Re: RE Comps
    thanks alot, think mill be looking into them in the near future
    Dec 2004
    Tuscaloosa, AL
    191
    Re: RE Comps
    dude i noticed you are bumping 2 RL-p 12" 4Ohm, like mooahh , ive got mine in about 1.25 sealed each runing with a NINe.1 which is probably about the same as your viper, these subs are NASTY, i know they bump loud as hell too in that Yukon, cause mine hurt in a '95 Camry.
    peace
    x2
  1. Need Amp and Comps for $300
    By StockDX in forum Speakers
    Last Post: 04-07-2005, 11:40 PM
  2. Eclipse Comps VS Type-X or DDLinears
    By Zinthesis in forum Speakers
    Last Post: 01-09-2005, 08:29 PM
  3. crystal CSc60s 6.5 comps
    By SMRHA in forum Subwoofers
    Last Post: 12-20-2004, 02:39 AM
  4. silk or titanium comps?
    By PoeticTragedy in forum General Discussion
    Last Post: 01-03-2003, 08:41 PM
  5. comps and bass blockers
    By CDJDX186 in forum Subwoofers
    Last Post: 07-10-2002, 02:53 PM
