+ Reply to Thread
Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 75 of 101
Reload Thread: Speaker FAQ
  1. #61
    PESteele's Avatar
    PESteele is offline I wang on an 8 in a van
    Dec 2005
    annapolis
    28
    3,425
    Re: Speaker FAQ
    anyone
    99 jeep cherokee on 32, Jvc kd-avx1, Elevation audio concert series speakers, kicker zx250.2, 2 Massive audio cw 12's, directed 1500d
    Refs- Twoohfour, SAG3, fo0manchu, guy022077, chris96camaro, frangka2, marcusb419er, XaznKewLguyX, Dj-torn, Milenko515, 6spdcoupe, foreman, tommelton(bimmerforums), burnzie2413, saywhat, Untouchable11, iceteebone, HarleyF150, Fi Car Audio, loud-n-low, dvrmstrng, Deucelee, MJ-tC, coachtjm, 80INCHES, jeepintn, sxkicker89, BiZkiT8u
  2. #62
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,449
    1 Post(s)
    Re: Speaker FAQ
    Quote Originally Posted by PESteele
    anyone
    Seriously...are you aware of the search fuction???
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
  3. #63
    May 2006
    Oakland, Ca
    112
    Re: Speaker FAQ
    learned a lot just by reading few paragraphs.. thanks a lot.
  4. #64
    AcidicDreams's Avatar
    AcidicDreams is offline I don't need one of these
    Jan 2005
    Auburn WA
    36
    3,965
    Re: Speaker FAQ
    http://www.passivecrossovers.com/#index
    Going 'active'
    A further improvement is the use of active crossovers. Unlike passive crossovers which are situated between the amplifier and the 'speaker drive-units, the active version is placed between the output of the preamplier and the input of the power amplifier.
    Active set-up
    Adding active crossovers is even better.
    One of the major benefits of active crossovers is that the amplifier has more direct control over the 'speaker drive-unit and can therefore control it more accurately. Think of it like this. If you (the amplifier) sit in the back of your car giving directions to a chauffeur (the crossover), who is driving the car (the drive-unit), you may get on fine at slow speeds, relaying your instructions, but if you were in a race, it would be much better for you to have (direct) control of the car yourself. Click HERE for a fuller explanation of active crossovers.
    Changing from passive to active control of your 'speakers will involve the following:
    * A separation of the preamplifier and power amplifier stages. If you currently use an integrated amplifier you will need to know where the circuit for the preamplier joins the power amplifier section.
    * One or more extra power amplifiers (you need one mono power amp channel per drive-unit ie one stereo power amplifier will drive two drive-units) These amplifiers need to have an identical specification as regards gain.
    * An active filter (crossover) circuit. You can either build one from scratch, from a kit or buy one ready built.
    * The removal (or disconnection) of the passive crossovers.
    * The possible alteration of the cabinet size and port tuning.
    I am a very big fan of active crossovers, having experienced the improvements they bring. Once you have an active crossover, it is also much easier to alter it to suit different 'speaker configurations than it is with a passive crossover.
    On the negative side, an active system costs more than a passive set-up due to the cost of the extra amplification. However, as sound quality is our ultimate goal, I feel that this extra expense is well worth it. And remember that building your own amplification will keep the cost down. See the Build your own section for links to some of the good amplifier kits available.
    There's only one thing better for 'speakers than an active crossover, and that is no crossover as I have discovered with my most recent 'speaker project which utilises some full-range drivers. (Click Here for details) However, even full-range 'speakers aren't perfect, often needing another unit to 'help' them cover the full frequency range.
    Driving a 2003 Lexus GS430 and a 1996 Lexus LS400
    GS430 - Massive RK Tweets/Crossovers + Phass MW650 NEO Mids, JBL GTO 755.6 amp, IDQ12v2 in 1cu ft sealed substage
    Refs: CA.com - excelerater, fosgate140, 99StangGt, desertheat, Frito, digital mint, dkguitarist, BoominBeast (didn't scam me), Fast1one, shiipseki, newtitan, Scoobydoo, spudracer326, sr_se-r, redlinese-r, James Bang, tweet02, effenay, and Mike Dressure ::: ECA - BBOYSTEVIE, Need-SQ ::: DIYMA - macxx, Kuztimrodder (very happy), and azngotskills
  5. #65
    Jan 2005
    Auburn WA
    36
    3,965
    Re: Speaker FAQ
    that was copy/pasted
  6. #66
    jacka's Avatar
    jacka is offline CarAudio.com Elite
    May 2006
    CA
    1,244
    Re: Speaker FAQ
    can you explain sensitivity of a component set? i know its not used to compare loudness, but i'm trying to understand what it is. also i don't get the 2.83 V/ 1m or the 1 W/ 1 M spec.
    References:
    Sold to: nauticagmo, 808bmw, hustler904, protocol_droid, latina33, dub22, morgans432, BassmentJack, Sr SQ (diymobileaudio), macxx (diymobileaudio)
    Bought from: sundownz, bjfish11, 6spdcoupe, 02TurboA4, ngsm13
  7. #67
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
  8. #68
    ndnbolla's Avatar
    ndnbolla is offline Jigga what?
    Nov 2004
    paradise
    1,673
    Re: Speaker FAQ
    I have a question about the crossover connections.
    I understand the tweeter attenuations (sp?) of 0db, -3b, and -6db which can be changed (usually inside the crossover) to you specific needs.
    However I have a question regarding the terminals of the crossover, specifically the tweeters'. In my case, I have Rainbow SLC crossovers where the tweeter can be connected to a the - but then either a 0db + or a 3db +.
    Which + terminal should be connected in what situations?
    EDIT: NM... I guess the + terminal for the tweeter just adds another degree to it's attenuation where it depends on the proximity of where the mid is located.
    Last edited by ndnbolla; 08-04-2006 at 01:08 PM. Reason: I guess I answered my own question
    A couple of hunters are out in the woods when one of them falls to the ground. He doesn't seem to be breathing, his eyes are rolled back in his head. The other guy whips out his cell phone and calls the emergency services. He gasps to the operator: "My friend is dead! What can I do?" The operator, in a calm soothing voice says: Just take it easy. I can help. First, let's make sure he's dead? There is a silence, then a shot is heard. The guy's voice comes back on the line. He says: "OK, now what?"
  9. #69
    lil azn 06's Avatar
    lil azn 06 is offline Senior VIP Member
    Sep 2005
    Houston Texas
    30
    388
    Re: Speaker FAQ
    If my Profi Kickbass are rated at 80 hz to 25khz, where would i set the crossover points at? (active)
    Currently i configured my HU for 80 hz-2.5 khz for the mids then 2.5 khz for the tweets.
  10. #70
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: Speaker FAQ
    Quote Originally Posted by lil azn 06 View Post
    Too many factors to answer this over the internet.
    Your best bet would be to start at the passive xover's frequencies and slopes, and then begin adjusting from there. Atleast then you'll have a target starting point to work from.
    Would be a big help if you could find an RTA to to use when adjusting the xover point/slope aswell.
  11. #71
    BlackMaxima's Avatar
    BlackMaxima is offline CarAudio.com Elite
    Jul 2006
    LA
    852
    Re: Speaker FAQ
    Good info guys thank you.
    very useful
  12. #72
    Bossmaan's Avatar
    Bossmaan is offline Junior Member
    Nov 2006
    Toronto, Ca
    Re: Speaker FAQ
    I have a Question...i've done this setup recently, only for testing purposes..I'm just wondering if there's a potential for any harm...this setup is in a 2003 camry
    I have the RF162C components..it comes with 2 sets of tweeters..i will be putting 1 pair in the door, and the other pair in the A-pillar soon enough...I have 3 1/2 inch speakers in the Top dash..I have a RF T4004 amp for the speakers..speakers and what not will be upgraded later to get the full potential of the amp..
    what I have done now to only test is and this is where I need feedback, I left both the tweeter sets in the door, and I wired the 3 1/2 inch stock speakers to the 'speaker' jack of the crossover...they seem to sound nice but i'm not sure if this causes any harm to crossover or the whole set...I've tried wiring it to the Tweeter ports, along with the current tweeters..it sounds alright but the highs get ridiculous, so I changed that...so is there a potential for damage to the components or overloading my crossover...
    my sub sub is set at 80hz (LP)... I'm wondering if i should set the crossover on the amp to all pass, low pass or High pass for the component set and the rear speakers..right now I've set my components to HP at 90hz, and rear speakers to AP 80...I've been busy so I havent had more than half an hour to spend on tuning, because I JUST put the amp in..so this is kind of half assed settings...
    I will be disconnecting the 3 1/2 inch speakers like originally planned, and just have a set of tweeters in the A pillar, and tune everything properly...unless you guys suggest not to disconnect em..
    sorry i'm kind of all over the place..i **** at explaining
  13. #73
    krisfnbz's Avatar
    krisfnbz is offline CarAudio.com Veteran
    Sep 2006
    Frederick MD
    32
    4,513
    1 Post(s)
    31 Post(s)
    Re: Speaker FAQ
    I love speakers!
    Yes that is a 5 1/4th audiobahn mid speaker in my civic's headrest. circa 2006.
    2000 Celica GTS
    Pioneer FH-X700BT
    Powerbass 2XL-60.3C 3 way
    Dayton Ultimax 15", sealed 4cuft
    Memphis 16-MC5.700 5 channel
    Knu wiring
  14. #74
    Angry Negro's Avatar
    Angry Negro is offline Junior Member
    May 2007
    Negroville
    Re: Speaker FAQ
    Anyone care to explain what it means to "phase" your speakers or "reverse phase" and how it is done? Benefits?
  15. #75
    atownbudzz's Avatar
    atownbudzz is offline Junior Member
    Aug 2007
    Aurora, IL
    Re: Speaker FAQ
    I have a question about Coaxial 6x9 speakers. I have 2 6x9 kicker ds650 and i have them hooked up to my amp. Everytime i push on the gas to my car a whistling nose comes out of the speakers. I dont no why and need to no how to fix it
+ Reply to Thread
