+ Reply to Thread
Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 101
Reload Thread: Speaker FAQ
  1. #46
    May 2005
    Tampa, FL
    106
    Re: Speaker FAQ
    I got a question for you guys.
    I was thinking about getting a pair of 6.5 DLS Iridum speakers but my car has a stock tweeter in the a-piller of each door. Now what should I do to get the most sound quality? Buy some good components and then buy 2 aftermarket tweeters to replace the stockers?
    Someone help a clueless person out, thanks!
  2. #47
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: Speaker FAQ
    Quote Originally Posted by Chowder Head
    No. The components will come with tweeters (and nice ones in that DLS Iridium setup). No need to add any more.
  3. #48
    May 2005
    Tampa, FL
    106
    Re: Speaker FAQ
    Midbass and midrange.....
    What are they exactly? Bass in mid note?
  4. #49
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    Re: Speaker FAQ
    subbass (low notes), are usually considered 80hz frequencies and below. - deeep pipe organ, low piano notes, some electric\string bass, techno, the 'rumbly' deep kind of bass, ect.
    midbass (middle notes on the low end) are usually considered 80~400hz frequencies - kickdrums, cello, electric\string bass, the 'punchy' kind of bass.
    midrange (upper middle notes) are usually considered 400~5khz frequencies - human male voice, some lower end female voice, drums, guitar, most of the music is here
    highs\treble\tweet (high high notes on the teeny weeny itsy bitsy strings /end strongbad) are usually considered 5kh~20hz and above - cymbols, guitar on the tiny little high strings, female voices, violin, and all that, the kind of sound that makes your ears hurt, aka - treble.
    those are just rough numbers, and can be argued to be lower\higher\broader\whatever... im not POSATIVE on the midbass\midrange numbers, but im sure they are close to those numbers.
    this chart is kinda cool;
  5. #50
    May 2005
    Tampa, FL
    106
    Re: Speaker FAQ
    Thanks req! That helped out a lot.
    Another thing. In my 95 Mustang, 6X8's can fit in the front. Would I have fitment issues if I want to add a set of 6.5 component speakers or will they slide right in?
  6. #51
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    31
    15,596
    22
    Re: Speaker FAQ
    with an adapter baffle you can fit a 6.5 in that 6x8 slot
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
  7. #52
    Nov 2004
    TriState Area
    32
    3,888
    23
    Re: Speaker FAQ
    Quote Originally Posted by Acidburn
    jigsaw + measurements + wood = insta baffle
    myspace
    1993 Volvo 960 Luxury Sedan
    Refs: Sake Pho Sho, Silentheaven389, macmood, iamslain, lemans23, desertheat (3), monte_carlo97 (7).
  8. #53
    Justintoxicated's Avatar
    Justintoxicated is offline CarAudio.com Elite
    Jun 2005
    San Diego, CA
    885
    Re: Speaker FAQ
    I made some adapters for my iridiums in my most recent post on this forum. Check it out for some ideas, my adapters were for 6x9's to 6.5's so it should give you some ideas
    The DLS tweeters are very nice!
    Mine are installed in the dash, however I have some time alignmet stuff on my HU where I can select Dash, Pillars, Door, Kicks etc... that helps with the imaging.
    Truck:
    Nissan Titan KC
    HU:
    Eclipse CD7200 MKII HU
    Speakers:
    DLS Iridium 6.2 Front Stage
    TC1000's,
    AMps:
    Arc Audio XXK 2100 for fronts, Diamond Audio D5 1200.1
    Other:
    Knukonceptz 0 & 4ga and all Speaker wire and Streetwires 0 ga Power/Ground Distro Block, 4.5 rolls 60 mil RAAMAT and Ensolite foam througbhout, Kintetik HC2000 The Big 3 + 0ga Gounding Kit.
  9. #54
    Shocks's Avatar
    Shocks is offline Member
    May 2005
    Orange County
    48
    Re: Speaker FAQ
    Sup everyone I am a noob to car audio and have a quick quick question. I have some Focal 165 k Comps powered by a US amps Merlin md42 and love the SQ. I have them High Passed and would like a little bit more midbass. Should I use the passive x-over or the one on the amp? Also can anyone recommend a good x-over setting for the Focals?
    Thanks guys
  10. #55
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Re: Speaker FAQ
    Not quite sure I understand your question? The passive crossover will not affect the low frequency output (midbass) of the speakers since it doesn't contain a highpass filter. The only way to highpass them is with the crossover on the amp
  11. #56
    omarmipi's Avatar
    omarmipi is offline Senior VIP Member
    Sep 2005
    Houston, Texas
    39
    371
    Re: Speaker FAQ
    Great reading! I am glad that I started by reading this faq because I found exactly what I was looking for. My 1st question deals with crossovers and my 2nd question was pretty much answered already.
    1.) I have a Boston rally R61 component set currently for my front stage and a 6.5" CDT EF comp set in the rear. They are both, currently, powered only by my head unit (Alpine 9827 - I am looking for a 100W x 4 amp). I just purchased a Autotek 2 ch active crossover and was wondering if it would provide any SQ benefit. Also would it be ok to run both the passive and active crossovers together?
    2.) I just bought a pair of Boston R620 Midrage speakers that I was going to replace with my current Boston R61 Midrange speakers for more front stage sound. Do you think I this is a good idea or should I just replace the entire set? My CDTs dominate and I do not want to have to fade the output to the front. I would swap the sets but my CDTs cannot fit in the front door.
    Thanks in advance
  12. 02-11-2006
    Junior Member
  13. #57
    jimh's Avatar
    jimh is offline Junior Member
    Feb 2006
    Warrenton, VA
    Re: Speaker FAQ
    Some things I don't see mentioned here that might be of use.
    I know there is always the talk of getting the bass up front. BUT if you are mounting the mids/midbass in the stock door locations firing directly sidways you might be better off with a smaller driver if you have subs. A smaller driver images much better of axis than a larger one. For example a 5.5 will have a better soundstage in the example than a 6.5, etc.
    The higher the order of a xover the more it will protect a driver with a steeper cutoff. The higher the order the more it will mask little nuances in the music too. So it is a big trade off.
    Passive x-overs: Even orders (2nd, 4th...) keep phase and odd reverse phase (1st, 3rd...). So if you are designing your own make sure to reverse + & - speaker wires for odd units.
    Digital elctronic xovers do not do this.
  14. #58
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Re: Speaker FAQ
    Quote Originally Posted by jimh
    It's not always that simple to determine something like that. That theory assumes that all of the drivers are equidistant from your ear (which is hardly ever the case in car audio). Also, phase is not constant. For a first order lowpass crossover (for example), the driver's response is shifted 45 degrees at the xover frequency and only the xover frequency. Plus those slopes don't account for the driver's natural rolloff....you might have a 12db/oct electrical slope, but a 24db/oct acoustical slope because of the driver's natural rolloff.
  15. #59
    NJack2AF's Avatar
    NJack2AF is offline Best Member Ever
    Nov 2004
    Las Vegas
    1,104
    1 Post(s)
    Re: Speaker FAQ
    Sry nm. Excellent thread btw though I learned a ton reading this!
    No setup at the moment
    Refs:
    Ricktc, Mr. Loki-x2, SPL140.2
    jimmyslide, Ruckus, Moe Lester
    Milenko515, skeptikal, haunther,
    amartin_72, DARKHART
  16. #60
    PESteele's Avatar
    PESteele is offline I wang on an 8 in a van
    Dec 2005
    annapolis
    28
    3,425
    Re: Speaker FAQ
    can someone explain active crossovers in detail and how to use them/what they do. I didnt see it in here
    99 jeep cherokee on 32, Jvc kd-avx1, Elevation audio concert series speakers, kicker zx250.2, 2 Massive audio cw 12's, directed 1500d
    Refs- Twoohfour, SAG3, fo0manchu, guy022077, chris96camaro, frangka2, marcusb419er, XaznKewLguyX, Dj-torn, Milenko515, 6spdcoupe, foreman, tommelton(bimmerforums), burnzie2413, saywhat, Untouchable11, iceteebone, HarleyF150, Fi Car Audio, loud-n-low, dvrmstrng, Deucelee, MJ-tC, coachtjm, 80INCHES, jeepintn, sxkicker89, BiZkiT8u
+ Reply to Thread
