Results 1 to 6 of 6
Reload Thread: Amping components question
    Zacmc212's Avatar
    Zacmc212 is offline Senior VIP Member
    Oct 2004
    FL
    285
    I have a Set of compoenets that are 50 watts rms. Does that mean i can only send 50watts to the crossover? or that the mid and tweeter will take 50 watts and i can send 100watts to it. The reason i am aksing is cause i have a gm-5000t laying around and it sends 125 watts rms x2 and i was wondering if it mwould work with them.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Re: Amping components question
    125w would likely be too much for them if they are only rated 50w RMS. However, with proper xover point selection and very conservative gain setting, that amp would likely work well with them. However, it would require use of caution and common sense. If those are two things you lack, don't try it.
    Zacmc212's Avatar
    Oct 2004
    FL
    285
    I dont think i can choose a crossover point, i opened it up and i didnt see a litle switch thing.
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Quote Originally Posted by Zacmc212
    I meant crossover point on the amp, not on the passive.
    Zacmc212's Avatar
    Oct 2004
    FL
    285
    O ok.....what should i set it at?
    And also i have a nine.1 with a rca output, if i use that wouldnt that create problems with fading back-forth and left-right? and would it cause any other problems?
    loserpunk's Avatar
    loserpunk is offline hapbahdasindot
    Jan 2003
    Elkhart, Indiana
    26
    1,878
    39
    the xover point will depend on the components, and, the size of your mids, if you're going to be sending them that much power, i'd plan on hpf on the comps @ around 100 and work from there, but it will vary depending on vehicle, install, and comps
    -jordan-
    msn - jeby97@hotmail.com
    aim - bumpinking
    REFS -
    rockingchair69
    tirefryr
    magick_man
    cjj2d
    ssj2xxgotenxx
  1. Focal components question
    By awdeo in forum Subwoofers
    Last Post: 02-23-2005, 12:39 PM
  2. Strange Question about Components
    By DJ Jester in forum Speakers
    Last Post: 02-23-2005, 08:22 AM
  3. Question about mounting Memphis 8" components
    By Passat 35i in forum Subwoofers
    Last Post: 11-11-2002, 07:17 PM
  4. Amping components? (wiring)
    By JonBoy in forum General Discussion
    Last Post: 08-29-2002, 06:47 PM
  5. Newbie question for components....
    By MadMarv in forum Amplifiers
    Last Post: 04-08-2002, 01:17 AM
