Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: Tweeter Output
    MikeS's Avatar
    MikeS is offline Member
    Jan 2005
    L.A.
    149
    Tweeter Output
    Hey guys,
    I was kicking around listening to some comps today at various stores and noticed that a lot of the sets I listened to seemed to have pretty mellow output from the tweeters. If I covered them with my hand I didn't lose a whole lot of sound. Is this normal?
    I put some cheap-o tweeters in my car to make up for the very low output of my DEI tweets and it is night and day without them. How much of your overall signal do you guys feel is/should be coming out of your tweeters? If you cover them in your cars do you notice a HUGE drop in high end, or is it pretty subtle?
    As you can probably tell, I'm a little confused now. I was gonna replace my comps with something new because my tweeters put out so little high end, but if the ones I replace them with don't put out much more then it seems like I'd be wasting time and money....
    Thanks!
    Mike
    desi_daru's Avatar
    desi_daru is offline CarAudio.com Elite
    Nov 2003
    BC, Canada
    543
    Re: Tweeter Output
    u should b able to change the level in the x-over
    mine are 0 -3 n -6 db i beleive, i think mines cranked at 0
    i blew my tweeters b4 n i missed my tweeters soooooooo much i felt like cryin, so yes if i cover them wif my hands i can tell very much so the difference
    Car - 04' Honda Civic Si, silver
    Deck - Clarion ProAudio DXZ835MP
    Fronts - Alpine Type-R SPR-136A (5.25" comps w/ 1" tweet)
    Speaker Amp - MTX Thunder404
    Sub - 1x Rockford Fosgate RFP3412 ported box
    Sub Amp - Rockford Fosgate Punch 150S
    Wiring - power/ground 4guage, speaker 16guage
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Re: Tweeter Output
    Well, in most comp sets the mids are the speakers that play the frequencies in which most of the musical content is located.
    MikeS's Avatar
    Jan 2005
    L.A.
    149
    Re: Tweeter Output
    Quote Originally Posted by squeak9798
    The mid driver certainly contains the majority of the fundamental musical content, but the tweeter is essential for establishing clarity and stereo image. The upper frequencies contribute largely to what makes a guitar sounds like a guitar, a sax like a sax, and a voice sound unique. These, among other reasons, are a huge part of why seperating the tweeter is so desirable in the first place. I'm sure you know all that, so I guess I'm just saying that I want to be able to hear the high end in my system if I'm going to the trouble and expense of dealing with seperates.
    In some of the speakers I was listenig too I was getting more high frequency content out of the coaxs than the comp systems, and this seems contrary to what I'd expect...
    desi_daru's Avatar
    Nov 2003
    BC, Canada
    543
    Re: Tweeter Output
    are all the settings correct on ur deck, xover, amp?
    MikeS's Avatar
    Jan 2005
    L.A.
    149
    Re: Tweeter Output
    Yeah, everything is set up fine. The x-over is passive with no settings for tweeter output or anything like that. I attached Optimus tweeters in the tweeter outs of the x-over and it has **** loads of level. I'm currently running them off the HU, but I did test them with an amp to see if power was the issue. I threw 150 or so watts RMS at them and they were still practially inaudible with my ear an inch or two from the tweet.
    I'm an audio engineer (and musician) by profession and have worked in QA for pro recording products, so my troubleshooting skills are pretty strong. I've tried different power sources, different crossovers, different tweeters, etc. and everything points to the DEI tweeter. They both do it(or don't do it), which is the weird part. They get signal, but they put out almost nothing even when cranked.
    These are supposed to be pretty nice, which is why I bought them in the first place, but they never worked. At the time I had them "professionally" installed but have since torn everything apart trying to figure this out. I'd love to get them working, but had given up on them as a bum pair. I'm still planning on just getting a new set of comps, but I was shocked today to hear not a whole lot coming out of some of the comps I auditioned...
    I'm TOTALLY open to suggestions, ideas, etc...
    Thanks,
    Mike
    packerfan's Avatar
    packerfan is offline CarAudio.com Veteran
    Jan 2003
    Beaver Dam WI
    26
    3,809
    Re: Tweeter Output
    Get some 1" metal dome tweets, those will scream in your ears. Also, if you have your tweets in the doors or kick that will lower the sound stage and also make it seem like the their not that loud. Try mounting in the A piller or getting some good metal dome tweets.
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
    9 Elemental Designs 13Ov.2's (15.5 cu ft ported box)
    O/1g All around, 2 Yellow tops, big 3.
    packerfan's Avatar
    Jan 2003
    Beaver Dam WI
    26
    3,809
    Re: Tweeter Output
    Also, what you hear in a shop wall is TOTALLY different then what they will sound like in the car. Keep that in mind...
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
  9. #9
    MikeS's Avatar
    Jan 2005
    L.A.
    149
    Re: Tweeter Output
    Quote Originally Posted by packerfan
    REALLLLY good point. Thanks for that.
    I don't necessarily want piercing, ridiculous highs(I'v got that with thes Optimus ones), I want nice, detailed and smooth highs. Hmm...I'll do some more listening and see if I can find something I'd like better.
    Thanks guys.
    Mike
  10. #10
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Re: Tweeter Output
    You sound like a prime candidate for horns
  11. #11
    getstoked05's Avatar
    getstoked05 is offline Member
    Jan 2005
    ATL
    88
    Re: Tweeter Output
    i tried horns-it's very easy to over power them! they sound great once you get them tuned right. i tend to hit the horn every time i got in the car. the only thing i didnt like about the horns is the sound came from the front not left to right
  12. #12
    MikeS's Avatar
    Jan 2005
    L.A.
    149
    Re: Tweeter Output
    I've noticed the horn talk on these boards. I just can't picture it. I guess I've been around too many PA cabs so I just picture this huge horn sticking out of my dash. Do they sound good? Most PA cabs are kinda crappy sounding from an audiophile perspective, and the horn is part of it. The dispersion is needed to cover a big room, but the imaging goes out the window and the highs tend to be pretty nasty.
    I checked out a few more comps tonight. I heard the lower end RF ones and they sounded WAY better than the Kenwoods and Pioneers next to them. I heard some Infinities and didn't really like them that much, but they were okay....do you guys like the new RF stuff? They were the **** back when I was more into car audio (mid 90s).
    Thanks!
    Mike
  13. #13
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Re: Tweeter Output
    Quote Originally Posted by MikeS
    Team Image Dynamics seems to have pretty good luck with them
    http://usdaudio.com/tutorials/wg-tut1.php
    http://usdaudio.com/sw/cars/
    Horns can have horrible results when not tuned properly; just like any other speaker in the world. But, now that I've had horns, I'll never go back to tweeters; that's a promise. IMO the sound is much fuller and lively, much more dynamics and "up front" so to speak. So far, in my listening experiences, the only tweet/mid comp set I've heard that I've liked even remotely close to as much as my horns are the Boston Z6's.
  14. #14
    MikeS's Avatar
    Jan 2005
    L.A.
    149
    Re: Tweeter Output
    Wow, that is pretty amazing. I'd love to hear one. Looks like an intrusive install to say the least! Maybe I should just get a power inverter and bolt some studio monitors on my dashboard!!
    Mike
  15. #15
    allsport513's Avatar
    allsport513 is offline Resides on Planet Audio
    Dec 2004
    League city
    26
    48
    Re: Tweeter Output
    my freind put six tweeters in his car how usefull is that
  1. Tweeter Install for best imagine help!
    By shtoops in forum Wiring, Electrical and Installation Help
    Last Post: 10-08-2004, 03:57 PM
  2. Tweeter can be install in this way..........?
    By Martin in forum General Discussion
    Last Post: 08-02-2002, 01:03 PM
  3. component tweeter placement question
    By crzybob77 in forum Subwoofers
    Last Post: 07-06-2002, 04:37 PM
  4. Replies: 3
    Last Post: 02-06-2002, 03:23 PM
  5. Amp Class Question
    By CheapPyramidStuff in forum Amplifiers
    Last Post: 01-10-2002, 07:12 PM
