Results 1 to 10 of 10
Reload Thread: Good 6 1/2" Driver
    Jonahdude's Avatar
    Jonahdude is offline ?????
    Feb 2004
    Florissant, MO
    24
    718
    Good 6 1/2" Driver
    Are Dayton 6 1/2 woofers any good? Specifically the DC160S-4. What else would be a good choice for a 6 1/2" driver, 4 ohms, with a frequency response that's at least 80hz-3khz, for less than $40 a pair? I'm looking to build my own component set.
    New setup in the works:
    Vehicle: 1999 Ford Windstar
    Head Unit: Pioneer Premier DEH-P860MP
    Signal Processing: Profile Q100 3-Way active crossover, set to 80hz and 3.5khz
    High Pass: the legendary Aura tweeters powered by a Pioneer GM-3000T
    Band Pass: Ascendant Audio 6.5" Poly Midwoofers powered by a Pioneer GM-5000T
    Low Pass: Elemental Designs 19Ov.2 in 3ft^3 tuned to 30hz, powered by a Power Acoustik 2APC-1400
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Re: Good 6 1/2" Driver
    Check out the Dayton Reference series
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    24
    718
    ttt
    kappa546's Avatar
    kappa546 is offline CarAudio.com Elite
    Oct 2003
    Texas
    28
    922
    you probably have to boost the budget just a bit. but yea check out the dayton refs.
    -andre
    DRZ9255 - Linear Power DPSQ50 (modified) - Linear Power 2.2HV - CSS SDX7 - Peerless 830987 - Alpine SPX PRO tweeters - AE IB15
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    24
    718
    Is Goldwood any good? Specifically this speaker:
    http://www.partsexpress.com/pe/showd...number=290-308
    Bartak1's Avatar
    Bartak1 is offline CarAudio.com Elite
    Oct 2004
    Nebraska
    593
    Definatley go with the Daytons before the Goldwoods.
    Im also looking to make my own comps. What kind of crossover do you plan on using?
    What about the tweeter.
    Ive been looking at the Dayton Classic 6 1/2 inch woofers, and Audax TM025F1 tweets, and probably a dayton crossover. Adds up to only 120ish bucks.
    Eclipse CD8053
    Arc Audio XXK4050
    Rainbow ProVandis ran active
    Arc Audio XXK1500
    (2) SI Gen2. Mags
    Refs: FoxPro5, MastaFlex, LeX, Valant_94gt, eBay account too.
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    24
    718
    I'm going to be using Aura crossovers and Aura 1" silk tweeters from the MR62 component swet. You can get the crossovers and tweets for less than $60 shipped from desertheatracing@yahoo.com, if you're interested.
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Quote Originally Posted by Jonahdude
    Then you need to verify what impedence drivers that crossover was designed for. If it was designed for use with a 4ohm mid, then you can't use an 8ohm mid (well, you can, but the results would likely be less than stellar).
  9. #9
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    24
    718
    It's 4 ohm, so I've only been looking at 4 ohm drivers.
  10. #10
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    24
    718
    Help me!!!
  1. winISD PRO driver question
    By req in forum Enclosure Design & Construction Help
    Last Post: 10-21-2004, 03:56 PM
  2. need help finding right 12' SQL driver
    By tweekerz in forum Subwoofers
    Last Post: 10-19-2004, 06:34 PM
  3. line driver? would i need 1
    By qxfosgatesvt in forum General Discussion
    Last Post: 08-15-2002, 12:08 AM
  4. Which Driver to Purchase ? Expert Advise Needed
    By Unregistered in forum Subwoofers
    Last Post: 03-25-2002, 03:50 PM
