Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: Get Out Of That Bed!!!
    IHFJ05's Avatar
    IHFJ05 is offline Banned
    Jan 2005
    warmwomb,female
    45
    look i cant sleep because im running out of time to find some good components. i listen to 100% metal,trying to find a component that can take a beating. currently money is not an issue-just want to get my truck jaming so i can bang my head up against the windshield. i need kick a-s-s midbass!! please help a head banger go deaf THANX!!
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,369
    Re: Get Out Of That Bed!!!
    Get some help, then come back when your sane
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    Quote Originally Posted by IHFJ05
    Bye bye beezlebub
    IHFJ05's Avatar
    Jan 2005
    warmwomb,female
    45
    well i got a big show to promote on the 01/23/05 and i need my truck done. i need to find the right components-im tempted to bust out my idq8's and run with those
    supa_c's Avatar
    Apr 2004
    In a chair
    19,369
    Just use the ID's then
    IHFJ05's Avatar
    Jan 2005
    warmwomb,female
    45
    you have run horns with those things dont you? i think i need a soft ribbon tweet for metal-right?
    supa_c's Avatar
    Apr 2004
    In a chair
    19,369
    Nope, you can run any tweeter.
    Metal= usually harsher
    silk= not as harsh
    But thats not the case all the time
    weeter Treatise
    Major Considerations:
    Cost –
    Power - power handling - the ability to play loud
    Control - transient response – the ability to stop and start instantly – openness and transparency result
    Energy – the ability to maintain a wide radiation angle at high frequencies
    Size – Will it fit in the “installation”?
    Extension – frequency response – high for maximum “air” and low for more midrange content
    Basic Types:
    Balanced drive (cone) – various materials
    Soft dome – cloth (silk), “poly”
    Hard dome – metal, ceramic on metal, ceramic, paper, diamond
    Ribbon – flat and folded (Heil)
    Ionic – typically spherical
    Electrostatic – requires high voltage bias and drive voltage
    Piezoelectric - either crystal or film
    Any of these can be horn loaded.
    The least expensive design for the results obtained is the balanced drive type. This small flat basically cone type driver is found on the vast majority of off the shelf two-way speaker systems. These are mounted on various posts and brackets in front of the mid-bass driver. Power, control and extension on the low side are sacrificed. Transient response can be good but is usually sacrificed for efficiency to reduce burnout problems. Ultimately power handling cuts this approach short.
    Probably the most popular driver type used in higher quality installations is the soft dome. Here an inherently larger voice coil allows softer heavier diaphragms to be utilized. These can provide excellent transient response. The weakness in this approach is a somewhat soft top-end. This can sound pleasant with smooth-listening type music but excitement and realism is diminished on really clean dynamic source material. This is technically a rapid energy response decline in the top octave. The top octave is 10 to 20 thousand Hz.
    The ribbon, ionic and electrostatic types have excellent transient response but only the ribbon is practical in a car. The limitation here is power response. The large surface area is excited evenly giving reduced dispersion. Some newer types have graduated drive and damping to improve this but the line source construction only provides extended dispersion in one plane. It should be noted that very large area sources of any technology, provides good top-end if listened to close up in the so-called “near field”. This only applies to very large diaphragms. For instance a ribbon drive headliner. This degree of elaboration has not been commercial to date.
    Piezoelectric devices do not survive well in high temperature environments. Electrostatic speakers are large and require special high voltages to operate. Ionic types take this to an even higher level and are not really practical.
    The hard dome – done right – is the optimal choice for practical automotive sound systems. The small size, flat energy response, moderate cost and good power handling offers the best balance of parameters. Until recently hard dome types have had a somewhat hot sound due to response variations right at the very top of the response end. These deviations have recently been engineered out of the response to a sufficient extent to put the best metal domes ahead of the soft dome.
    Ceramic and other non-metallic super hard materials have been used as diaphragms. These are excellent but are very expensive as a rule. If the price comes down those with adequate power handling will begin to appear in the automotive environment. Currently they only appear in high-end audio home speakers.
    IHFJ05's Avatar
    Jan 2005
    warmwomb,female
    45
    what would you do SUPA C?
  9. #9
    supa_c's Avatar
    Apr 2004
    In a chair
    19,369
    Pick up some tweeters/x overs
  10. #10
    supa_c's Avatar
    Apr 2004
    In a chair
    19,369
    Are those ID 8's 2 ohms ?
  11. #11
    IHFJ05's Avatar
    Jan 2005
    warmwomb,female
    45
    no i thier 4 ohm- i think let me go check
  12. #12
    IHFJ05's Avatar
    Jan 2005
    warmwomb,female
    45
    what happened to you mr. supa c
  13. #13
    supa_c's Avatar
    Apr 2004
    In a chair
    19,369
    Nothing. Im fine
    There was an ebay auction for some 2 ohm x overs, thats why i asked
  14. #14
    IHFJ05's Avatar
    Jan 2005
    warmwomb,female
    45
    since mine are svc 4ohm could you wire them to the amp in a 2 ohm load?
  15. #15
    supa_c's Avatar
    Apr 2004
    In a chair
    19,369
    yep, but thats only 1 channel
  1. If you can figure this out.....
    By loko_pocho808 in forum General Discussion
    Last Post: 12-13-2004, 11:32 PM
  2. would you do: 2 Shiva 12s or 1 Koda 10?
    By dan7532 in forum Subwoofers
    Last Post: 10-08-2004, 08:19 AM
  3. 98 Siverado
    By JL in forum Wiring, Electrical and Installation Help
    Last Post: 03-18-2002, 04:08 AM
  4. 1993 Gmc S-15
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 01-24-2002, 08:23 AM
