Deck: Sony CDX-F5705X
Trunk: 24 - 150Hz ( 3 MTX 10" 8104a ) ( Sealed, 1.8"^3ea )
SAmp: Hifonics BX1500d
Wiring: KnuKonceptz; 4ga power, 8ga speaker; etc.
Impedance: 1.33 Ohms
Rear: xxx - xxxxHz ( Need 6.5" midbass )
RAmp: TBD, based on 6.5" specs
Wiring: Generic
Impedance: TBD
Doors: xxxx - xxxxx ( Need 4" highs )
CAmp: Run from deck?
Vents: xxxxx - xxxxx ( Included with comp set? )
TAmp: Run from deck?
Would like a solid midbass with good extension; no enclosure feasible, so they'll be sharing the trunk, for the most part;
4" should carry the range, and should be loud enough with low feed;
Tweets don't need a ridiculous upper spectrum; Just enough to fill.
Where would you go with this on a reasonable budget?
6.5s & tweets ~ $80 - $130
4s ~ $50
Of course, if a good speaker should run more or less, I'm open to that =)
My main concern is the 4", the factory Bose are flappin' in the wind; Which suggests a lot to me, including that Bose integrated a way-off crossover, and speakers not suitable for such an open "enclosure" as the doors.
I also imagine the factory 6.5" won't stand up to the 10s;
Register To Reply
Bookmarks
