Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Reload Thread: Rear fill overkill?
    OdieTRP's Avatar
    OdieTRP is offline Senior VIP Member
    Nov 2004
    Central, NY
    161
    Icon32 Rear fill overkill?
    I have a set of Type X comps for the front, was going to buy a set of coax's for the rear fill, but still have another set of Type X's I could use instead. They are going on the rear deck in 6x9 slots but I have an adapter plate that will let them fit easily. Would this be too "good" for the rear fill? They will be powered by a PA 75x4 amp so power is not an issue. Before you give opinions that you wouldn't use a rear stage, please keep in mind that it's not my car and rear speakers are a must. I'm also curious how much more difficult it would be to tune correctly. Thanks for all the knowledge.
    OdieTRP's Avatar
    Nov 2004
    Central, NY
    161
    Re: Rear fill overkill?
    One other thing too; I won't be adding a sub to the system until spring, just fyi.
    fossil99ca's Avatar
    fossil99ca is offline Member
    Apr 2004
    Toronto
    86
    I would consider bridging your amp to give you 150 x 2 (if possible) to the fronts and using the deck amp to power the rear fill. You can always fad out the rear to your liking or kill it altogether. This will make the car owner happy because they still have sound back there. 150 to the front gives you lots of head room and avoids clipping. If the speakers cannot handle 150, turn the gains down or the volume.
    If you have speakers lying around, why not install them. Having tweeters in the rear pulls the sounds stage back which isn’t good IMO. But again you can always fad them out when you are in the car. Although the other person driving the car would probably never notice if the fronts sound good enough.
    When you get your sub you can always un-bridge the fronts, and use two channels for a sub or get another amp for the sub.
    Disclaimer: I do not know all the specs on your equipment so please check the owner’s manual to see if everything is do-able (i.e. bridging your amp, etc)
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Why is it a "must" to *** up the imaging?
    Rear speakers - run em off the HU. Never amp them. Don't use components.
    Unless the front stage is so weak that you have no choice, in which case the rears will be your primary speakers and nothing is "too good".
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    MetalMaxima's Avatar
    MetalMaxima is offline AURAL DESTROYER
    Dec 2004
    The Garden State
    36
    1,142
    Quote Originally Posted by maylar
    I am assuming that everyone downplays rear fill due to the poor imaging provided by OEM speaker locations. Would adding a quality rear fill have an increased effect if you could change the imaging?
    I have a large rear backseat and am considering running a set of midbass or comps using a fiberglass panel down the middle of the rear seats OR mounting a set on top of the rear deck using fiberglass pods to point them out instead of up. Would this not create a noticable change in the rear fill? ...or is this just wishful thinking?
    HU - Alpine 9833
    FRONTSTAGE - Dynaudio MW170, MD 100, Morel Domes (all passive )
    REAR-FILL - Rainbow SL 165
    SUB - 2 x 12" Alumapro Alchemy RX
    AMPS - Arc Audio XXK-4150/2500
    WIRING - Stinger Expert
    SQ CABIN 160sqft. Damplifier, 120sqft. Spectrum, 100sqft. Hazmat, 80sqft. Spectrum Sludge...[/SIZE]
    OdieTRP's Avatar
    Nov 2004
    Central, NY
    161
    Because it's what she wants, plain and simple. She carries passengers and wants rear speakers. It is not up for debate! Were it my system there would be no rear stage.
    I understand the theory that the best speakers should be up front for staging, imaging, etc. The Alpine Type X's are rated at 70 RMS (2003 models); bi-amping them would fry the tweet wouldn't it? Even bridging the amp would put at least 150 per ch to them which is way more than they're rated for. I got them new for $150/set and bought two sets. I am trying to prevent spending a lot money and could put the other set in the rear. Why should I spend even $50 for a set of Planet Audio coax's or $100 for Type S 6x9's that will sound like **** when I have a good set of speakers to put back there? It's one heck of a dilemma and paradox, can the rear speakers be too good? The HU is a 9830. If I do put coax's back there, can the 4 channels from the HU be bridged to two and run off the rear RCA's to get 36w per channel?
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    I am bi-amping my Type X comps, just keep the gain down on the tweets or use the attenuation circuitry on the crossover.
    themainjam's Avatar
    themainjam is offline CarAudio.com Elite
    Aug 2004
    Minden, nv
    969
    well i was running 100W to the type R 5.25 and they handled it just fine.....
    i have another question though. in my 4 runner i have 6.5 up front which i am going to put some orion p6.2 and in the rear they have enough room for my 5.25 Type R... i was thinking of setting it up like this..
    6.5.........6.5
    .....S.....S
    5.2.........5.2
    .....S.....S
    the "S" stand for the seats where people sit. so that would give good imaging and shouldnt interfere with the front because the seats will absorb most of it...
    '99 Toyota 4Runner
    _____________________________Condition_____Price Paid
    H/U: Pioneer Premier DEH-630 ____(Installed)_____$100 Used
    Front: Orion P6.2 Comps_________(Installed)_____$150 New
    Rear: Alpine Type R 5.25 Comps_ (Not Installed)___$50 New
    Subs: (1) 10" Alpine Type X Sealed. (Installed)____$50 New
    Sub Amp: Hifonics BX1500D ________(DOA)______$80 Used
    Comp Amp: Orion 8004 100 RMS X 4 (Installed)____$230 New
    AIM = TheMainJam
    MSN = [email protected]
    YIM = all_star09
  9. #9
    fossil99ca's Avatar
    Apr 2004
    Toronto
    86
    I don’t think you can bridge a HU because they are not 2 ohm stable. Don’t forget the amps in the HU are like the size of your thumb. Bridging your amp (I believe) should quadruple your power. Like my JBL amp is [email protected], [email protected] and 160x2 bridged only at 4 ohms. At 2 ohms bridged it would be 320, not recommended. So you’re your HU would be 72 watts bridged, again not recommended.
    Rear fill is not a paradox, its personal preference. Try it at 70x4, if you like it, keep it. You always have the fader. If not, just disconnect them.
    Yes you are taking more of a risk with 150x2 for them blowing but less for clipping them. Depends how much you push your amp at 70 watts.
  10. #10
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,431
    ok, here it goes. "Front stage" comes fromt the fact that live music is played in front of you right? how the music was intended to hear is what audiophiles are constantly trying to reproduce. if you have rear fill it only takes away from your front stage. i hope that is helpful
  11. #11
    OdieTRP's Avatar
    Nov 2004
    Central, NY
    161
    Quote Originally Posted by OdieTRP
    Why is it so **** difficult to get info without people trying to change the system? READ THE POST! I don't care if you think just having a front stage is the best way to do it; for the last f'ing time I KNOW THAT! Now, this has been a great forum for me to learn and get info. But, to be blunt at the risk of being rude, your opinion on whether or not to have a rear stage is irrelevant, meaningless, a waste of time, useless and furthur more lacks common sense because you can't bother to think critically about the problem at hand! For those of you willing to help with the problem I can't thank you enough and will be more than happy to share any knowledge I have. For those who need to interject their front stage only opinion, stay the hell out!
  12. #12
    themainjam's Avatar
    Aug 2004
    Minden, nv
    969
    ok i would try to put the comps in the door (if 4door)and face the tweeters back. but if you cant do this and are going to run them in the rear deck then a cheap set of coaxials might be a better choice then using the comps.
    1. coaxials will be just as good if not better than comps(because comps are for imaging while coaxials play good from off camber surfaces.)
    2. comps facing up and tweeters facing forwar will mess up the front stage...
    3. you can run coaxials off Hu power without worrying about underpowering them....
    '99 Toyota 4Runner
    AIM = TheMainJam
    YIM = all_star09
  13. #13
    themainjam's Avatar
    Aug 2004
    Minden, nv
    969
    P.S. hope i helped
    '99 Toyota 4Runner
    AIM = TheMainJam
    YIM = all_star09
  14. #14
    OdieTRP's Avatar
    Nov 2004
    Central, NY
    161
    Quote Originally Posted by themainjam
    P.S. hope i helped
    That is very helpful, thank you! I have two sets of comps but will probably now use only the one in this car. Anyone have a set of decent coax's (6x9 or 6.5) for cheap?
  15. #15
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    I have to agree with the topic starter, this did go way off. Look, I see absolutely no problem making a baffle and sticking the tweet and the midrange next to eachother on it. Obviously keep the gain a bit lower than the front so its not completely pulling the stage back. Also it can be turned down quite low, because all the passengers heads are going to be less than a foot from the speaker. I say do it
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
  1. Rear fill to Front speaker ratio.....(long)
    By Pl8er in forum General Discussion
    Last Post: 02-22-2008, 02:59 PM
  2. Cancel rear fill upgrade? How many did this?
    By Getwild2 in forum Speakers
    Last Post: 12-22-2004, 03:56 PM
  3. Rear Fill?
    By JoseMCeee in forum General Discussion
    Last Post: 11-27-2004, 06:05 PM
  4. Rear Fill?
    By DJ FADE in forum Speakers
    Last Post: 10-27-2004, 06:32 PM
  5. Xtracab pickup, is rear fill needed?
    By toneddie in forum Subwoofers
    Last Post: 03-14-2002, 02:01 AM
