Results 1 to 14 of 14
Reload Thread: Truck: do I need front and back spks.???
    Kaos's Avatar
    Kaos is offline Member
    Jul 2003
    Coastal N.C.
    87
    I have a Ranger w/ 4 speakers and a pair of 10" subs. I am looking into getting some componet spks. to replace the front 2 spks. in the truck, is it necessary to replace the back w/ componet spks. also or do I just unhook them? TIA.
    Quote Originally Posted by EarDrummin.
    Uh.. I could be wrong. I could be really wrong. But what if I'm right? ****, I don't know. I'm right, I think.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Re: Truck: do I need front and back spks.???
    Just unhook them
    Kaos's Avatar
    Jul 2003
    Coastal N.C.
    87
    So all I need to do is get a good set of comp.'s for the front door panels and unhook the rear spks. Would it be beneficial to get some sort of filler for the rear, i.e. a pair of Kenwood 2-ways or such? TIA.
    `pr0digy's Avatar
    `pr0digy is offline - turbobricks.com -
    May 2004
    Philadelphia, PA
    1,676
    Quote Originally Posted by Kaos
    I'd just completely ditch the rears, if I were you. Especially in a truck... I have a wagon, and only use the front set of speakers, sounds great
    HU: Apline 9815
    Sub: Image Dynamics 12 v3 @ ~ 28 hz
    Sub Amp: eD NiNe.1
    Comps: Looking towards ID CTX65cs
    Comp Amp: Needed! Got 150w x2 @ 4 ohms to sell ?
    The Tempest's Avatar
    The Tempest is offline Junior Member
    Nov 2004
    Illinois
    Truck interiors are too small to need that many speakers to get loud. One nice high quality component set not only saves you lots of money, but should get more than loud enough for any daily driving application.
    Kaos's Avatar
    Jul 2003
    Coastal N.C.
    87
    I'm looking into some Fosgate Power 6x8's w/ tweets. Is there any diadvantage to haveing an oval spkr. as opposed to a round one? And does anyone have any feedback on these spks. TIA
    bibby's Avatar
    bibby is offline CarAudio.com Elite
    Sep 2004
    none
    26
    4,941
    i have two 6x9's, two 4x6's and 4 tweeters, on a 75wx2 amp, and it screams at you! (91 s10 ext cab)
    If you are viewing my profile from SMD, FSC, or d-series.org, then this is the thread with my refs...
    Refs: http://www.caraudio.com/forum/showthread.php?t=231239
    Sleeklsc's Avatar
    Sleeklsc is offline CarAudio.com Veteran
    Jan 2004
    IL
    6,748
    17 Post(s)
    people say ovals distort quicker and dont have as good of a midbass responce then round ones..
    you can prob fit 6 1/2's in there..you will have to make a plate for them though..it just converts tthe 6x8 to a 6.5...its rather easy to make as well..use 1/2" mdf..
    Ref's:1. Midwestcustoms 1.5. Desertheat 2. Mjbailey 3. Terryracing86 4. Sickmint79 5. Untouchable11 6. mattj 7. Ssweet96 8. Kool9accord 9.Kristinspapi10. Kmhogan224 11. Alpine3612 -x3- 12. Vectork39 13. Livinlife 14.Chriscivic 15. Violentraptor 16. Ricky616 17. Bassaddictj 18.orioles26 19.Khail19 20. jak3th3snak311 21. Myjaja 22. Springy101 x2 23. Ali1 24. Privatepastry 25. Plus about 10+ more..
  9. #9
    Kaos's Avatar
    Jul 2003
    Coastal N.C.
    87
    I do sheetmetal work for the USCG, I could probably whip up a bracket there out of aluminum, unless you guys think it would vibrate. Suggestions welcomed.
  10. #10
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Quote Originally Posted by bibby
    Doesn't mean it sounds good
  11. #11
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Unless you went with very thick metal, I'd probably advise you to stick with a wood bracket. Metal would definitely resonant badly. If you wanted to stick with metal....then sound deaden it heavily and it would proabably be a good idea to wrap some molding clay on it as well (the heavier the better). But I would atleast make a wood baffle for the speaker to mount too.
  12. #12
    audiolife's Avatar
    audiolife is offline WhAt?
    Feb 2002
    indiana
    42
    14,367
    0id just buy qforms kicks and a roll of sound deadner. unhook all your factory stuff and amp the component set and the subs. results arent as good as making your own kicks(if you are experienced) but better than just nob diving into fiberglass work...but then again if it intrests you you gotta learn sometime lol....have i confussed you yet?
    Sony Mobile ES C-90 Audison Bit-One
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
  13. #13
    Kaos's Avatar
    Jul 2003
    Coastal N.C.
    87
    I built offshore fishing yachts for 2.5 years and know about glassing, but I don't really want to go that route. I will probably go w/ the 1/2" MDF. I do however have access to 1/8" Lexan (sort of like plexi-glass, but bulletproof). Do you think that would deaden the sound, or should I just go w/ wood? TIA.
  14. #14
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Wood.
  1. Rear fill to Front speaker ratio.....(long)
    By Pl8er in forum General Discussion
    Last Post: 02-22-2008, 01:59 PM
  2. Antenna in Back, FM Modulator in Front
    By JedK1 in forum Wiring, Electrical and Installation Help
    Last Post: 02-27-2005, 10:31 PM
  3. Feed back through front speakers
    By dave_in_OOB in forum Amplifiers
    Last Post: 10-08-2004, 02:05 AM
  4. Can i convert 4" speaker hole in the front to 6.5" from the back?
    By venom107 in forum Wiring, Electrical and Installation Help
    Last Post: 01-17-2003, 12:27 PM
  5. WOOFERS FIRING TOWARDS THE BACK OR THE FRONT?
    By crispy highs in forum Subwoofers
    Last Post: 11-14-2002, 06:26 PM
