Results 1 to 5 of 5
Reload Thread: WTF? Tweeter wiring?
    Scarenius's Avatar
    Scarenius is offline Call me Ravo
    Jul 2004
    Michigan
    479
    I took apart my roadmaster set (Maybe put decent modbass speakers in the box?) and after checking the tweeters, I noticed they have a very very stange crossover setup.
    Positive attaches to a little HP crossover that looks like a resistor that then goes to the tweeter's positive terminal. Negative attaches to the negative terminal, then goes through a second HP crossover, exact same kind, and into positive! What the hell is that?
    Current Setup
    "Power is probably the least efficient way of increasing SPL."
    - Jmac
    boister77's Avatar
    boister77 is offline CarAudio.com Elite
    Dec 2003
    SoCal
    36
    824
    Re: WTF? Tweeter wiring?
    looks like two resistors in parallel. maybe they were trying to use a certain resisitance that isnt' common so they had to use two resistors in parallel to achieve it.
    www.realmofexcursion.com: Free Hosting for Videos, Pics, Audio, and more!
    forum.realmofexcursion.com: Another car audio forum.
    NofriendsSpongr's Avatar
    NofriendsSpongr is offline Senior VIP Member
    Sep 2004
    Murrieta ca
    258
    Dont bass blockers look sort of like that? maybe thats what they are?
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    the real question is why the heck are you using roadmaster?
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    Scarenius's Avatar
    Jul 2004
    Michigan
    479
    Ok, I bought these things, Walmart special. I thought for $15 I get a nice box for 6.5"s and 3" tweeters. The fact that a cheap component set was with it doesn't mean much. That and at the time I'd never heard of Roadmaster. I had them in my room, and when you don't have ambient noise, they work pretty well. Then my little Mobile Authority 100 watt amp blows the tweeters up. Meh.
    I know it's bass blockers, I just wanted to know why they wired it like they did. Usually just in series with the positive wire suffices. I'm not going to worry about it.
    Current Setup
    - Jmac
  1. WTF is up with my system?? alt or wiring?
    By TooLowTooGo in forum General Discussion
    Last Post: 11-08-2004, 03:09 AM
  2. Box Volume.
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 02-24-2003, 01:37 AM
  3. So the wiring harness I bought for my HU does not fit
    By Gauntlet in forum Wiring, Electrical and Installation Help
    Last Post: 11-28-2002, 09:19 AM
  4. does the size of the wiring matter??
    By ZmanTT in forum General Discussion
    Last Post: 08-02-2002, 06:19 PM
  5. component tweeter placement question
    By crzybob77 in forum Subwoofers
    Last Post: 07-06-2002, 04:37 PM
