Results 1 to 4 of 4
Reload Thread: Tweeter Level
    fossil99ca's Avatar
    fossil99ca is offline Member
    Apr 2004
    Toronto
    86
    Tweeter Level
    I have the infinity 605CS component set. I am running the tweeters already at -3db on the cross-over but I would like attenuate the tweeters even more than that if possible, say to -6db. (the cross over only has level and -3db)
    Is there a way to do this either by buying something that goes in-line with the speaker wires, or by making something myself? I know I could buy a new cross-over, but that might cost as much as the component set itself.
    Would also be helpful if the modification didn’t screw with the cross-over frequency. I speculate I could put a resistor in-line with the tweeter, effectively increasing the resistance of the speaker and lowering the power output but that changes the cross-over frequency I believe.
    Any help would be appreciated.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Re: Tweeter Level
    fossil99ca's Avatar
    Apr 2004
    Toronto
    86
    Re: Tweeter Level
    Thanks, knew they must exist but didn't know what they were called.
    Although, I can only find 8 ohm L-pads on the site. The one 4 ohm was discontinued. Do you know who sells a 4 ohm
    djdilliodon's Avatar
    djdilliodon is offline CarAudio.com Elite
    Dec 2002
    New York
    658
    Re: Tweeter Level
    if u want a cdt audio lp-1 l pad let me know i can help ya out 20 shipped will do both tweets
    Contacts:
    email - islandsound1@yahoo.com
    AIM - djdilliodon
    05 SRT-4
    System in the works
    MIDBASS ?
  1. Tweeter Install for best imagine help!
    By shtoops in forum Wiring, Electrical and Installation Help
    Last Post: 10-08-2004, 03:57 PM
  2. component tweeter placement question
    By crzybob77 in forum Subwoofers
    Last Post: 07-06-2002, 04:37 PM
  3. HU's Line Level Output to AMP's Speaker Level Input
    By Unregistered in forum General Discussion
    Last Post: 02-09-2002, 03:51 AM
