Results 1 to 9 of 9
Reload Thread: Help choosing 4" drivers. Specifics.
    Tirefryr's Avatar
    Tirefryr is offline PoonTang Addict!
    Oct 2003
    IN
    34
    1,718
    Okay, I've been doing some research for a project and I'm coming up short on 1 thing. I need a 4" driver with an outter diameter of NO MORE THAN 4.5", with a low FS (40-60), a decent efficiency rating (at least 88dB@ 1W/1m), and a vented pole piece.
    Now I can find quite a few hundred that meet these specs except for the vented pole. Can anyone help me out?
    Thanks!
    A bunch of SSA stuff.
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,368
    Re: Help choosing 4" drivers. Specifics.
    and why dont you want the vented pole piece ?
    Tirefryr's Avatar
    Oct 2003
    IN
    34
    1,718
    Quote Originally Posted by supa_c
    That's the whole point. I WANT the vented pole. Just in my research I have yet to find one that has info on whether or not it has one, or any pictures on the ones I have found that clearly indicate that they do.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Midwest Ohio
    26
    3,509
    Why do you want a vented pole
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Quote Originally Posted by Tirefryr
    Why does the driver you are looking for need to have a vented pole piece? Or is this a want vs. need thing?
    Tirefryr's Avatar
    Oct 2003
    IN
    34
    1,718
    It needs a vented pole. It's a specific for a project I'm working on.
    Feb 2004
    Midwest Ohio
    26
    3,509
    explain why then, i don't see how it would make a difference
    97 Monte Carlo
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Top secret?
    I assume you have already checked with Atomic Fusion. If anyone would know, he would.
    But good luck......I don't think I've ever seen one. Have you posted the question on sites like the madisound discussion forum and avs home audio forum?
  9. #9
    Tirefryr's Avatar
    Oct 2003
    IN
    34
    1,718
    Quote Originally Posted by monte_carlo97
    IT's for a project. Just NEED the vented pole.
  1. Help Choosing speakers!!!
    By spicmonster in forum Speakers
    Last Post: 07-04-2004, 07:58 PM
  2. Gen XI balanced line drivers
    By nismboy6986 in forum Amplifiers
    Last Post: 05-10-2004, 03:39 PM
