+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: Question about Pro Audio Components vs Normal Component Speakers
    BigSteve757's Avatar
    BigSteve757 is offline Junior Member
    Jan 2014
    Virginia Beach, VA
    30
    21
    6 Post(s)
    So i bought a pair of Pro audio speakers (CT Sounds STRATO PA (PRO AUDIO) 6.5 Components)
    to replace my factory front door speakers and now i see that alot of people say they wont sound good without some type of equalizer and a bunch of tuning...Is this true??? if so should i send them back and get normal component speakers???
    Just for your info...
    I have a set of CT Sounds 5x7 Meso Coaxials for my rear doors
    A Soundstream ST4.1000D for the door speakers
    A single Skar ZVX 12 paired with a Skar Skv2-1500.1
    A 3.0cuft box tuned to 32hz
    A 320 amp Apex Alternator
    A Pioneer MVH-2300NEX
    evilmonstertruk's Avatar
    evilmonstertruk is offline Premium Member evilmonstertruk is a Supporting Member of the forum!
    Sep 2014
    Virginia
    1,137
    3 Post(s)
    336 Post(s)
    Re: Question about Pro Audio Components vs Normal Component Speakers
    Quote Originally Posted by BigSteve757 View Post
    They will sound fine. Just no midbass. All the PA style 6.5s have no midbass. You should eq no matter what speaker you get.
    Sent from my SM-N950U using Tapatalk
    Jan 2014
    Virginia Beach, VA
    30
    21
    6 Post(s)
    Quote Originally Posted by evilmonstertruk View Post
    Do you think the rear coaxials would be enough to make up for the mid bass?
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,196
    245 Post(s)
    7918 Post(s)
    Your head unit is already way superior than any sub 100 dollar outboard EQ out there. The main important thing is running network mode for active crossovers which your head unit can do if you choose network mode after a factory reset. EQ is no where near important as the crossovers when it comes to pro audio. You want to have the mid and tweeter wired directly to their own channels of the amp, throw away the passive crossover completely and leave your rear speakers on head unit power. Absolutely no attention, money or power should be put into the rears at all, completely useless and degrades overall soundstage and sound quality. After a proper crossover point
    and speaker level adjustments tune, then you time align the mids and the tweeters. Then you work on the EQ then you repeat everything over and over again till its perfection.
    Completely and utterly false, it depends on the driver's TS specs and overall frequency response and your overall install/door acoustics. I heard some cheap @ss skar FSX 6.5s thump down to 80hz hard in the right setup. No it wont play lower midbass to subsonic range aka 50-80hz that well but it more than gets the job done paired with a sub.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  5. Likes beak81champ liked this post
+ Reply to Thread
  1. Replies: 35
    Last Post: 01-31-2013, 09:06 PM
  2. Question about component speakers
    By soldiermedic in forum General Discussion
    Last Post: 09-05-2009, 01:30 AM
  3. Newbie Question on Component Speakers
    By jameisonstyle in forum Speakers
    Last Post: 07-07-2007, 10:50 PM
  4. component speakers vs normal speakers
    By tebo7 in forum General Discussion
    Last Post: 07-09-2006, 09:05 AM
  5. Cross Over Question and Component Speakers
    By TheSensFan in forum General Discussion
    Last Post: 05-11-2006, 05:34 PM
