+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: 6.5" Passive Component Set Suggestions
    cas0586's Avatar
    cas0586 is offline Member
    Nov 2014
    WV
    76
    20 Post(s)
    Looking for recommendations for a 6.5" passive component set. I will be using a Precision Power P900.4 amplifer to drive these and the rear door 5.25"(also tbd). I currently have a set of CDT Audio MX-6CV.2 being driven by this amplifier. I feel I need a bit more midbass. Is there anything in the ~$200 range worthwhile or should I just stick with what I currently have? Will be moving these from one vehicle to another(new dd). Thanks all.
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,392
    110 Post(s)
    7901 Post(s)
    Re: 6.5" Passive Component Set Suggestions
    Run them active. No rears
    Or get the install right if it isn’t.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    cas0586's Avatar
    Nov 2014
    WV
    76
    20 Post(s)
    Quote Originally Posted by LosIsATool View Post
    Nothing wrong with the install, but if I can find something better I am willing to purchase if it is in that budget. I am going to be swapping these to another vehicle if I stay with them. I could go active but I am not sure how much power the tweeters on that set can handle. I do not see it on the specs anywhere.
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,196
    245 Post(s)
    7918 Post(s)
    Quote Originally Posted by cas0586 View Post
    most can handle 100 watts easy with good crossover points and slope control. Did you do full acoustical treatments? no just deadening alone with CLD tiles is no where near good enough. Most midbasses want 200 watts before they reach the point where they produce clean midbass. You can also lower all other frequencies to match the amount of midbass and raise overall output level as well with your tune.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
+ Reply to Thread
  1. Decent 6.5" Passive Component Set?
    By jgruberman in forum Speakers
    Last Post: 02-17-2017, 04:13 PM
  2. 6" component speakers (passive) on a budget.
    By cwzilly in forum Speakers
    Last Post: 10-28-2009, 01:17 AM
  3. 6.5" Component Suggestions???
    By RCobra07 in forum Speakers
    Last Post: 05-22-2008, 01:12 PM
  4. 6.5" component suggestions
    By denj3325 in forum Speakers
    Last Post: 01-09-2008, 11:04 AM
  5. 6.5" 3 Way Component w/Passive Crossover
    By qtipextra in forum Speakers
    Last Post: 09-28-2006, 10:59 PM
