+ Reply to Thread
Results 1 to 5 of 5
Reload Thread: Help getting my pa mid's blend with my tweets
    bajbass's Avatar
    bajbass is online now Junior Member
    Jan 2018
    baj
    22
    8 Post(s)
    Ok so I have some pa powerbass xpro 6.5 mid's in my door and massive ct-2 tweets in the dash just wondering if it's better to cross the tweets high like 5k or so and just let the mids take care of 5k and down since it was noted in the manual it could play up to 7k I think ...usually I get a better staging crossing the tweeter lower..
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,965
    240 Post(s)
    7783 Post(s)
    Re: Help getting my pa mid's blend with my tweets
    just experiment, it'll be different in every car. some cars worked fine with 3k at -18 db, some works great at 8k at -6 db, some worked great at 2.5 at -24 db. Its all dependant on the midrange driver and overall interactions with the vehicle's acoustics. Cookie cutter crossover points wont help you, you need to put in at least an hour of experimenting.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    bajbass's Avatar
    Jan 2018
    baj
    22
    8 Post(s)
    ok i also read some where if u use a 12 db slope on both mids and highs u need to reverse the polarity on the tweets so they will be back in phase at crossover point is that true?
    Water Bear's Avatar
    Water Bear is offline Senior VIP Member
    Oct 2017
    Atlanta, GA
    175
    100 Post(s)
    No, that is not true. Changing amplitude (applying a crossover) has no relation to changing phase.
    Edit: actually, changing the polarity of the tweet relarive to the mid could create destructive interference, reducing total output.
    Quote Originally Posted by bajbass View Post
    Sent from my SGH-S970G using Tapatalk
    Polk DB 6.5 components and coaxials, Alpine MRV M1200 (1200x1 @ 2) and MRX F30 (50x4 @ 4) amplifiers, Pioneer double din HU, Sundown SA-12 in ported enclosure (built to spec).
    Jeffdachef's Avatar
    Feb 2013
    15,965
    240 Post(s)
    7783 Post(s)
    No thats horse sh*t
+ Reply to Thread
