+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: debating between active and passive crossover
    millerb415's Avatar
    millerb415 is offline Junior Member
    Apr 2018
    los Angeles, CA
    11 Post(s)
    here is my set up infinity kappa 60.11cs front, kappa 6x9, alpine pdx-v9, and an alpine sub. was debating about whether or not to run the 60.11cs active on the amp or to run them passive using the crossovers that came with the speakers, and powering the back speakers also. what would you recommend?
    Louisiana_CRX's Avatar
    Louisiana_CRX is online now dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,550
    24 Post(s)
    1886 Post(s)
    Re: debating between active and passive crossover
    Quote Originally Posted by millerb415 View Post
    If active is setup properly you’ll get better sound ..especially if you ditch the 6x9s..
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
    youdoofus's Avatar
    youdoofus is online now Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    2,061
    5 Post(s)
    911 Post(s)
    Quote Originally Posted by Louisiana_CRX View Post
    ^^this, all day err day^^
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-2300NEX
    2 PPI PC275's running 1 sub each atm, waiting to put the SQ 2200.1 back in and add the PhoenixGold Elite.4 once my electrical is up to snuff
    Stock front and rears (theyre actually squirrels listening to headphones that ive trained to sing what theyre hearing)
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,962
    109 Post(s)
    7679 Post(s)
    Nothing wrong with a 6x9 if they are quality. That’s **** near a 8in. Just need a tweeter, wide band, mid range that can play low enough
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
+ Reply to Thread
